Everything posted by EVOthis
yes... you can check the inner and outer tie rod ends by either a doing a dry park test or by jacking up the front end of the car and grasping the tire at 3 and 9 oclock and try to move the tire back and forth and feel/look for excessive play in that area....the dry park test is simple...if you have access to a rack type lift you can drive the car up on the rack and get an assistant to sit in there....raise the vehicle and have the assistant just rock the steering wheel back and forth slightly and look /feel for play at the tie rods that way. I know my steering rack boot tore about 30k miles ago and i just started noticeing symptoms of a bad inner tie rod.....so i just got done replacing the inner and outer tie rod ends and the steering rack boots.....so my opinion would be that if nothing has any excessive play than i would just go ahead and throw the boots on.....than again the car does have alot of miles.......it might be worth it to do it all at once......good luck!
Hey WA....i was just looking over this post again and i saw were you said the viscous coupler was a sealed unit.....isnt the coupler surrounded by a think fluid?......if i were to replace the coupler how would i get the fluid back in there?....also you are refering to removing the tailshaft houseing NOT the transfer case houseing?....how do you tell which is which?....is one behind the other?......you seem like one of the right people to ask these questions too....you do answer the majority of my threads with knowledge.... again thanks for your help.
Rough idle
EVOthis replied to e4620's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
as a subaru tech im sure he did both of these.....but it doesnt hurt to double check..........make sure all lines, especially vacuum lines are hooked up and properly.....if you have a vacuum gauge i would run a quick vacuum test and see what youve got...did he set the valve clearances to spec? -
i have a 96 legacy and the only time my drivers side front window seals properly is when i close the door.....ex: if i were to put the window down while driving than put it back up you can def. hear the air and a small bit of seepage coming through ( i think its because our doors dont have a frame around the window)....i have a couple of buddies with subarus and they all have the same problem......i also have the window rattle when i close the door with the window partially down......it doesnt really seem to bother me at all but my guess is something is loose.........just my experience.....
