Everything posted by mikeshoup
				Addicted to bright (die dial up)
mikeshoup replied to Matty B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's pretty sweet looking. But yeah, you do need a light bar on the roof. -
				Are EA81 & EA82 Firing Orders the same?
mikeshoup replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All 4 cylinder motors fire 1-3-2-4 The Justy and ER27, EG33, and EZ30 are exceptions -
				Give me details on a XT turbo please.
mikeshoup replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, there are push button manuals also. Just Single Range though. -
				new engine in XT, won't start *SOLVED* Bad ECU
mikeshoup replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bah, you're right. -
Wastegate duy solenoid is on the turbo itself. Dunno what the Pressure sensor duty solenoid is though? An NA car should run on a non-turbo ECU. NA is non-turbo [edit] here's a thought. Have you checked that the disty in the right position? I don't know if your JDM motor came with the disty on it already or not, but it might be good to check. If that's good, have you checked that the disty cap isn't 180 degrees out of rotation? On mine, the #1 spot on the cap is pointing north (up) -
Its 1-3-2-4, counter clockwise. Geez gary, you deleted your question, so now my answer is null. -
				3eat? or 4eat? on a EA82 4X4
mikeshoup replied to LUVMYBRAT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
nope. all autos were single range. -
Easy way to tell is by looking at the shift console. If you have D-3-2-1 (or a switch labeled 1-hold), then its a 4EAT, if its just D-2-1, then its the 3AT. -
	Gotta love threads from 2004 that have been revived! My 86 XT Turbo was named R. Dorothy Wayneright by the previous owner (cutie-ru/roni). I call it Dorothy. My 88 XT6 (for sale!) is affectionately named doorstop.
	My XT Turbo is running SPFI pistons... Nothing but premium for her. I'd hate to imagine what anything lower would do to her. I would say, you'd be fine with regular. Just listen for nocking, and pay attention to any stumbling / hesitation from the car.
				I just Bought my first Subaru
mikeshoup replied to davido's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wheel pattern: 4x140mm. Pretty much only 80s subaru wheels or various puegot wheels will fit. If you search the forums, you can find stuff on doing a 5 lug swap from an XT6, or you can redrill your hubs to 6 lug. Engine swap: Many people have put in EJ series engines (like the 2.2L in the legacies). No need for a different frame if you stay in the subaru family. Some just may require more cutting and hacking than others. You could even swap in an EA82T to net you some more power. If you want more info on any of that, the search link is right at the top of the page! -
	My FWD XT6 averaged about 22 in the city (we gots lots o' hills), and about 28 on the highway. The last tank on the XT Turbo, I got 28mpg. That was a mix of highway and city driving. I was actually quite amazed at that...
				thinking of re-painting rx
mikeshoup replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Holy crap, this was in another thread. Its not a CF hood, its a CF hood scoop. -
	My bro has 243K on his 89 GL 3dr coupe, original motor.
	Read a little closer, its a carbon fiber hood scoop.
	I'm pretty sure the steering wheel won't. Different spline count. Someone on XT6.net had purchased an aftermarket steering wheel for the XT6, and none of the aftermarket adapters fit. It seems the XT and XT6 both have a completely different spline count from their EA-82 bretheren. Not sure about the shifter. You could always try
	Do you know if the turbo is good? It could be in bad shape and spewing oil and coolant into the engine.
	Those performance chips are useless. They trick the ECU into thinking the air is colder than it really is... yeah, you might gain some power, but the ill-effects can be pretty bad.
				getting home with no fuel pump
mikeshoup replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I assume if the pressure runs out, just get outside and pressurize the tank again. These are so cool ways of limping a car back. -
				MEET: CO: May 21th at Red Rocks Park
mikeshoup replied to The Korean's topic in Meet n' Greet. Your USMB Welcome Center
I'll be there sporting the XT Turbo I just acquired today. -
				Timing Belt Covers - Yay or Nay?
mikeshoup replied to mrroot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm sure it'd do great without timing belts, as long as you have someone to push Sorry, had to -
				1982 GL Wagon timing belt or chain?
mikeshoup replied to unibrook's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also same reason most auto makers use a timing belt instead of a timing chain.
