Everything posted by beataru
Max speed in 4 hi ???
torque bind is ugly!! And bad for the center diff!!!
Ever seen this much stuff on your front diff drain plug?
Diffs are beefy... Subaru diffs are industructable.. I think NASA uses subaru diffs to smash them into comets or something... then they fall back to earth and get put on a Loyale or something:rolleyes:
2007 Factory Subaru synthetic fluid manufacturer
beataru replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprobably mobil but.. im probably wrong since i never have seen mobile with atf.........
EA82 Coil (Igniter)
yeah sort of.. the coil takes 12 volt charge (high amp) and sucks it up into a 35-45 thousend volt charge to make the spark ignight the flame. then sends it through the little black square thingy on the coil... thats the igniter. without the high voltage the spark wouldnt have enough power to jump acrossnthe plug under compression... I would just go ahead and buy a MSD coil.. or an equivalent.. Im going toget one sooner or later... itl give you a hotter spark... hope it helps
Wow.... Land Rovers are pretty hardcore
the V8 was a good engine... it was out for something like 10-15 years or something like that... rover has gone to the puss show now!!!! auto decent is cool and all but.. I like my foot better.
*sigh* going to take the plunge into EJ swappageness!
Big hammer... Ducktape... zipties.... Gasoline... Battery.... Oil... Preferably mobile 1 0w-40.... big td04s..... hks bov.... Key... Guts to floor this badass down the road. Oh yeah... radar detector, jammer!! Illeeeegal but who cares if it works then they wont know!!! post lots and lots of pics EVERY STEP OF THE WAY!! Like when you purchase an AN fitting on ebay... take a picture of your happy face!! and when you blow it up..... wait happy thoughts happy thoughts Go aluminum with the rad!!! and use waterwetter!!! It works.. ime sure you know that though.... well i guess ive wasted enough of my post so.. back to you!
Subaru STI ATV
this thing looks so stinking slow... if its a true sti with everything.... then why wont he give it the juice!!! its not going to pull a wheely.. its got awd and an engine in the front!!! and not to menchen a panzi at the wheel:grin:
Lube tire bead
You wana know what they really use??? Like in shops and stuff??? Its really really simple... I didnt even know it was this simple... Untill I looked for the in our toolroom at my school... LARD There I said it.. hard to believe huh?? Soap will work but..... use lard... silicone spray is 1000s of times better than soap but lard is the best option dont forget to be very very generous!!! dont tear a bead!!! some kids already did it at my school (on practice wheels of course) just because they got lazy and didnt lube it up!! Oh! I forgot... i think its a special lard but im not sure.. or at least its more expensive than regular lard... But napa should have something that would work.. i dont think autozone or checker/shucks or even kragen would have it
Hitched another subaru
Yeah thats the thing I was talking about!!! Radio shack really would have these?? they have the little plastic thinggy mo bober that has the phillips head on it too.. right?
my car has an aftermarket sterio in it and... my trip computer still works... it has this big thick extention piece of plastic that brings it out about 3 inches... I didnt install it so I dont know where to get things for it... ABout the lights... Well.. I took mine apart and... lost 1 in the process... and some how lost the otherone too.. but I took a picture in my photographic memory... I dont know where to get them but NorthWet suggested that I try checker or something like that... Im gonna go to BAP since there exclusivly imports... I hope i can find them!!! Besure to post if you find where to get them!!
Ram Engines Did it again!
back when I interned at chandler air service... I learned all the terms and phonetic alphabet and blah blah... but i did learn that when you say cross country, it means 50 miles or more.
i got my first car....guess what it is...
ive got kooms.... I like them for the price!!!
overheating 98 forester
beataru replied to mwills's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry to hungry to read... but EJ-25s overheat hugely when they blow HG's...
Aftermarket gl taillights
I like my tail lights... only the headlights are something I would change... to Litronics... but those cost lots, and arnt made for a Gl-10....
No start - gas and spark OK...
The Pump gets power when its in the on position it senses pressure drop and then pulsates... what you saw on you meter was it getting a power surge so it will boost the fuel pressure for start up... (correct me if im wrong guys) and idunno about the block heaters
are all late 80's EA82 Manual FWD transmissions the same?
Which means lots and lots of replacements!!!
Will a wrx turbo bolt to a EA82T?
itl get rid of your MAF?? YES I WANT IT NOW!!!!
Hard to put into 1st Gear when cold
Yeah double clutching works too... And im not saying to become a ulmate racer... just an expierement for you subiebuffs... its getting cold here in az also... you can really feel the car drag more because of it... I would totaly reccomend some mobile one gl-5 gear lube... or redline synthetic... there the 2 best brands out there!!! and remember these cars wernt made for fast shifting.. especially down to 1st!!!
Its not hard on it if you know how to heal-toe... first just try blipping the throttle befeore you (Gently Theses sync's are really slow) push it in gear
is your intake freezing?? THATS REALLY COLD BRRR.......
EA-82T Exhaust Leak...Vaccum Leaks... Where???
That would be cool... no rush of course... So... whats that do?
ea82T pcv question...
Yeah thats a definate sign of an oil sucker.. mines doing that too... It goes from the PCV and through the combustion chamber.... if its leaking... think of it as a vaccum leak... Thats metered air coming out of the crankcase.... If unmetered air (metered meaning... comes after the MAF) gets into the system your car can run like poo! If you see a little bit of oil in the intake, well, thats expected, but, if you see like.. alota oil... then youd better get a catchcan and plug all of your breathers into it!! Someone else can explain the pcv system more in depth... Just wanted to give you a quick synopsis and bad spelling to boot!
Heres some pics I took after school... sorry there really really bad... I used my moms pocket pc/phone, aka piece of ********........... Click on em to makem bigger and one of em dissappeard ohwell...
The WTF is wrong with my wagon thread
I dont know if this will help but.. My car (when it had hewglymongous exhaust leaks) did the crappy when I floored it.... It would sumble... kinda like it was about to fall on its face... and then surge forth... but slowly at that... Not to menchin the amount of fuel this thing was using... So i would check for Haust leaks either before the turbo.. or before the 02 sensor... hope it helps!!!
Southwest Subaru meet 2/15/07 MLK jr weekend
My car gets better and then gets poopier.... not to menchin... Im running severly low in the funds department... ive got to get a job!!!!
