Everything posted by Nug
EJ22 swap done........motor wont start........
Nug replied to ballitch's topic in Subaru Retrofitting
So the fuel pump comes on when you turn on the key, and stays on while cranking, right? And it has spark? Are your injectors firing? -
I'm gonna try my damnedest. Our new house is supposed to be done in the beginning of June, so theoretically, we should have sold our current house, blah, blah, blah. Tim, if I can't make it, that's no excuse for you not to go. Maybe you should go to Morgantown and pick up Trogdor!.
how hard???
Nug replied to TotallyCorupt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It would be a heck of a lot easier if you hold out and got one that was awd, instead of diving into the headache of swapping. Seriously. -
Somewhere between 90-94 or 95, the crank sensor changed. They are probably functionally identical, the difference is the later one has the connector on the sensor body, the earlier one having a 10" or so lead. I paid $200 for the early sensor on http://www.1stsubaruparts.com, and saw later sensors for a ridiculous fraction of that.
Meh. I may be moving, or homeless, or in some other turmoil that weekend. I'll keep you all posted.
Dyeing the motor oil is a good way to find hard-to-find leaks. They put a few ounces of flourescent dye that dissolves in your oil, and drive it around for a while. The dye is visable as a bright orange under ultraviolet light. If the smell persists, I'd go the dye route. I'd bet you have cam seals that are leaking. You can't tell unless you take the timing covers off, though.
That doesn't bother me, if I bring a friend, it may be an issue. Maybe I'll bring a tent.
Hey, can I sleep on someone's couch? If I'm driving out there, then I'm staying the whole weekend.
If I'm driving out there again, I gotta put a CD player and speakers in the RX. You can listen to your engine only for so long.
I saw the movie and thought, "I wonder how many threads will be started about that brat?"
Need Your Advice
Nug replied to Pegg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I use 15w-50 mobil one in a couple different generations of Subarus. -
Tina, get some ham!!!
Is Memorial Day weekend official?
You could run a stand-alone ignition controller, like MSD, to run the ignition. The fuel system would then be up to you.
