Everything posted by subiemech85
what kind of radiator did they send me! help.
ea82, definately auto possibly turbo maybe
Make an EA82 carb motor run like it's not a carb motor?
check the sparkplugs, if they are not NGK bpr6es-11, change them asap
brat tailgate on ebay
Thanks Mic for the rescued tailgate, I don't need the one off ebay, nor could I afford it at that rate
what is it? 84 ea81 emissions control?
what do you use to remove decal glue residue?
xylol
Decal my wife picked up for me :)
"how much and give it to me" I do like me2
what is it?
yes I am searching for how to disable it in my 84 brat
I so NEED that tailgate, and YES, I do have a brat does it work properly? how much for shipping to 50156?
Are there any FAQ's?
and, yes you can swap a 3.7 lsd parts to make a 3.9 lsd
$200 Score with Trans ??
yes, that is 4x4 though, that is why you can go with a 5 and keep it fwd
Adding Oil Cooler....less oil pressure??
yes
check the govenor, or replace with 5 spd fwd manual trans, I vote for the 5 spd
benefits of a spider? carb?
what's the benefits? can it be used with carb?
4spd or 5spd? d/r or not?
http://www.ultimatesubaru.org/forum/showthread.php?t=14547&highlight=gear+ratio is about gear ratios in 5 spd dr does anyone know the ratios for the dr 82 and the others, I hear there is a difference I prefer my super 10, it is so nice in snow to shift between hi and lo, start in 1 lo work up to 4 lo, then 4hi, then 5 hi also, when playing at the river bottom, go in fwd, when you see water, STOP IMMEDIATELY, shift into reverse low, and there you be free
85 brat 4" lift for sale
is the 4" lift for sale? who made it?
Need color coded wiring diagrams, 85 ea82
horns weren't working when I bought the car, so off went the horn pad also pulled off the horns, didn't work wires melted by right side of rad after turn signals and windows quit working, I pulled down fuse panel wire for fused side has completely melted insulation, it combines 4 wires, and every one has melted insulation I Need a Color coded wiring diagram, the fsm has stupid black lines with no color designations sorry, my bad, this is 900
A wierd one. what do you think of this????
that's the hazard switch, and the parking light switch is part of the headlight switch that is on the left side of the dash, at least it is on 85 OMG: 900TH POST
http://www.ultimatesubaru.org/forum/showthread.php?t=10101&highlight=melted+fuses
ea82 performance increase
http://ngksparkplugs.com/ http://ngksparkplugs.com/techinfo/spark_plugs/faq/index.asp?nav=31200&country=US
had a meltdown, turn signals, hazards, and windows all quit, clock works, as does locks
Model identification information
http://oreillyauto.com/B2C/vehicle.ecatalog I use this link for parts all the time you may have to specify a newer year, ex. 88
Once again - noisy lifters
1. please post only one ? at a time, helps avoid confusion 2. http://www.matkurja.com/eng/country-info/ nice country 3. try 20w50, marvel mystery oil, risoline, seafoam 4. pull the axle 5. byb or pk davis lift kits 6. welcome
Welp, I bought a Subaru (the trouble with licensing it)
what ever happened to "in transit" ?
New rear speaker option for wagon owners!
by doing that, you decreased the hauling capacity for the fill the car up and pile it on the roof sales! go for some wheel well mounted ones I remember spending many hours laying down on the back seat listening to the speakers in the doors
Pressing on
d/r 5 and s/r started in 85
