Everything posted by zukiru
my free 92 sedan.
So it's all ready! Tick has been all gone for a bit now and fuel mileage is improved with the CEL off. (even if it's a cheat) Oh and the freaking AC works! Next thing i want to do is fix the sloppy shifter and put in a CD player with AUX port. (so i can listen to my nerdy podcasts without an fm transmitter) Soon i will post my 88 xt that is getting an EJ (hopefully frankenmotor) now that I'm not daily diving it.
TomRHere's '88 GL 4WD Wagon
That was a great read. Wish you had a bigger pic of the over all wagon
- My 1986 Subaru GL-10
1990 Loyale. Has spark and fuel, crank no start
You said you tested the cool and igniter.. But. I had a bad distributor in my 86 XTDL it had spark. But it was too weak to make the car start. Edit... Nevermind you swapped the distributor.
my free 92 sedan.
Egr solenoid. I got the light out by wiring in a solenoid that works but has a nipple broken.
my free 92 sedan.
Fuel filter looks new, but i am going to replace it. Found the codes list for 87+ spfi cars today so now i know what I'm looking for.
'13 Subaru BRZ Limited
^^^ what's Opti-coat?
my free 92 sedan.
Okay. So I'm at a bit of a dead end with the "sedamn" It still has the tick but I'm okay with it... ill get it eventually. But it has a CEL and I am not sure if it has the same check process as the XT. The other issue is it seems to like gasoline a lot more than the xt. Are spfi cars less fuel efficient? I have like no experience with the throttle injectio... should I rebuld the TB? How do I know it needs rebuilt? Thanks.
You're just jealous. And so am i. Freaking hot car!
my free 92 sedan.
Thanks!
Lifted Imp: The Swag Wag
The zebra fender is a hoot! Lifted imps are neat.
my free 92 sedan.
its clean. But the picture looks a bit better than the truth.
- My 2003 Subaru Baja
my free 92 sedan.
Haven't been on here much. The new mobile site is interesting. Thanks for the replies. I almost feel bad for the previous owners... but I guess knowledge is power in this case. I had it diagnosed and repaired in a matter of a couple hours.
my free 92 sedan.
5 speed! The only way to fly!
my free 92 sedan.
To make a long story short my uncle towed it in over a timing belt. They let him have it, cheap. And i got it for the scrap from a very worn ouT XT. one belt and a quart ATF (to stop the ticking), and I have a new daily driver.
Too Much? 86 EA81 hatch questions.
Wow. Looks clean!
RIP 3door, I'll miss you...
Man. That looks like it was a nice car too... My condolences
- Center caps for 86 brat different then 86gl hatch?
Motor oils and brands
I work at an oil change center. we use valvoline oil. I am currently using Valvoline Max life 5w30 and a vo33 filter. next change I am going to run 0-20 maxlife. I am interested to see if I get the propsed 4-5 percent better MPG. and if I have any issues I can drain it and go back... having a pit I can use at any time is nice.
I'm back in it.....my '84 Brat
I wish i had a head for all this transmission lingo. You make it sound easy. Like playing with LEGO... Subscribed. What did the front lsd set you back?
ej25 nat update
zukiru replied to subarurx yo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsometimes it's fun to just do things the wrong way and let it hold together as long as it will have fun, blow the sucker up and... have somebody ready to tow it
Looking for EA82T megasquirt base map.
I have one i was emailed. But i have to find it. Might have time to look Sunday.
ej25 nat update
zukiru replied to subarurx yo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice! Got pics of this car/Monster motor?
Differences between 4WD and 2WD EA82 struts
2wd xt front struts make the front sit lower than wagon struts., that's all i know from experience.
