Everything posted by subaru360
Should I Attempt an Engine Swap?
subaru360 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup the intake manifold. It's shaped kind of like an M. Tie one end of your strap to each front runner. It will balance nicely like that as you pull it or drop it.
Repair or part-out mint 93 Legacy??
What I usually do for a hit like that is repair the innner fender in front of the strut tower as best as possible by pulling and hammer and dolly work. Then I drill out all the spot welds and replace the core support or possibly looking at your pic just the upper bar of the core support. It looks like that hit was above the frame rail so it should be an easy fix. Being an older car, you don't have to do show quality work on the inner structure either, just get it straight enough to bolt on the fender. Good luck!
That looks fixable to me. Cut the inner structure from a junkyard car. Drill out the spotwelds, weld in what's needed, some used lights hood and fender and you're back on the road. I don't know if it's worth it thought, you could probably buy another one just like it for less than $1000.
*..Cost for rebuilding a Transmission?..*
subaru360 replied to bakerman1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's on the passenger side of the engine compartment towards the rear. It's not in a fuse bluck, it's just a single fuse holder, it will say "FWD" on the cover.
subaru360 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJack under the trans for sure. But the pitch stopper on an EJ bolts to the trans, so that's not going to work too well:) Best way to do it is a strap tied to the intake runners one on each side.
subaru360 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll find it's easier to swap engines on a subie than a chevy. There's only two vacum hoses and 3 electrical plugs to unplug to pull the engine. You can just unbolt the p/s and the a/c and put them off to the side, no need to disconnect the lines. To pull it tie a strap (I use an old seatbelt) to the intake runners, one on each side.
How does this sale sound?
subaru360 replied to EYE_WHY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome tapping is normal. It could need the valves adjusted, 2000 should be solid lifters. A little cold piston slap is normal too. Sometimes on those the timing belt tensioner goes bad and makes a knocking noise. If you are still considering the car take it to somebody who can tell you if it's a "normal" subaru noise or something going bad.
subaru360 replied to EYE_WHY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is a fair price. The one owner older people thing is good too.
EJ engine weight
subaru360 replied to subaru360's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I'm guessing it would work out ok. I might get one of those little trailers or the carrier, I'm deciding. I like the carrier idea, with the grate on the bottom I could stop at the car wash on the way back from the junkyard and pressure wash the engines there and keep the mess at home to a minimum. But the small trailer could haul my 360 around as well as engines. I've already got a big car hauler trailer but it's a lot to take out just to haul one engine or the 360.
EJ engine weight
Does anyone know how much a complete EJ engine weighs without acessories? I'm thinking like 300 lbs or so. It can't be that much, I can lift one myself if I really try. I haul them around a lot and was thinking of getting one of those hitch mounted carriers so I don't have to put greasy junkyard engines inside my suburban anymore. Harbor Freight has them on sale now 500 lb capacity $57.
boston area HG repair
subaru360 replied to telemarkskier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah a shop is not necessarily doing a bad job if they don't mill the heads. If they measure them and the block and all is well it's ok to put it back together. If you read the factory manual and the endwrench articles on head gaskets, they say to measure them for straightness and even show a pic of how it should look when cleaned up. You don't need to get it shiny new clean, that's actually bad, since you are removing material, which can give you low spots. The originals fail because the material they used is no good. You can see where the gasket material pushes out into the water jacket under the cylinders. The latest MLS ones are great. A MLS gasket can't fail in the way the originals did. I don't have any with 100,000 miles on them, but I know some have maybe 20,000 on them so far no problems.
subaru360 replied to telemarkskier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is nothing wrong with just replacing the gaskets. You need to check the heads for warpage with a straightedege and a feeler gauge and inspect the block and head surface for any damage. If they aren't warped or damaged, they don't need to be milled. I have done tons of HG's without milling the heads and have never had a repeat failure.
subaru360 replied to bakerman1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it really is a transmission going bad, on an older impreza, used is a better choice. Get one from a junkyard. Most of them will give you a 30 day warranty. It shouldn't be more than a few hundred. Shop for one on http://www.car-part.com
Carlisle show May 16-18 2008
I registered with my 360. I might bring the WRX too, not sure yet, I'd need to put a trailer hitch on it first to pull the 360.
1998 is the price to outragous
subaru360 replied to xr2guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's way way too high. Is this just a plain legacy not an outback, gt or lsi? Even with the low miles it's worth 5,000 tops.
Looking To Buy An Impreza
subaru360 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah search out the best deals. Try posting wanted ads with what you want and what you have to spend. That's how I found my wrx. It wasn't much more than that impreza you looked at either.
Looking for reputable Sub mechanic
subaru360 replied to Mtnrider9800's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNext step is a compression test. If that checks out, you should test the injectors.
subaru360 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt seems like a good car. The previous owner probably took care of it. I wouldn't pay that much, but I'm cheap, it's not a bad price really.
Locked out of Legacy
subaru360 replied to SOOBOUTLAW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI pull the glass back and use a coat hanger to hit the power lock button. I've done it many times. I have a few slim jims, but they don't work well on Subaru doors.
How do I pull the trany easily @Junk Yard???
subaru360 replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its an auto it's tough to get it out the top with the engine, but it can be done. Five speed comes out the top with the engine ok. My favorite yard has all the cars sitting on stands. They don't allow any jacks in the yard, but you can rent a big hoist on wheels. To get a trans I usually unbolt everything, then grab a tire and put it under the trans. Slide the trans off the studs onto the tire, pull the tire out and then drag the trans out from under the car. It's a dirty messy job, but I can get a trans cheap so it's worth it. Pulling junkyard engines is much easier, I have it down to about an hour now.
EJ22T back together, in the car, now no spark :(
Looking at that wiring, I think that is where your problem is. Off the top of my head, I think the broken conneector is the crank sensor and the other is several other engine sensors. You should fix that right and go from there. After the wiring repairs, check for continiuty with an ohm meter. It almost looks like you have the pins touching and shorted.
Look what we got
The seller somehow managed to take the pics so that the rust was all hidden in the shadows. The bottoms of the front fenders under the mudflaps were gone, I could lift the fenders up off the car. The lips of both rear quarters weren't there either. It looked awesome in the pics. Oh well.
Look what we got
I think I talked to the guy in pottstown about that one once. For some reason we didn't go look at it, I don't recall why.
To start with, does the tach go up when you crank it? That's a good first step. If you have a scan tool that can display sensor values that is an easy way to check. Or connect a voltmeter to the 2 wires off the sensors, set it to AC volts and see if it reads anything. Do you have fuel pressure and injector pulse?
Looks Like I'm Gonna Be An Impreza Owner...
subaru360 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should put some wrx wheels on that, it would look good with them and you can pick them up cheap on ebay, nasioc or craigslist. My 02 wrx came with a 6 disc changer with weather band, it's not bad, the previous owner said it was from a newer forrester.
