idosubaru
338
Just bought a 1982 GL Wagon 47,000 actual miles!
idosubaru replied to randy803's topic in Old Gen.: 80's GL/DL/XT/Loyales...
post what engine you have, either EA81 or EA82 and also carbbed or fuel injected. some of us are only familiar with FI engines like myself so i can't help you out as i believe yours is carb but i dont' know when or what models have carb. if it's like the fuel injected (FI) cars then it's by the passegers side rear wheel, crawl under the car and you'll see it mounted up underneath there. but again, i don't know the carbed vehicles at all. -
welcome aboard. check out the search function. above is a button, click on "Search". find most things you want in no time, here's a link to one i found with the search button. http://www.ultimatesubaru.org/forum/showthread.php?t=51970&highlight=parts click on that link and scroll to the bottom of the page as well, below the posts. you'll see links to related threads about parts, should have anything and everything you want in no time.
what are the 2.2 in EA bodies getting for gas mileage?
idosubaru replied to idosubaru's topic in Subaru Retrofitting
ah, that's pretty good. i only get a tad better than that on all highway driving in my impreza all tuned up. i was wondering if the impreza gas mileage is body design, weight, gearing or engine related. or combo.... i bet it'd get good mileage in an XT frame/trans. what trans do you have in there? -
has it always done this since getting the tires 6 months ago or started some time after getting the tires? i'd have the tires balanced. the place that installed them may do it for free. you can even check yourself, look at the outside and backside of each wheel and see if you can see balancing weights or a spot where there "used" to be a balancing weight. one may have fallen off. hard to tell visually because old ones may have left marks and there might not be many....but a visual check can sometimes show something. take it and they can check for you. if you've been off road or hit any potholes, any kind of hard hits like that, it's more likely to happen. if you are feeling it in the "floor" so to speak then it's likely a bad ujoint. unfortuantely unless they are near failure the ujoint problems i've seen can not be diagnosed unless the driveshaft it actually removed from the car. they'll be seized, lots of slop or very lumpy....the seized and very lumpy variety failures are diffiuclt if not impossible to diagnose on the car. that being said....on this new of a vehicle i'd suspect something very strange to be at work here. can't imagine a bad u-joint this soon.
tierods ?
idosubaru replied to Subaru in the Rainfroest's topic in Old Gen.: 80's GL/DL/XT/Loyales...
stock size is the only option that i know of. but new, not used. at 20 years old the stock ones have seen better days. did you hit anything to bend it? -
GL/Loyale 4EAT Problems... Where Is The TCU???
idosubaru replied to NorthWet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds like it's in the same position as the XT6 TCU, probably alot of the EA82, if not all are located there. glad it's going away...hopefully the new fluids does the trick. -
Ok, give it up, someone has it...
idosubaru replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
can you use a flexplate off the car you're trying to match as a template? -
check for spark at the coil now. keep working your way "back" so to speak. no spark at plug, now narrow it down even further. if your coil is sparking then your problem is between the coil and plug (wires, distributor, cap, rotor, t-belt). if the coil is not sparking then all of those items are ruled out....with the exception of the CAS in the distributor *maybe*. this will help us help you, let us know what you get. just ground the coil wire like you did when you tested the plug wire. guesses: ECU, transistor under the coil, and the coil are common issues. got another coil and transistor to swap in (quick and easy test)? any recent work done, attempted jumping of the battery, motor get wet?
Any thoughts on seat swaps?
idosubaru replied to eponodyne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds reasonable. i'd probably look into subaru options, they might be easier to swap around. -
if they are not subaru OEM spark plug wires, then get another set. i've seen brand new off-the-shelf spark plug wires from auto parts stores cause cylinder mis-fire codes exactly as you say. the newer EJ motors like you have are not forgiving at all. stick with OEM Subaru only spark plug wires. you can attempt to test this by swapping ignition wires around. clear the code, then swap the bad #2 ignition wire with your #1 cylinder. if the code comes up next as a #1 cyilnder misfire then you definitely isolated the wire as the cause. even if it stays at #2 though it could still be wire related but much less likely. i'd swap in a coil pack before an ECM. both can be had cheaply on here or at a junk yard. call and search around, i was looking for an EA82 ECM and saw the prices range from $35 - $609 for USED ones. i took the $35 route.
