Everything posted by northguy
good tires for my 88 gl
You may want to look at tire size first so you can decide on lift size and how much fender wall modification you'll have to do to accomodate the new tires.
New to Forum
Welcome to the board. You're sure to find helpful info to push that Legacy even farther.
Hello All - Need Help with Justy
Welcome to the board. Try the search function as I believe there have been some similar discussions in the past.
hello from texas!!
Welcome to the board. You'll want to link up with Calebz if possible. He's a wealth of knowledge.
Anyone ever replace a windshield before?
So are you recommending a "close cut" method of installation? And/or, if there is rust, what does one do when one has to remove all of the old urethane down to the pinchweld and start fron scratch? What keeps the shield from smashing the urethane flat in the installation process if you aren't using a butyl tape as a dam? I, too, installed shields for a number of years (8) in 3 different states (Iowa, Illinois and AK) from 1980 - 1985 and 1990 -1993, and saw the change from old school to urethane sets. I also saw major corporations (L.O.F., Speedy Auto Glass, Pilkington...) lobby the National Transportation Safety Administration to enact legislation to force only certified installations, citing studies that specified the shields of vehicles installed with urethane sealant were integral to the structural integrity of the vewhicle in roll over tests. And to an extent, I would agree with them that if the shield doesn't pop out on impact, like the old sty;e VW Beetles, that the driver and passenger are more likely to stay in the vehicle, and perhaps a properly installed shield is likely to reinforce the a pillars and roof of the vehicle to some extent. But I have never seen a case of a lawsuit for an improperly installed shield. I am very interested in how the process you advocate is different than what has been professed here, and I am not trying to be adverserial or attempting to start a flame war. You cite some important documents, and outline some safety aspects that are often overlooked, but you don't state how it is done in the shop any differently.
Watch the marketplace. Some deals pop up from time to time.
just a Hello!!
northguy replied to pastorj651's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board.
Pretty good install process, Torxxx. A couple of finer points: 1. Clean the glass surface thoroughly first 2. Prime the inside surface of the glass about 3/4" in with glass primer made for the urethane you're using. 3M is a reputable brand. 3. The 5/8ths bead of butyl tapeis the appropriate thickness for use here. Heat it in a microwave oven before using. Roll it directly on to the pinchweld leaving the paper on until just before installation. 4. Have a friend help set it and don't compress the shield onto the butyl tape until you have the proper spacing on each side. 5. After the shield is located correctly, use long, even pressure to compress the butyl tape and smash the urethane.
Accident at Colorado Meet 1/22/04
Glad to hear he's all right.
newbie in fla
Welcome to the board. Glad you found a cure.
any suggestions
Put a rear spoiler on it = good for at least 5 hp.
Newbie here with a brat project
Welcome to the board. Be patient with P.K.; he'll get back in touch with you. He's just a busy guy, but he'll get around to you in time.
New to the group
Welcome to the board. Send out a notice in the market place for parts.
What'a a bad bearing sound like?
northguy replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBearings usually scream - probably a bad cv axle or doj.
SKA meet n' greet? (attn: Alaskans)
So, was that you at La Mex that we saw? Did you see Kelly and I honk at you as we crossed the intersection? Or is there now someone else who thinks I'm some lunatic honking at people as we go through the intersection?
New Subaru Owner
Welcome to the board. As other questions come up, ask away.
Lift Kit for NON 4x4 ??????
I believe the chasis is the same. Should work.
w00t! I'm joinin the club!
Let the games begin.
Hello from Ohio - new ru
Welcome and ask away. That's how one learns. But be aware there is a search function, also.
Alternator problem?
northguy replied to dave1rr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be good to go for the life of your car.
Ok, Ive had my fun
Once you've been to the candy store your sweet tooth will drag you back again and again.
is this worth it??
Buy all 3 of them. You should be able to scab together one good rig, and recoop your investment in parts sold by parting the other two out when you're done. Good luck with the project.
Gun Racks
northguy replied to Tom Dunn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCabelas has the ovrhead mount for pickups, but that depends on how much head room you have.
MTBE and Subarus
northguy replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's been in our gas here for years and no problems to date.
Coming back to Subes
northguy replied to wae's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepending on how well it was maintained, you should be buying a good car. Timing belt changes, maybe brake rotors, maybe alternator(?), nothing else comes to mind. Good luck and welcome to the board.
