Numbchux
Everything posted by Numbchux
  1. Numbchux replied to singletrack's topic in Off Road
    I got this, as I've had the link bookmarked since he posted it... http://www.streetbeatcustoms.com/ragtopsunroofs.html don't remember what dimensions he went with, but I think I'll get one a bit longer so there's open air over my head.
  2. I'll be in duluth, possibly until turkey day...
  3. ah yes...I see that now.... essentially same motor, but have to find room for the turbo too...
  4. oh yea, and about the rad hoses. the passenger one is fine (little more strain, so if it's old and crispy, it might break, mine did....but it reaches fine), and the driver side one could be made fit. here's the deal: the two ports that need to be connected (tube from water pump on block, and radiator) actually get closer together, so you could trim the stock hose to fit, using the bend that's already in it. I found that when I did this, the hose had shrunk in the middle (220k miles and almost 20 yrs could do that), so I took the piece that I had cut almost exactly to size to NAPA, and told them I needed to replicate that, but a bit bigger diameter, and he looked in his book, and found something with a nice bend in it, I had to trim it too, but it worked perfectly. be creative, there's nothing too hard... also, about the pitch-stopper, maybe try a jack & wood block on the oil pan to tilt the whole thing back a bit, that's a trick someone suggested for changing the clutch (to align engine and tranny easier), I did it when I did my clutch, and didn't take the jack off until I had the pitch stopper back on. it worked fine!
  5. Numbchux replied to singletrack's topic in Off Road
    sweet! I'd like to do something like that (when I get my ragtop), unfortunately, bugs are a bigger problem than shade. I got this idea from my uncle, take mosquito netting, cut to the size and shape of the windows, and put refrigerator magnets on the sides. then you can roll down the windows some, and stick in the nets to keep the bugs out.... also, some sort of tent, maybe similar to that, but wider, that would allow you to get from the side doors, to the rear hatch, and stay dry...
  6. relatively common swap. check the retroffiting forum for more info, search around, there's lots of info here.
  7. my pitch stopper was fine.....don't know what's up there... there's a nut on the bottom of the shift linkage, that holds it to the unibody, the hole is actually slotted, loosen the nut, let it adjust for the extra length, then tighten it again. should work much better.
  8. +1 not to nock pkd, but AA is very fast, and in great touch, very easy to get ahold of/work with
  9. mine was seized, couldn't feel it with it in the car, but when I pulled it out to do a clutch job, I couldn't move either joint in the rear half, I replaced it and now the noise is reduced soooo much!!
  10. yea, that's the idea, but mine never worked (on either car) the only negative effect, seems to be the CEL
  11. I too would like to add my $.02 about the kits. QMan is very right, it's a high maintenence vehicle now. also, it is a bolt up install. I don't have the one piece tranny xmember/leading rod blocks, I still have 6 individual blocsk which were hard enough to install. also, make sure you have them on the right side, this is just a guess, maybe it's painfully obvious, but maybe not. if they're not ligning up at all, make sure you've got 'em on right. don't fret, it's a great kit, and quite easy to install, but some cars just work better than others. my engine crossmember shifted quite a bit while I was installing it, and those blocks where a total pain!!!
  12. Numbchux replied to lil_J's topic in Off Road
    check the Frequently Asked Questions (FAQ) section here in the offroad forum for information in the future, but since I know them off the top of my head... http://www.ozified.com (heard a rumor that he's not making kits anymore...) http://www.alliedarmament.com (it may not be listed there, but they can make all sorts of stuff, big personal recommendation here!) http://www.sjrlift.com (again, maybe not listed, but he's pretty versatile, I'm getting a part from him to make my lift bigger/better!) and look for mudrat79 here on the boards, mixed opinions amongst fellow members about his business rep, but he definately does great work!!
  13. not all d/r trannies are like that. I'm not sure of the exact cutoff, but my '88 had it on the tranny, and my '85 had it on the clutch pedal. I swapped 'em (the '85 had way fewer miles), and it works fine, just didn't plug it in. yea, my CEL is on, but all my cars have the CEL on. I'd be worried if it turned off! I'm going to try to attach the two wires, maybe that will get it to shut up.
  14. that sounds like a blast, I love alaska, and will be going back a number of times. unfortunately, I don't know how I'd be able to pull if off while I'm still in college. however, once I'm out, I'd love to do it!
  15. agreed, black wheels are sooooo hot!!
  16. Numbchux replied to Numbchux's topic in Off Road
    hmmm...this is a good idea, unfortunately they're mounted on my roof rack, pretty solid mount, but nothing above to mount the top to. and they'll be pretty much off-road only lights, so there'll be lots of vibration to worry about. maybe lower wattage might make them last longer?? we'll see this weekend!
  17. All EA82 Dl's came with dual headlights
  18. gound clearance is awesome, I know I've got better than virtually any vehicle out there. but suspension travel and flex is where it's at. those few inches of clearance aren't anything to the suspension travel associated with solid axles. our BIG advantage, is the point in the middle where the t-case is on those trucks, we have virtually nothing hanging below the unibody there, I have almost 20" of clearance at the "high-center" point.
  19. I really want to put in 4-point harnesses in my wagon. I get thrown around on the trail alot. and my gf is all for it! I'll probably buy some and see if I can make it work.
  20. Numbchux posted a topic in Off Road
    I have a pair of Hella 7" round lights in big ol' plastic cases for roof-mount. I got them from my uncle, and they're not wired at all. They're H4's with lo/high beams... 2 Q's...1. anyone know the wiring for them? I've got three contacts, and I'm not sure which is high, low, or ground. I could just try 'em, but I'd like to make sure I get it right. 2. would it be ok to run both filaments at the same time? I've got combo driving/fog lights on the front that I run both on at the same time, but they're individual bulbs, these are 2 filaments in the same bulb....would the heat be too much?
  21. GravelRX made a removable light bar...here's a couple pics from his photo gallery. do a search for posts by him, I know he's posted exactly how he did it.
  22. oops....I completely misread your post....yea...what shawn said
  23. HI EARL!!!!! sorry, I just couldn't resist
