10
Everything posted by ivans imports
Even with all the right tools for the job is very hard every time I hate this job and do alot a 3/4 impact helps and a kent moore hub remover installer tool kitt helps also a 20 ton press and berring knife. It cost 350 $ + for me to change that berring if I can get the bolts out for trailing arms and knukle bolt. This is #1 on my not favort jobs list
simple and carb Did you say that ! lol darn carbs no o2 to tune them. CFM wise a 350 -450 cfm carb about right a square bore carb. They make tbi units now that ecu injectors sensers all part of the tbi unit thats made to look like stock carb
Yes machine heads when i surface them there is always a low spot on bottom of heads you can realy see how bad they are when i take the first cutt
- 17 replies
- baja
- timing belt
(and 2 more)
Tagged with:
change valves surface heads good to go carfull to not drag out the torque converter when pulling engine likes to stick to back of engine i hold it back with screwdriver thru axsess hole on ps top of block
- 17 replies
- baja
- timing belt
(and 2 more)
Tagged with:
have a 05 forester motor 1500$ 200psi comp on all four and 20 heads if need parts. changing valves is not a waste of time if engine was in good nick but change or check them all before reinstall. Is not mutch saved time doing heads in car it takes me 22 minutes to pull motor and engine can be put on engine stand and can be rotated to help geting heads off. Installing heads in car not mutch fun
- 17 replies
- baja
- timing belt
(and 2 more)
Tagged with:
why not use gm tbi unit from some kinda v8 or v6 give it signal from ej s injector pulse and try that out
Newbie in Canada
ivans imports replied to rhubarbray's topic in Meet n' Greet. Your USMB Welcome Center
Subarus are addictive soon you will want more and more subarus till your yard is full of them lol ! -
No will not fitt totaly different units A delay into gear is a very commen problem have a few that have been doing this for 5 years or better one thats been doing it for 150000kms no problems. Give it time to warm up helps and try changing the screwon fillter on side of trans use a subaru fillter as it has a anti drainback valve biult in
Had a forester with a water bubble hanging around the pump screen made a nice pocket around the pu screen and whould not let feul into pump. '" it keeps surging but gets better when i turn " the pocket that pump sits in if crap gets in is very hard for it to get out. Try somthing simple like a bottle of gasline anti freeze
I use the felpro one as they are slightly thicker witch acomadates the head surfacing better i find the subaru ones are very thin and after planing makes the piston very close to head. as far as longevity they all seem to last the same i glue mine with avionic form a gasket to insalate the gasket from heat and coolant. This works well i never install them dry. I have tryed all kinds of gaskets none seem any better than the rest as far as holding up.
1990 Loyale: some sort of electrical short
ivans imports replied to jasonkaye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Clean up ground on coil braket add extra wire from - post to coil braket add extra ground wire from - termanal to block / intake check main fuseabble links and link box feed wire no ground at coil = no spark/ feul pulse- 15 replies
- loyale
- electrical
(and 1 more)
Tagged with:
