440
Engine ping while at highway speeds
GeneralDisorder replied to heep70's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Exhaust leaks can sound like pinging.... just thought I would toss that out there. Doesn't sound like that's your problem tho, since it goes away if you lay into the gas. Generally and exhaust leak will get louder when you do that. GD -
I got 32 MPG with a brand new Weber - I would say that those who claim less have not got them properly adjusted, or are using used Weber's that aren't quite perfect. Since mine was brand new, and (I think) properly adjusted, I got some damn good mileage from it with the 175's I had on the car at the time. Of course now with the 28" mudders I get about 17.... The Hitachi's aren't bad if you rebuild them carefully - but the best I've seen one get is 30 consistently - and that's with the Cali emmissions stuff - computer controlled feedback system. I doubt that a new Hitachi, against a new Weber would win. The problem is the complicated design of the Hitachi. If you like tho, I could take a look at it for you. I'm here in West Linn - about 15 minutes from Portland..... And Zap is right - you should check the timing. Variations in the height of the carb and the mixture can affect it - plus the timing is supposed to be set at a specific RPM - and if your not idleing correctly, then likely it needs checking at least. GD
rear 87 wheel arch source
GeneralDisorder replied to jelly man's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That seems like a pretty good deal considering that used body panels from a JY are like $25 each plus core.... then there's your time to go there and cut them off... GD -
32/36 DFAV Weber to P/S EA82 complete
To all who don't know - this is NOT a DGV carb. It's a DFV carb, which is basically a mirror image of the DGV, with a different air cleaner opening. Even the rebuild kits are the same part number. You can get these carbs off of many early model Ford cars and trucks - like early 70's curriors and pinto's and such. I've been thinking about doing this for a while, since the adaptor plate would fit the same, and the choke being on the other side is actually a good thing for you EA82 guys...... GD -
to all brat masters?????????
GeneralDisorder replied to beachbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah.... but that was a Gen 1..... did they make a 2WD MV Gen 2? GD -
how to pack wheel bearings?
GeneralDisorder replied to teasdam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes - that would be why I said OLD bearing. If I'm taking it out, then I certainly WILL NOT be reusing it. Like I said before, the punch is the RECOMENDED method of removing the bearings according to the FSM. If you have issue with that, then call SOA. Not only that, but I fail to see any other method of removing them that will not result in pounding or pressing on the inner race. This is of course with my limited experience of EA81's.... I don't mess with EA82's, so I don't know about them. GD -
IF you could find someone willing to press them in (unlikely), they wouldn't have the correct press fittings anyway. And any shop will just pound them in anyway, so I fail to see how this is a "backyarding" method of installation. This is how Mudrat79 installs them, and many here on the board consider him to be a very knowledgable Subaru mechanic... GD -
How many times do we have to say you don't need a press? Jeez. The outside one comes out toward the outside, and the inside one comes out towards the inside. If you can lay hands on a brass punch, you'll be fine (about $1 from harbor frieght). You just pound the old bearings out with the punch, using it at an angle from the outside of the hub - the spacer moves up and down, allowing you to use the punch on the inner race of the old bearing. It literally takes less time to remove and install the bearings than it does to pack them by hand. As for bearing packing, I have two methods - usually I just do it by hand, but if I'm lazy or don't want to get dirty, I'll break out the pneumatic grease gun and a grease needle - just use the needle to fill up the "holes" in the bearings. Works great. I personally don't like bearing packers - they make a mess, and then you have to store them somewhere where they won't get dirty, etc. At least I can throw away rubber gloves.... GD -
Suday off-roading trip - damage pictures!
GeneralDisorder replied to GeneralDisorder's topic in Off Road
You wax eloquently about finesse, but that rock looks easily avoidable.... was there a time when you too were learning?? J/K GD -
Alignment go bad!
GeneralDisorder replied to Rolloverbratboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tie rod ends are about $25 each - you can install them easily in less than an hour. Just remeber to mark their location so you get them back on at least semi-aligned. Removal and installation of the rack and pinion unit is neither neccesary nor reccomended for tie rod end replacement - I don't know what they are smoking on that one..... Thrust angle alignment is bullshiz for Subaru's - tell em to stick it where the sun don't shine.... ALWAYS have your tires balanced. But a school auto shop would probably do it for nothing just for kicks if you asked nicely.... Siping is actually pretty cool, and if the tires are cheap ones, it will improve them a lot. Traction = good. Siping is good for mudders too..... If you have nice rims - tell the idiots to put the wheel weights on the inside of the rim so they don't mess up the nice appearance of your rims.... GD -
I don't know about EA82's, but on the EA81's they are a press-fit. but you can install them with a soft faced hammer (copper or aluminium), and a brass punch. In fact, this is the reccomended removal method according to the FSM. They are HEAVY duty bearings, so a little pouding if your careful should not hurt them. There is no need to even remove the hub from the car - just bang out the old bearings, and beat in a new set. Don't firget the spacer in the middle, and also use new seals on both sides to protect your new bearings. NAPA has two grades of bearings - one is about $11 each, the other is about $22 Autozone has Timken bearings for about $13 each The seals are about $5 each no matter where you go GD -
82 BRAT front height adjustment
GeneralDisorder replied to s'ko's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The adjustment (if you have it) is on the front struts - it's two 21mm nut's that raise the strut spring's lower cup. If your strut's have ever been replaced there's a possibility that you don't have the adjustment anymore. The adjustment is only about 1", so if you want to take the rake out, then you should lower the rear some. In fact, Subaru doesn't reccomend running the rear all the way up all the time. It puts more stress on the torsion bar.... and yes, they can break. Also - running the front suspension up, will impact your camber, and increase tire wear on the front. So you really should run with the front all the way down, and the rear all the way, or half of the way down. Also - having mis-matched tire sizes causes "chirping" when in 4WD, since the front is locked to the rear, and must turn at the same speed. Engage 4WD only on slick surfaces, or you will bind up just going straight down the road.... GD -
They are not simple inside - get an FSM if you don't have one, as they aren't even easy to get apart. You'll need the procedure on it. I'm working on one right now - I'm just stuck at the moment cause I don't have the right socket to remove the "extension housing drive gear" in order to remove the transfer case.... GD
Yes - I agree, we do get out and check quite often. And I'm getting better at picking the right lines through stuff, but in the case of that big log you see there - the only right line would have been a shovel and dirt, or a chainsaw, as there was really no way over or around it that was any easier than where I drove. Ian escaped the damage because he has a hatch and thus the better departure angle on me.... 14 1/8"?!?! Holy crap! How did you manage that with the diff hanger blocked down 3"? I'm confused.... GD -
Depends entirely on where it's driven, and by whom. If all the miles are freeway.... well you don't use much clutch on the freeway now do you? So I have to ask... What is the "problem"? First problem I've ever encountered where the "problem" is that it's definately working correctly..... would we file this under "operator error"??? GD
nokian tires revisited
GeneralDisorder replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Get some 27" swampers. Nokian's are awesome tires, but for about the same price you can get some swampers.... and there's just no comparison. GD -
Yeah - I think this is the bugger that did the nasty on my mustache bar - I'm afraid that soobs weren't really designed for log-hopping: The last series of pics you see there is where I broke my rear axle. The bend in the mustache bar caused the axle to over-extend and pull out of the outer cup. But I did make it up the hill.... barely with the welded rear. Axle went out just as I got up there. Bugaru tried, but it didn't happen - it's very steep, and there's a HUGE hole right there under the right front tire. Flo - it's clean. Sorry about that. GD -
Weber fuel pump?(new questions on setup)
GeneralDisorder replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would say that some of the pumps out there are starting to fail, and drop in pressure or capacity. They are all nearly 15 to 20 years old after all, and some have a lot of mileage on them. I think I'll be going with a carter pump that's around 6 psi.... GD -
MPG of various models ????
GeneralDisorder replied to mtsfabman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can figure it out yourself if you like... I get 200 miles to a tank (maybe 210 - the last time I almost ran out it was 207 and it died on the way into the station).... My tires account for a 19.2% difference in speedo, and odometer readings (175/70R13's to 215/75R15's)... 210 * 1.192 = 250.32 actual miles driven. My tank capacity is listed as 14.5 gallons... 250.32 / 14.5 = 17.26 MPG That's figured at 210 miles, and like I said, I nearly ran out at 207 last time I tried that, so I would imagine that this calculation is pretty accurate since I doubt the fuel system is capable of completely draining the tank of every last drop..... And for comparison, I could go over 400 miles when it was 2WD with no trouble at all. I seriously doubt anything has changed - except of course the obvious stuff - and there's plenty of people around on the board that can tell you how good my engine runs.... it's top notch. GD -
Quick speedo question
GeneralDisorder replied to SUBARU3's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've seen posts about the seal on the tranny side of the cable going bad and the cable "sucking" tranny fluid up into the speedo..... might want to have a look anyway. On the other hand the one in my brat does that a tiny bit at low speed, but stops after 25 MPH or so.... hasn't been a problem yet. GD -
In my wagon (84 EA81) when it was 2WD and a BRAND NEW Weber, I got 32 MPG on a 600 mile trip to WCSS5. Now same car, no engine changes at all - same new Weber, with 28" mudders, and 4WD, I got 16 MPG on a 300 mile trip I made week before last.... Bugaru got 16 MPG in his hatch on the same trip which weighs less, and has smaller 27" tires - but he's got the Hitachi, and crappy gearing, so I still did better. I think our calculations were pretty accurate - we filled up at the same places each time, and checked how much gas we put in, etc.... GD -
As I recall, Rob said that he has about 1/2" more clearance under his diff than Ken, and his hatch has the rear strut's like my wagon... both of them are running 27's. Now I'm running 28's, so I should have another 1/2" on top of that, so my guess would be that I have at least 1/2" more than Ken, if not a full 1" more. I can tell you that I have 13.5" under my rear diff.... so we ought to be able to compare that number if all our diffs are in the same location, then the gas tank ought to be the same relative to the diff. My guess is that the difference with the Brat's, is that the rear strut top is physically lower on the body or something.... makes sense anyway... GD -
incidentally - the fuel pump pressure for the EA81's is 1.6 - 2.03 psi or something like that.... GD
