Everything posted by Dee2
Front Axles
If you haven't done this before watch the videos on how to do it. There are also many historical posts from people who have done it many times. A search should pull them up.
This part, the Y pipe bolts into it, can I remove it?
I doubt the backside of that flange looks like the front side. The exhaust pipe won't mate well.
Cranks and wont start
Glad to hear you found the problem. If it was idling correctly before the belt slippage and the belts were replaced, it's possible they are off by one tooth. Double, triple recheck positioning of cam sprockets.
Weird intermittent CTS problem - solved
Intermittent problems can be a nightmare. Finding something as vague as turning a plug connector around is nothing short of amazing..... Hope that solves it permanently....
- EA81 Unsolvable steering wheel shake
So you have spark at the coil but not at the plug. That would indicate a problem in your distributor. When you get a chance open the distributor and have a looky-see to find out if anything is broken. A failure of something inside could cause an engine to suddenly stop running. Maybe the wire from the coil to the distributor is not seated and secure. Check the continuity of that wire and if it is seated correctly. Sometimes it's just a simple thing....
So, it's likely an electrical problem. I would start at the plugs. You may already have done this but do you have spark at the plugs ?
If it died suddenly with no other issues, it is likely an electrical problem. If it did a little hurt dance and then died it is likely a fuel problem.
ECU BLOWN? Cranks but no power?
Look at the wiring diagrams and find out what is common to all the things not working. From what you've described, it does sound like a fusible link failure. How did you check the fusible links ?
CEL and rough idle when pointed downhill
check for codes
EA82 timing driving me crazy
--clean , sharpen and regap the spark plugs maybe replace plug wires --check air filter and intake for mouse denris --check and clean contacts on distributor --check for vacuum leaks
Gas shooting out the filler.
You may have something clogging the fill tube.... I'm not sure how to safely inspect that. Perhaps a thin, long, wooden dowel ? Or, remove the fill tube from the tank then inspect it.
I never heard of a tank puking gas. Check to make sure the tank is not leaking. Gurgling may be from a worn out gas cap and it would be cheap to replace it with a new one to see if that solves your problem. good luck.
84 gl runs great then dies after short run time
delete
new axles but I still have noise
Clicking noise is a sure sign of a bad axle joint. If they are new, then perhaps they weren't torqued down properly. Sometimes, after driving for a while, they need to be re-torqued. I would check to make sure the torque is correct. Sometimes they have to be slightly over torqued.
What kind of noise ? grinding ? clicking? squealing ? once ? continuous ? anything's possible.
Loyale 1992 engine code diagnostic how-to?
https://www.2carpros.com/articles/subaru-diagnostic-trouble-code-definitions-1987-1994-obd1-with-code-gathering
- Ea82 alternator alignment.
Fuel pump continuous prime/primes when turned off.
You may have a faulty fuel pump ...(?) You may have a faulty fuel pump relay...(?) You may have a faulty fuel pressure regulator ...(?) I would check to make sure there is fuel getting to the engine.
That looks correct. Below is a picture of mine. As I recall, at one point I lengthened the slot on the rear bracket on the AC so the AC could be pushed away from the alternator. This made more room for the alternator. You may need to do something like that if you can't find a belt to work. If you're not using the full length of the slot now, then the AC belt may be too short pulling the AC too close to the alternator.
1990 Loyale
Check the battery cable connections. Might just need cleaning or ??
loyale no spark
It would be worth taking it in and having it tested.....
