Everything posted by subaru360
96 Legacy 2.2 into 98 Legacy 2.2
subaru360 replied to kaki's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a straightforward remove and replace swap. No additional parts needed. Put the manual transmission flywheel on the new engine.
97 obw wont start after airbags deployed
subaru360 replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt bent all the valves. It's an interference engine. If the belt comes off, the valves hit the pistons.
ej22t
subaru360 replied to garbage's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgain, anyone can make a website or a post on one. How could the wrist pin be longer? They would hang out the side of the piston.
New STi!!!
It looks great. Wheels should be gold. Other than that about perfect. I HATED the 08-10 sti hatchback.
ej22t
subaru360 replied to garbage's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo some idiot made a website with bad info. I've had these engines apart side by side and they are the same. Same part numbers too. Go to the dealer and check if you doubt me. EJ22E and EJ22T take the same part number crank and rods.
ej22t
subaru360 replied to garbage's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, EJ22t rods and cranks are the same as EJ22e, EJ18 etc and the pistons are cast.
ej22t
subaru360 replied to garbage's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcast pistons 7.5:1 or so compression
99 Legacy Outback - Looking to buy - Worst Case Scenario?
subaru360 replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX00 up have headgasket issues also. They drip on the ground rather than leak externally.
subaru360 replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTorque bind. Check for it. Other than those 2 issues, the old outbacks are a good car.
outback/forester struts
Yes you can
Please help, no crank/no start!!!!!!!!!!!!
subaru360 replied to WickedV6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you jumper across the two terminals of the starter and see if it cranks? The starter contacts go bad often.
Yes they will lift it and yes they bolt in.
swapping newer seats into my 96 impreza
Yes, they bolt right in. They will sit about an inch or so higher. You might be able to swap the rails over to lower them
mixed up Akebono pads for impreza
subaru360 replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX471 is the rear
subaru360 replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX470 fits just about every ej subaru with single piston front calipers. Brake pad part numbers are industry standard, so that goes for any brand pads. They might add a few letters in there but the numbers will be the same.
98 Forester Rear Drum Brake Upgrade???
subaru360 replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you don't get the whole hub, you have to press the bearings on and off to swap the backing plates. That's why most swap the complete hub.
Sub-specific towing advice
subaru360 replied to canalligators's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll be fine. The car will handle it. I towed 1000 lbs with my wrx wagon all the time and it pulled and stopped well.
Re-visit EJ25 replacement with EJ22
subaru360 replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost of the sensors and wiring on the 90-94 engine are different.
Lightest EJ based soobie for wheeler ???
You'll be looking a long time for a 93 coupe, 95 was the first year for the 2 door. 95 impreza coupe is about as light as it gets. Mine was 2350 curb weight with 1.8 fwd. It had no abs and crank windows. It's still under 2500 lbs with EJ20G and awd. I removed AC, PS,radio, sound deadening, airbags, bumper beams, extra wiring, heat shields, splash guards, fender liners, everything in the trunk and more. My goal was to build the lightest awd impreza possible. I want to get it on a scale for an exact weight soon.
subaru360 replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX90-94 engines will not work.
Are the Heat Shield really necessary???
subaru360 replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've thrown them out on a few cars with no problems.
cross member broken bolt need help
subaru360 replied to juneballoon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLift the carpet and cut a hole in the floor with a hole saw to get at the welded nut.
Need ej25 to ej22 advice.
subaru360 replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes legacy too. 99 legacy 2.2 is a phase 2 engine.
subaru360 replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX95-98 2.2 automatic. 99 2.2 is a phase 2 engine.
I just scored a 93 Impreza for $200!!!
subaru360 replied to A DOG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo put a rear swaybar on a car that didn't have one, you need lateral links with mounting points for a swaybar, swaybar mounting brackets, bushings, bushing clamps, endlinks and the bar. You do not have to change the subframe.
