CNY_Dave
5
Everything posted by CNY_Dave
There is a preload washer/shim (or several) that goes onto the back of the clutch to set preload on the 4EATs up to '04, if this trans has that setup also it could be the thickness is too great. (The shimming is used so with no pressure the clutch doesn't drag, but not a lot of movement and it's locked up) Here's a question or a few- Does it get worse in 1, 2, R? If you park but leave the shifter in N and shut off the gas, does the car lurch or act like some pent-up stress was suddenly released? I'll reiterate our '05 forester has the tightness you describe, has been that way for about 100,000 miles now (since we bought it used), if it just feels a little tight but doesn't lurch when making tight circles and there's no other ill effects, I would call it in the normal range.
The TCU can sense the connection is open or shorted to ground, usually either a broken wire or a wire pinched to ground rather than the solenoid itself.
- 9 replies
- AT Oil Temp
- Legacy
(and 1 more)
Tagged with:
Yep, both rear wheel ones go through there, they go down, go to a mounting/junction block, then one goes to rt wheel, one to the left. Probably the other one is ready to go to. My drivers side rear line went out, nothing usable all the way over to the connection at the control arm. I patched in new up top.
FWD light does not come on / FWD mode not engaged when trans has an error that causes the flashing. The fuse is ignored in that case.
- 9 replies
- AT Oil Temp
- Legacy
(and 1 more)
Tagged with:
The binding going away with the fuse could mean everything is normal except that the plates are gripping each other more than normal, due to previous mis-match tires or something. There is no feed back in the system, if the clutches 'stick' to each other 'better' than normal, it'll bind. Could also be plates are fine but clutch basket is grooved. We have an '05 forester X auto, the AWD is pretty tight on it, it fights parking lot turns just a little bit, has been that way since 35k miles or so, hasn't gotten worse now with about 130k.
Copper can work-harden if it can vibrate, can get brittle and break.
- 8 replies
- coolant linerust
- replacement
(and 3 more)
Tagged with:
