Everything posted by NoahDL88
oil everywhere!!
it seems rare that a cam seal would suddenly let go. but not impossible i guess. having not seen it i'd venture to guess that it might even be the power steering pump, the rubber hose could have sprung a leak.
Are there 2wd subarus?
pre 96 they came in 2wd variants, just look underneath as Jib's said, if you see a rear diff, then its 4wd after 96 they are all AWD at least USDM
Calling John Bloom (again)
so the pump works now, but i've not got spark the coil seems to be getting power but i'm stumped. Austin had mentioned a coil resistor that was on the legacy passenger strut tower, but i don't seem to see it on the schematic.
Air Bag warning light
NoahDL88 replied to nzbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it goes out, it shouldn't be a problem
bogger needs help
It sounds like the mechanical linkage is missing between the two
EA 5-speed D/R into a EJ 90 Legacy.
The rear diff should bolt right in, i'd just change the whole diff, although on the Legacy there is much more support for the diff than on the EA-82's You may have to make a custom drive line, and shorten or lengthen the section in front of the carrier bearing
I seem to be having a small issue with the ignition relay, it should be grounding into the ECU, but when i apply 12 volts to the power side it dosnt' click :-\
Where are the CRAZY subaru off road pics at!?
You're not the first Los, so this isn't aimed at you. But everyone seems to think that the AA wagon is a DL, well, as one of the few owners of a DL on the board, i can say that its not, it has black D pillars, and the single headlights, and the slightly more obvious GL badge on the rear hatch.
A few questions on EA to EJ
Way easy, the bottom bolts even line up. at least 20 people have done this.
Still working on the wiring, when its running, i'll be smiling soo big it won't even be funny Just a heads up, that million wire junction box with the 10 mm bolt that connects the two halves, yeah, make sure that's tight and that will save quite a few headaches.
- Yes!!! Now I Can Offroad!!!
Huzzah for the resurection of the dead posts!! As far as craming a 2.7 into a hatch, you can either search, or browse the Retrofitting forum.- Calling John Bloom (again)
my engine is in, and as soon as i get off my keester, i'll spend the rest of the day wiring and hooking up sensors and cooling lines- Tachometer
On a Brat? 5500- cheap/price free improvements
NoahDL88 replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnothing in this world is cheap or free, especially on Subaru's You gotta pay to play, thats it no way around it, unless you were born with a silver spoon.- Nokian Studded Snow Tire Q: Hakka 2 vs. Nordman
NoahDL88 replied to 99obw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can imagine it would be fun to ride with you in the snow. I'd also have to downplay the studs, the hakk's should be good enough without them.- Tachometer
Get a test light, and turn the ignition on, find out what fuses have power in this position, and tie in your positive wire from that, but make sure that when the ignition is off, the fuse dosn't have power.- Latest mod.... at LEAST 50hp :)
Maybe we could get into Subie Sport !!- EJ into EA questions
It would get you better acceleration than the stock legacy, if you had AWD, but in FWD, its hard to put the power down. As far as MPG, with oversized tires, i'm getting 25-26 mpg pretty consistantly. Someone put the whole legacy AWD AT drivetrain under an EA-81 wagon, that way he can run legacy wheels, ran really well too.- Hand throttle?
Austin had to use some pink string that I had in the back of my dad's forester as a hand throttle because the throttle cable broke, it was hillarious. I'd worry about the safety of a throttle that sticks, if you push the clutch you could over rev, and if you don't get it to disengage you run the risk of backing into somthing. maybe a bike brake that dosn't lock. I'd be cool if you get it to work, let us know Huzzah for the pink string- Latest mod.... at LEAST 50hp :)
I think you're the only one on the board that can challange me for too many stickers I still have quite a bit of real estate, so if anyone has any more- Delta cams for the XT6?
Yes, if your peak power is that high it will be a bear on the street, low end torque will be reduced quite a bit.- questions questions need much info on engine swap!
if you are using an OBDII engine and harness, as the 2001 is, you will need a VSS or the vehicle will not run correctly, i'm not 100% sure but its either in the transmission that the engine came with, or its on the axle tied into the ABS. without the VSS the computer will go into limp home mode, and after about 10 miles you will have about half the horsepower.- Stock Cams and why my carbed ea82 pulls all the way to 6k
The difference is clearly your exhaust, thats the only non-common element between the two.- A few questions on EA to EJ
I was under the impression that the SOHC's fit, no matter the size, well, except the 3.3 - Yes!!! Now I Can Offroad!!!
