Everything posted by SUBARU3
1st Annual Subaru Feed and Speed (Central PA)
An MD-88 jetliner! I live in TX, so I fly up often. See: m2.aol.com/subaru3 (2) 95 Imprezas (4) Gen 1s (BRAT/DL wagon, auto/DLwagon 5 speed/GF But I will have a glorious rental car of unknow kind yet! Todd
I'll be in Waterville/JerseyShore, (Williamsport), PA that weekend, at our cabin.....I'll see if maybe I can stop by. Todd
Stage 2 Gen 1 wagon rear, hatch, glass rubber update
Thought I'd bump this up for those looking for front glass rubber. Todd
ANOTHER Stage 1 question
Anybody else know of applications from other vehicles for older Subis? Todd
The rubber for the back glass is the VW beetle, 72-77. I think 78 and 79 were all convertibles. The later beetles had bigger back glass. All the newer Mexican beetles have the same bigger glass too. Like I said, I have that rubber on my 78 wagon rear hatch glass and it works fine! Get the CAL look. Also, the front SUBARU hood emblem is available NEW, the same size and the same "font", in CHROME! This emblem was on a certain early Legacy wagon tailgate. I once stubled upon one in a salvage yard and said, "hey that looks exactly like the ornament on my Gen 1s!" (I ordered 5!!) They look nice on all my cars! New is wonderful!! Subaru # 93060AA010 I have some decent original ones too if anyone is interested. OH, the VW windshield washer sprayer, that fit's in the hood, also work for Gen1s. Todd
The rear hatch glass is the same on Gen1, Stage 1 AND 2. The 1972-1977 VW rear glass rubber will fit. Use the "CAL look" and then you don't need the reveal molding. West Coast Metric has them. http://www.westcoastmetric.com/bug.php?Section=Window%20Rubber&stat=1 I have it in my 78 and it works fine! Looks fine too! Todd
what paint matches valve covers?
"pontiac blue" engine paint for the blue color. Todd
Equivalents for obsolete parts.
Outstanding idea!! Todd
EA81 vs EA82
I agree and side with the EA 81 too. I have 4 cars with EA 71s, essentially the same engine and they are literally indestructable! Todd
ea81 A/C installation.
PAG oil is not compatible with R12, however POE oil is compatable with both. I have been told the POE, (Poly ester), oil is a better choice for conversions. Todd
Well, now the Idle wont go low enough for SMOG on the '78
I have found on EVERY Gen 1 I have, that a high idle is related to a "too tight" accelerator cable. If you loosen the screw holding the cable while the car is running, the throttle will fall forward and the idel will decrease. When tightening the screw for the accel cable, keep FIRM downward/closed position pressure on the throttle. Otherwise the cable will pull it up just enough to cause a high idle with a completely backed off idle screw. Todd
1997 Subaru 2.2 interference or not
SUBARU3 replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 1997 2.2 IS interference. This is quoted from the 1997 official SUBARU new model introduction/ Techical training manual: With photos of the new style 1997 piston it states that, " The shape of the new piston has eliminated the clearance that WAS available between the piston at TDC and a fully opened valve." This would imply to me interference. Todd
brat tailgate on ebay
Looks like a typical daily "winter driver" tailgate! Todd
He wants $100...what would YOU do?
FE was for "fuel efficiency". It had the higher compression engine and higher ratio 5 speed. It was rated at 50 mpg on the highway. (Moose....that might be your blue dash!!) I say get it! I see tons of good stuff and you would have fun playing with it! How many miles on the FE? I thought cars in the NW didn't rust so bad! Todd
Will dual port 1400 heads bolt onto a EA71?
I'm almost positive they won't work. The 1400 had shims and floating liners, there is a head variation from the 1600 with "cast liners". I maybe wrong. Anybody else? Todd
gsr parts wanted
Let me know what you may need too. I have quite a bit of GEN 1 BRAT and car stuff. Moosens and I are 2 of the earlier model guys. Todd http://m2.aol.com/subaru3
I have to agree. One only has 2 hands and 24 hours in a day. (8 is sleeping!) I know I get diluted in my projects and then nothing gets completed. I feel like I'm just treading water! Todd
Essentially, $100 is giving them away. I 'd pay it just to get them home and see what I REALLY had! The parts are worth way more than $100, if you have the cars that can use them. Are they restorable? Todd
Tips on passing SMOG? (78 wagon, with issues)
Rebuild the carb...cheap and easy. Flush the motor with gunk motor flush USE Mobil #1 15W15 Synthetic oil will not produce as high of emissions if burned. New spark plugs/wires and new coil Replace ALL vac hoses, although they can appear good, they leak from being hard. Replace the PVC valve Adjust the valves. I have never failed an emissions here and usually the cars run nearly as clean as my Imprezas!! Oh the Gen1s did not have a CATs till the 80/81 BRAT. Original CA cars "may" have had a CAT, but I'm unsure. You should be fine! Generally, EA-71s are very clean running when maintained, even with high mileage. Work from the cheapest/easiest, to the more expensive, more complex repairs. Regards, Todd
The front windshield rubber for 77-81 BRAT 76-79 wagons and sedans, (except GF) is available at www.prp.com They only had about 30 remaining, They are VERY high quality and new. The factory SUBARU ones, (when they were available), had been on the shelves for 20 years! I HIGHLY suggest gen 1 owners get one while they can!!! (And don't linger in this.) Leaks will cause rust. AND you might never be able to find one again! Todd
Actually , it's 72-77 rear glass. Super Beetle and regular beetle were the same glass. Todd
I also know the VW front washer/sprayer, (that goes in the hood), will work nicely on the Gen1's too. I have replace all 4 of my Gen 1's. You just have to aim them higher. I now have a nice pressure stream, instead of a drip! I'm curious if the VW door side rubber may be just as adaptable?????? Ideas? As these cars get older and less unique parts are available, we need to address alternate applications. I think we should develop a database of alternate applications! (Kinda like what the 360 owners have done.) Todd
Mike: This VW application is for the rear, hatch glass. NOT the 1/4 rear side windows. Just want to clear up any confusion. Todd
Ok...it's official! The replacement for the rear window/hatch rubber weatherstrip is the one that fits the VW superbeetle rear glass! I installed tonight in my 78 DL. It was a perfect fit! The "Cal-look" is wider and works better I think. No need for the "reveal" molding then. My original was pretty dry and brittle. You can get these strips for next to nothing and they are plentiful, as VW has everything aftermarket AND from the Mexico factory. I am so pleased that there is now a replacement, as many of these Subis have leaking or bad seals. So pass the word to those Gen 1 wagon owners! Here's one place they are available. http://www.westcoastmetric.com/ Todd
A/C compressor repair options 91 legacy?
SUBARU3 replied to gbrand's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere neighbor: I'm over in Euless. My roomate and I did a 91 Legacy Lsi last summer to 134A. It was a bear! 3 bad rebuilt compressors, till we got a good one. The Calsonics do not rebuild well I am told. Congrats on getting the job done! http://www.pbase.com/txguy/subaru_legacy Todd