Any interest in a lift kit group buy???
idosubaru replied to Shadyirishmen's topic in Products for your Subaru
+1 XT6 lift kit! (i know...ha ha ha on me) -
Drove on rim for 26 miles.. problems??
idosubaru replied to kylecoyote's topic in Old Gen.: 80's GL/DL/XT/Loyales...
someone slashed 3 of my tires in my 88 XT years ago. this was in highschool before i knew anything about cars. i drove to my parents house 25 miles at about the same, no more than 30 mph tops. the tires eventually came off the rim. made it home, got new tires and all was well. drove the car a few more years after that into college and never had any problems with it. didn't even bend the rims. stock steel wheels with hubcaps as opposed to aluminum i guess prevented them from bending. -
great cars, great motor. it is old so the air suspension is for sure the first thing to worry about. look to convert to coil over if you like to keep things simple, cheap and reliable. the turbo has oil and coolant lines to it. that's fine....except when they leak that basically pumps oil and coolant away from the motor. i'd replace any related clamps, hoses or o-rings first thing. the head gaskets are the first things to go. at this age/mileage the turbo's put too much stress on the motor to take any overheating or negligence in the maintenance department. at 20 years old it's very easy for the car to have been overheated or driven hot at least once...not good on 20 year old head gaskets. some tips of checking for head gasket issues - look under the oil cap for a milky type substance, start the car up when cold and see if any coolant/water blows out the exhaust pipe. see if there's any oil in the over flow tank. run it for awhile and make sure it doesn't overheat at all. after it's warmed up, get out of the car, pop the hood and see if any bubbles are coming out of the overflow tank. bubbling is bad. check to see if there are any new cooling system parts - radiator, water pump, hoses. i'd buy the car even with bad headgaskets, but i'd like to know before i start talking price.
first - completely ignore the passengers side cam, this is a two step process. install each belt indepently, not both at the same time. line up the MIDDLE of the three marks you're talking about. line up the drivers side cam - install the drivers side belt. once that step is complete, then start thinking about the passengers side belt. rotate the crank shaft one complete revolution (360 degrees) and bring the same middle mark to line up again on the bellhousing. now line up the passengers side cam and install that timing belt. once you're done you'll notice that each belt is 180 degrees off from the other. when one cam mark is down, the other is up. if they are both up or both down, it is wrong. rotate the engine around at least one time and check that both belts are lined up dead on before continuing. no point in putting everything back together if it's one tooth off, which is easy to do.
friend of mines explorer wouldn't get out of 4WD and i crawled under the truck, found a mysteriously cut wire. spliced it back together and all was well. i'd keep checking the codes...wondering if those others were residual or legitimate. if they are actual codes, all three, then i'd definitely expect a wiring harness plug or wiring somewhere. many squirrels/mice around your place? they like to chew on wires. also wondering if the TCU has issues if it's multiple circuits showing up. didn't you have at least one (if not two) vehicles with a cracked/broken rear window? the TCU is located directly underneath the rear window on the drivers side in an XT6. i'd wonder if any glass or water could have gotten on it/in it and caused issues if this is one of your cars with broken glass. -
i think i'd try to extract those codes before doing anything else to the car. if it's flashing, the TCU knows something and that will only help you. just get a long piece of transmission hose and run it from one side to the other. did it to my grandmothers car a few weeks ago when her radiator ATF cooler sprung a leak. ran fine. for the cost of hose you rule out the radiator. one minor bump in the pan shouldn't cause alarm, but a big dent might be worth looking into. got any large magnets to pull it out? drill a hole and pull the dent out, then weld it back shut. that would be quick. pulling the pan is very annoying as the old gasket will be caked on, hard to get off and the new gasket likely won't seat right on the pan because the screw holes are all non-flat. they get concave so to speak and end up making the new gasket leak in short order. really annoyihng...just like oil pans if you've done those. should be able to order just the gasket for a couple bucks, i've bought them before without issue. but that being said...you might be better off replacing if not the filter, the o-ring at the top of the filter. the filters really aren't worth replacing because they aren't much of a filter. they are only a screen, a fine mesh screeen and i've never seen one have so much as a fleck of dirt in them. i've replaced them but have to be honest and say i've never seen one that needed it. so if you're not wanting to spend the $, then don't you won't suffer for it. but....with your issues i might want to look at the o-ring that goes on the filter where it slides up into the trans pump. there's an oring around the filter outlet. maybe that's causing loss of pressure to the system? -
sure it's not a turbo oil line?
