238
Everything posted by Loyale 2.7 Turbo
DOHC EA82 (Aviation)
Loyale 2.7 Turbo replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Creator of those DOHC Heads (16 Valves) for the Subaru EA82 engine, Mr. Neil Hintz, from AutoFlight, does not answer his e-Mails... I tried to contact him (also another USMB Members), asking info about those heads, the timin' belts he used, if they could be suitable to be used in a car; etc... Nothing. I've spent many, many hours reading his threads in Gyrocopter forums, and beside learning info about those, I collected these photos of the DOHC EA82 engine, which he named as: "AutoFlight 140N" due to its Easy 140 Hp it Develops: -
Loyale 2.7 Turbo replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, I emailed him too... and a couple of people more on the subject, without any response. There is a Discussion Thread about that, with more Photos, going on ~► Here. Kind Regards. -
Dash/Tail Light weird issue '94 Loyale
Loyale 2.7 Turbo replied to Leisa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, Thank you! I Imagined that back then, but I was somehow in a Hurry when I Wrote that Writeup. You're Welcome! -
Thank you for your Kind Answer. I did a 2" Lift on my Subaru "BumbleBeast" but I dropped the Engine's Crossmember 1½" in order to aid to the Axle's longevity. Kind Regards.
Any Updates / News \ New photos of the Project?
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Clunking noise at low speed turning
Loyale 2.7 Turbo replied to epix's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Kindly suggest you to check for worn / Loose Ball Joints. Sometimes that Kind of "Clunk" sound on Low Speeds are due to Ball Joints about to Fail... ~► http://www.mobiloil.com/USA-English/MotorOil/Car_Care/DIY/Ball_Joints.aspx Kind Regards. -
Look Here, this writeup might have Useful info: ~► http://www.ultimatesubaru.org/forum/showthread.php?t=90403 Kind Regards. -
Weird smell when turbo kicks in
Loyale 2.7 Turbo replied to scoobywagon45's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Guess you meant like a Burning Oil (Diesel) Smell, isn't it? Does it leaks Oil? Kind Regards. -
Yes! I Really like how that Lifted sedan does look like. Could I ask if you Dropped the Engine's Crossmember and Rear Differential, when you installed the 2" BOSS Lift kit? Kind Regards.
Now add 16 Valves DOHC Heads For the EA82 to the Mixup... ...more info on the Heads, ~► Here. Kind Regards. -
Here's a Magnificent Subaru Turbo EA82 built in 1984, which is in almost Show Room Conditions, For Sale in Las Vegas: This is the "For Sale" ad: ~► Here. With only 83K miles... Who's gonna buy it? -
An Advertisment for an Earlier Subaru Rex / Sherpa: -
Welcome! It looks Nice & Clean; if you take care it will last many years and good adventures to come... Kind Regards.
The LADM (Latin American Domestic Market) is the world's "Oddball" of car Markets, so you can find "Mixed" Style cars been sold here without problem, not Only Subarus, also other Brands sells here cars with EUDM specs. Kind Regards.
- 96 replies
- Dual Range EJ
- LatinAmerican Domestic Market
- (and 7 more)
The "One Reverse Light" tail lights Setup always comes with the single White One on the Passengers' Side Almost all Latin American Countries has LHD Cars, like USA and Does Follow the USDM Standards, so Usually the "Dual-Reverse-Lights" Tail Lights' setup is more often seen, but since LADM (Latin American Domestic Market) is the World's "Oddball" you can see some Subies -and other cars- sold here with EUDM Specs, such like the "One-Reverse-Light" setup, without any especial reason... The Subaru in the Following Photo, belongs to a Friend who lives in Ecuador, South America, The Single White Reverse Light is on the Passenger Side, Which is the Rear Right since since the Subie is LHD: But the RHD "One-Reverse-Light" Setups does have the single White Light at the Other Side; Which still is on the Passenger Side, because this car is RHD. By the way, this last one is an EA71 (1.6L) Engined Wagon. Kind Regards.
- 96 replies
- Dual Range EJ
- (and 7 more)
Hi Mark! I Like your "Dirty Impreza" Sweater! Kind Regards.
- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
Timing belt issues
Loyale 2.7 Turbo replied to briankk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Remember that NickNakorn, who posted that photo, does live in England; So that hole is in his Passenger's Side Cover. Kind Regards. -
That is a Nice Photo, of a Beautiful Subaru Impreza in a very Good Landscape! ... I Really Like it. Kind Regards.
Timing belt issues
Yep, it could be, but with that Timing Belts' placement is not easy for debris to get there. Long time ago I serviced the Timin' Belts on a 1991 EA82 Sedan (Not Mine) and the covers were holding (collecting) inside a good amount of oils (Engine Oil + Power Steering Oil) mixed with dust = Muddy debris inside... I asked to the owner if I could leave them off, she told me: "Do whatever you want" She only needed her car to be good to go... I believe that under certain circumstances, the "Naked" Belts could somehow manage to clean themselves, keeping oil off, not only due to the Spin movement, but also the warm air blowin' to them from the Radiators' fans. Kind Regards. -
Timing belt issues
Now that's Epic! ... ... I've somehow "Teached" many Honduran Mechanics on How to do the EA82 Timin' Belts Service, now think that they're "Trained" in Mechanic Schools... I Learned how to do that, Here in USMB, Long time ago... also to let the covers off. Kind Regards. -
EA82–vacuum hose problem or bad fuel filter?
Loyale 2.7 Turbo replied to DaveS's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Carburator, huh? ... so these might be Keywords: It could "Swallowed" Dirt to the Carb, but also... ...yes, there are some hoses that originally should go from the carb to the carbon canister, if you cross them, sometimes the engine will run for a while and then it stops... You can test if that is the culprit, by capping closed temporary all the vacuum ports and see if the engine works. Kind Regards.
