Everything posted by ivans imports
My new redonkulous project idea
has all lights all plastics very good tailgate extra front fenders rear seats front seats and no kms on running gear
- 79 GL Wagon front end crunch-need some parts
2002 outback engine swap
ivans imports replied to vremeika's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWrong engine !
Replace this seal while I can?
Yes it should be split and yes if its apart change it make shure the converter seats properly and set the seals in place with some vasoline to keep them from geting torn on way in
ivans imports replied to vremeika's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope deul cam dosent interchange with single cam in those years can o worms need a 2.51 / 2.53 99-05 or 2.2 99-02 must be single cam phase 2 engine
Cleaning TPS on '91 Loyale
leave tps alone not a thing to mess with
symptoms of dead or dying ecu / ecm - 1984 ea81t
any luck ?
Am I the only one who
just putt a 2.2 in a chaser yesterday i used the overflow from a 91 legacy on the 81 rad worked well had to make a simple bracket and rad stays full and overflow stays at half. Sounds like pluged rad check if bottom half is getting hot when at full temp fan on.
2000 motor swap questions
Make shure you check for cracked or droped guides when doing valves
I whould use all managment from old engine cam gears crank gear intake ect then you know its a match take very little time to swap I always leave the intake atached to car never undoo feul lines and just flop intake over to ds put atowel down to keep from chiping fender
Dude have the exact brat here has 22000 kms on it same coulor ect 100 % compleate very clean just rusty floor 1000$ ligit regie runs good needs restoration
GUYS,,I need help Part 2 (photos)
ivans imports replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrive by wire boooo hurry up and wait for engine to catch up !
hitachi carb - issues after partial rebuild
have you changed the rear feul fiilter ? and try bolwing some compressed air back thru the rear line into tank mabee sock intank is pluged carfull a little bitt of air is all or can damage tank and spray gas make shure cap is off and a rag loosly over filler hole. Is funny no screen must have been removed from carb
whistling sound
ivans imports replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe louder it is the srtonger the engine is its a good thing THE WHISTLING OF POWER anyway is totaly normal opp
1988 EA82 no spark
Subaru # 233 fixed lol have been giving subarus #bers to keep better track of fix's
Crank but will not start
ivans imports replied to iransom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtiming belt striped the teeth on the crank sprocket
ivans imports replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMust use marks on belt or count teeth have lined up marks on belt and cams dident point at the spot i expected them to all about the tooth count.
Outback 5MT reverse switch
ivans imports replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon top of bell housing is two small two wire plugs one grey one brown one is reverse light other is neutral switch unplug them when in reverse when lights go out got the right one
EA71 Electronic Distributor
Have a few electronic diss for ea71s came on 78 and up but bow wow sells a points to electronic upgrade for vw vans whould work was about 60 $ if i remember right and was a generic kit
Can I?
Better putt some turbo pistons in it first ask me why.
89 XT GL - 4WD actuator hoses unplugged from ?
I try to avoid useing the vacume line for regulator for anything but that is sensitve to changes in vacume ect it sould be direct to fuel reg no tees. Or you get rise in feul pershure when heater or 4x4 is turned on
redrilling bellhousing
4 10/1.25 studs work well have done about 25 addaptor plates now no problems the two 10/1.25 studs come very close to eachother but do not touch eachother but is very tight to tap but doabble. And have never had a stud pull out as long as i tap it shallow
- Carburetor issues
Used power steering pump
ivans imports replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDealer sells a reseal kit for pumps is fairly cheap and takes about 20 min to install the most important is the shaft seal is last part in pump but were most leak
SUBARU hood emblem location?
can look on my brat mine is installed sitting in the glove box lol but i think about 3 inch up on ds
