screwbaru2
Everything posted by screwbaru2
water out the EXAUST!!!??????
screwbaru2 replied to GREENSUBIE's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you had the head checked for cracks? Sounds like the water jacket is opened to the exhaust. -
I think it may be federal law. Like the $10,000. fine for messin with the cats. I know in RI the only way I can get a used cat is to buy the whole car. Can you get the crack welded or brazed? That maybe your best bet to get past inspection.
I like the look of the red car and its more areodynamic! Give ya that edge:lol:
Chevy Small Block questions
screwbaru2 replied to [HTi]Johnson's topic in Non Soob Cars and Bikes Discussion
I do miss those V8's and the bigger ones too 427 ..... Lots of torque @ low RPM's the exhaust is like music:burnout: -
The sensors job is to tell the ecm when the engine is pinging/knocking. The ecm retards the timing until the sensor stops sending the signal. If the sensor is bad (open) then it doesn't signal the ecm and the engine pings/knocks. So yes to your question except it doesn't make the engine knock it lets it knocks. Also I used a bosh knock sensor on the 99 imp seems to be working fine. Make sure the angle is correct on installation it does make a difference.
Sorry I get automotive dislexya somtimes with open and closed loop. It seems like his problem started after the plugs and wires where installed. I know it drove me crazy the 1st time it happened to me. Seems like the new gen engines are fussy. The older soobs I had used aftermarket without problems.
Yeah like he said -
Old gas - what really happens?
screwbaru2 replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I know the one year I did not use stabilizer in my lawnmower I had to flush the gas out and refill it before it would start. I kept gas for over a year in a 55 gal drum buried in the ground (don't ask) with stabilizer in it with no problems. Good article Nipper. -
If you have the buckets and enough AT fluid you can flush it by putting a hose on the return (lower) side of the AT cooler in the rad the other end in a large bucket. Run the engine and keep pouring fluid in the the trans until it comes out clean. Keep up with the flow, don't run it dry. Helps to have 2 people.
Gary, I'm half joking about being confused. You give good advice and I appreciate it. I'm focused on my Outback now, if by Sat night it looks like it's not going to happen then I'll turn to the TB'd Impreza and cut that wire. I'm not big on servicing ATs. When it comes to ATs I usually just replace em. Thanks, Jordan
