Everything posted by subiemech85
you need to first 1. find the oil filter and change the oil and filter 2. that is where the pump is 3. SEARCH
pic is on page 6 with link http://www.cardomain.com/memberpage/471729/6 That babe said a lot of bull to a lot of people
what size exhaust after glasspack
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
problem fixed $120 later, write-up on page 5 -
proboably going to cut up a junk tire from a pug wide baler belting would work, convenient sizes
remove the cap ea81 wagon cap used to not seal
aftermerket mufflers
subiemech85 replied to The Scooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
went to exhaust pros for piping custom system of pipe going to and from glasspack in stock location, seems quieter or equal to ea81 stock pics of before and after are on page 5 -
hitachi secondaries question
subiemech85 replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
snowman do tell about mod for pwoer while keeping economy if you can -
super, did you check size?
DO NOT BUY POWER MIKE WHEELS ALWAYS MAKE SURE DISK IS TIGHT
cool guy repiled put text and pictures on cardomain http://www.cardomain.com/memberpage/471729/4
what to check when buying an ea82 wagon
subiemech85 replied to MaroonDuneDoom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
RUST -
the BIG boot at either left or right side by hood hinge I bought 25ft of green electrical stranded copper electrical wire, needed enough for ground
going to exhaust shop Saturday, need to know what size pipe to run after glasspack tired of my ears ringing from glasspack dumping behind my seat
sent an email hope for reply
gas mileage questions
subiemech85 replied to Buddythedog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mods accel coil 8140C, emissions delete, glasspack 22 mpg, and rising -
middle of guage, 45 when warm 85+/- when cold, goes down when warmed up 15w40 140,250+miles
I see you didn't buy a fifth plug, are you going to remove the EGR valve? Parts are as follows: EGR gasket fel-pro 70978 or 12-3075 air fliter wix 46016 oil filter wal mart/fram ST3682 dist cap MPI C631 add a fuel filter under the air box GKI 33011 slice n' splice GKI 33204 under car by axle Accel coil 8140C
does anyone know the sizes for the inner and outer flaps, nearest 1/4in.? are they available for the front?
hazard melting fuses
I still haul a "luggage" in the front seat I found the problem when I added more "turning signal fluid" I removed the horn wires on the right side up to the point where they run with all of the wires, the one wire melted the insulation off about a foot in length IT'S FIXED ! what is the closest point to the source that I can "disconnect" the horn wires" notice my "D" horn -
Iowa boy says "LOOK NO RUST! " It's a beautiful keeper
unsticking a Chevy Pickup
I hi-centered while drift jumping the snow banks along the fence line in the fields drove the dodge 4x4 to unstick myself by myself -
85 Brat won't start??
subiemech85 replied to rkmastiff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hijack at my hijacking pages -
What the heck is wrong with this piece!
subiemech85 replied to mikekucharski's topic in Old Gen.: 80's GL/DL/XT/Loyales...
second day of diesel power trains 404 I say check the clutch parts, springs, disk, torque dampening springs, alignment, and the obvious
