Everything posted by kevinsUBARU
How to buy a used Subaru?
kevinsUBARU replied to nhruby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe 95 Legacy definately has a 2.2 regardless of trim line. good luck with the purchase!
Hello iPod users?
kevinsUBARU replied to Griffin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis is exactly what you are looking for....no FM transmitter and YOU can make it after a quick trip to Radio Shack Eventhough it is written for an XT it should also work for you....read and then decide if it's worth it. iPod Solution That being said, I use a McAlly FM Transmitter for my iPod (aftermarket CD player/radio)
Valvoline...
kevinsUBARU replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the past 4 times I have changed my oil I have used the $14 rebate form. I get 5 quarts of MaxLife and 1 Purlator PL14460. It seems like decent oil, and the price is right
05 Legacy Wagon GT-180˚ - Help!
kevinsUBARU replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe funniest part of your post is the quote: "your vehicle was checked out and they were unable to duplicate your incident"
Running leaded gas in my Subie (Nicaragua)
what is the estimated round trip mileage?
can foggy headlight lens be cleaned?
kevinsUBARU replied to aa8jz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi It's been covered before, a quick search found what you're looking for. Now read it and clean them up! CLICK ME Kevin
Subaru body and rust--help me dispell myth
kevinsUBARU replied to swordsmanrex's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCardinaA: Syracuse made my 1995 Impreza start to rust as well. I lived there the past two years and have cancer spots on the rear wheel wells as well. They use so much salt in the "Salt City" its insane! There were times my car would be white with a hint of green. That rubber "protective strip" is definately the problem...it trapped all sorts of crap under it and just started eatin' away!!! I meanm it's not like my car is going to rust apart, but it's still rust. Now my girlfriends 91 Camry...wow, Syracuse made it get more cancer than the Marlboro man!
Clunk when car starts
kevinsUBARU replied to bluecar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it do it every time you start it or just sometimes? If it does it all the time, did it ever just do it sometimes before progressing into a worse condition? Do you ever start it smoothly, drive somewhere, shut car off for 10 minutes or so, then have it clunk upon restart? This is very interesting.
Brake Parts
kevinsUBARU replied to Smpol19's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust word on the street from what I've heard, but don't waste your time with EBC pads...rotors are ok, but don't get the pads.
Forester rear accessory socket
edit: nevermind
95 Impreza: Front Differential Drain Plug/Washer question
kevinsUBARU replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgreat! thanks for the help. Kevin
kevinsUBARU replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXanyone?
Hey all I finally have time today and I really need to change my front differential oil (95 Impreza AWD automatic). I did some searching and am getting different results on if a crush washer is used on the differential drain plug. The owners manual says to use one, scooby mods doesn't say, and an old thread on here said that a non-crush washer was used from the factory. So the question of the day: Is a crush washer used on the front differential drain plug, and if so, what size! Thank you for your speedy responses! Kevin
i found a 98 forester 150,000mi
kevinsUBARU replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXApproximately $5000 with the limited information you provided. Since it is at a dealer, they will probably be asking $6,500 or somewhere around there. Kevin
Chains on WRX Wagon
kevinsUBARU replied to SubaruAl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXread your owners manual Kevin
Engine won't turn over - 99 OBW
kevinsUBARU replied to burke615's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo make your car run you need air, fuel, and spark. My guess is that your spark is the missing link, and I think your plugs might need replacing. Good luck! Kevin
Need Help with Fuel Filter 2004 Outback
kevinsUBARU replied to pollyavis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you go buy one, you can see what it looks like, then it's just a matter of out with the old and in with the new
wiper assembly problem
kevinsUBARU replied to vman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy guess would be that the linkage joint between the motor and the wiper linkage is broken. I believe the motor is on the passenger side firewall and you would be able to check there first of all. The black plastic tray at the bottom of the windshield can be pulled out with some grunt (usually) and that is how you can access the linkage assembly. Good luck! Kevin
Dodge rims that fit my 98 GT
kevinsUBARU replied to Glenner55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcool, keep us updated
Loading Forester with a fork lift?
kevinsUBARU replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXload ratings are for wussies
First DIY Coolant Change
kevinsUBARU replied to JohnnyB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks what did you do with the old stuff (assuming you use a mixture and not pure water)
kevinsUBARU replied to JohnnyB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo did you do this yet? If you did, I would like to know how you made out, where you got the hoses, ballpark $$, and where Setright's coolant filling instructions are located. whewwwww that was a lot! Thank you Kevin
Technical Service Bulletins
kevinsUBARU replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.endwrench.com
How to modify the new 1.6TS impreza for better mileage?
kevinsUBARU replied to GCGOH's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor starters, you can't be getting horrible mileage with a 1.6L engine! I'm curious as to what you are currently getting. I'm pretty sure yours is FWDand it and not AWD...can you confirm? I did some research and found that you should be getting an average of about 8.2l/per 100km which translates into approx 31mpg. A low for you should be around 23mpg and a high of about 36mpg! Kevin
Check out this ROO!
Doesn't Billy C. have the same car in the same color with the same mods, and doesn't he live in Duluth, GA? For those not in the know, Billy C. was one of the people who started this whole Subaru message board thing way back when...
