Everything posted by Craven
custom Y pipe layout pics.
LOOKING GOOD
Grease for rear wheel bearings
Use the red you have- not the black
how do i set the throttle position sensor?
SorryOk with a .31mm or .0122 feeler gauge between the throttle stop and the throttle lever. Rotate the tps switch untill you get continuity between pins a & b (the top 2 pins of the 4 on the switch plug). Tighten the adjustment bolts. When you open the throttle all the way, there should be no continuity.
After market clutch?
www.dialaclutch.com
www.ramclutches.com/Applications/subaru_2003.htm
ANOTHER Stage 1 question
You might want to give these guys a call. http://www.xpglass.com/
Just bolt it on and plug it in. Just aline the sensor with the shaft.
stage 1 question
Do you want to fix or replace? Try here.http://www.jcwhitney.com/autoparts/ProductDisplay/s-10101/storeId-10101/p-1201/c-10101/catalogId-10101
Ruh roh... broken intake manifold bolts... (ea71)
Thoughs bolt stubs are or would have been a good candidate for welding nuts to the stubs and they more than likely would have turned right out. Craven
Attn: Craven...
Look at you PM.
Have you tried L/H drills? I've used Helicoils before, after someone monged up the hole so bad you couldn't just tap new threads. Why would it do it again? If you use never-seize when you put it back togeather, there should be no problem. Craven
Speed Bleeders for old Subarus? (part numbers and pics added!)
Would rear disk brakes use the same S/B as the front? Craven
This is what I use, if I can't do the weld a nut on trick. trick.http://www.mytoolstore.com/hanson/hanson.html I've got this a set. Craven
I need tail light cluster
Got one of thoughs too.
That my friend is why you try everything and anything but an e-z out. Now your stuck with a piece of hardened steel in the hole, that you can't drill through.
Im gonna need parts for an 86 gl coupe?!?!?!?!?!
Do you have any pics. of the damage from this little FUPA. If the hatch won't close you might have some major structural damage. I've got a very nice door and quarter glass, but shipping would killer.
By the way it sounds, you need more than just parts.
El Junkyardo
Some yards are like that. They think all their stuff is made of gold. Then others just want to move the parts and you can get great deals. Then sometimes it depends on the day, could be good one day and s**t city the next.
whats the best paint to use?
If it were me, I'd give this stuff a try. http://www.autobarn.net/heruvtopprot.html?AID=10274001&PID=613288 You might be able to find it local at a parts store, that sells HERCULINER products. Craven
- Hello
help! leaking engine block '84 brat
Didn't you say that your mechanic had replaced all the seals and stuff? Sounds like the valve cover gaskets are leaking, easy fix less than $10 in parts. Find yourself a real mechanic. Could you post some pics. of this crack, your talking about? Craven
Sometimes I feel I'm being ignored.
Fiberglass Brat tailgates, OH YA
6 X 140 rims, what make/model have em?
Ya forgot about the wagoneer wheels. Has any seen or used the 15x7 alloy wheels on a soob?
Older Monteros have 6lug wheels, some of which are real sweet looking. But I think they are 15"
Chevy/GMC 1/2 ton 4x4, Dodge D50
