Everything posted by Sweet82
You must lift first! The tires won't fit if it's not lifted. In the pics with Mad Max on the 26" Atv tires... The tires were rubbing...
Rage on! That's Great! Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester
Besure you use a 6 ply tire!!! I wouldn't trust anything less. Plys are everything when your abusing the maximum ratings. They make 28's but,... your loosing a lot of your gearing by going that big...?
I would think you'd need an idea of what your looking for as an end result in order to get an idea of what you'd need as a frame. You can certainly start with the engine compartment. That measurement would be the current width of the frame rails under your hood. (Where your crossmember is currently bolted to your frame) That won't change! The firewall would need to be in the same basic position for your controls to work as they used to. (pedal box, steering...) Big time & money saver re-using those components! Beyond that it would all be up to your imagination... Length is subjective, it's just a matter of lengthening or shortening your driveline. My buggy, Summer, is 11' 6" long. I took 15" out of the driveline. Knowing what I now know, I'd send off for Rhino plans and change them as necessary to suit your desires-given your end result idea/use. I changed tons of stuff from the original plans. But for the time & grief they saved me by diagraming it and measuring it, it was worth the $!!! Your also getting a tried and tested design, there is a lot to be said for that? Good Luck, Glenn 82 SubaruHummer--frame could be built in 2 weeks, working eves and weekends. 84 GL Mad Max 01 Forester
There is a UROC competition Rock Crawler that uses an STi motor. Unimog axles are heavyier, more expensive and harder to find parts for than a Dana 60. The latest Crawlers are not using Unimog equipment anymore.
A 12" rim will fit and clear all the brakes and steering components. http://www.ultimatesubaru.org/photos/showphoto.php?photo=4967&sort=1&cat=500&page=3 The question is what are you going to do with a 12" rim? If you mount a middle of the road tire "26 inch", you'll need a lift to clear them--depending on the width? http://www.ultimatesubaru.org/photos/showphoto.php?photo=7438&sort=1&cat=500&page=2 http://www.ultimatesubaru.org/photos/showphoto.php?photo=7435&sort=1&size=medium&cat=500&page=2 A smaller tire would fit a bit easier. Your stock tire should measure about 22.5" A 26" tire measures out to about 25.5 Tell us what you have in mind? Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester
I was never able to find a 13" tractor tire. What equipment uses them? I never found any industrial or farm equipment that used a 13" wheel. With no demand, no one is going to make them? Best I could find was 14". Send us a link on the 13" tractor tires.
Whats the best tire and wheel combo ?
Sweet82 replied to shawnsbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You might want to search a bit but here is a pretty good link.... http://www.ultimatesubaru.org/forum/showthread.php?t=24980 Good Luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester -
ea81t 4wd coupe; how rare?
Sweet82 replied to Jack in Norfolk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a complete Tan one in an out of the way Junkyard here in SLC. -
So...you haven't given us any details... we're going to quit begging... if you don't fess up....
Yes, your hubs are locked, that's your option. Just messing with you. Welcome to the board, as of yet no one has made a unlockable hub although some have been discussed.
I had a hitch on my Hatch. The one I used came off an old Honda Civic. It mounted to a plate and the plate mounted to the bottom side of the rear cargo area. I also also attached to the bumper. I'd think if you know how to weld, you could easily make a custom one. Good luck, Glenn 82 SubaruHummer--hitch 84 GL Mad Max--hitch 01 Forester--hitch
I do the exact same thing with my Trooper. Vehicles make logs much easier to move!!!
No more signatures?!?! SIGNATURE POLL
Sweet82 replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Never used um! Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester -
Shipping from the Northern Mariana Islands might get expensive!
I just used the archive feature and it's great! I was at my limits too. The download to a file is a great feature to keep your treasured PM's!
I think there is also some "beatin" required to allow clearance for some rear drive train parts. Do a search, it's been done many-a-time. I'd also agree that is may be cheaper to just buy one and restore it with your other car parts, rather than purchase JY parts and add them to your car... Good Luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
Greetings all I am new
Sweet82 replied to iluvdasubarus's topic in Meet n' Greet. Your USMB Welcome Center
If it were me, I'd look at NADA.COM and put in some figures and see what current wholesale (Low Book)prices are. I'd look for a vehicle in your price range with the proper amount of miles or less. If you can find a non-wrecked, non-painted Subaru without high miles, I'd consider buying it. Good Luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester--purchased $1,000 below low book with average miles. No paint no collision. -
Welcome to the board! I'm not sure why your post got moved but if you re-phrase your question it should fit in the "Newer Subaru" forum without getting moved. You may get better exposure for your question in that forum? Good knowledgable folks in the newer forum. I've had great luck with that type of request in there. Also you may try a search for JDM and see if you find anything helpful. Good Luck with the project! Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester
I'm just far enough away to not feel guilty about helping! Good Luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
Fuel Pump Control Unit - A call to action
Sweet82 replied to exister99's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What's wrong with a Junkyard part for $5-10? I had the same issues and looked at a new one but that just didn't make sence. I also wired my pump to the coil until I could locate a Junkyard FPCU. Seems to me a JY is a quick, cheap, real fix? Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester
