Everything posted by Sweet82
Project Bobby approved by Fiance.
My wife was the one who sent the money to AZ for the plans to build "Summer" ....(do you think she did it so she wouldn't have to drive it anymore?).... She enjoys our SubaruHummer and calls it a 4 seat ATV. It's nice to have someone who supports me with these whacky projects She's a keeper Sko! Keep Building! (your relationship)
tranny help
If I remember right it takes about 3 quarts? of fluid... Mine ran fine on 1 quart for many years...as I never filled it in 20+ years Good luck, Glenn 82 SubaruHummer 01 Forester
Who wants to laugh at me? Took me five years to find...the cupholders.
Sweet82 replied to Nihilator's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI like where they placed them in the forester.... Right in front of the vents!!! In the summer it cools your coffee and then in the winter it warms your soda! Who thought this up? It also blocks a fair amount of air when you use them... Just whining!
Temp display?
On the 01 Forester I have the "out. Temp." display on the dash that tells the outside temp. Question; Is there a way to display the "inside temp" off the same unit? Or is is strictly going to just display the outside temps? Alright it's a stupid question, I know... But I have a stupid reason. I want to get the center dash gauge pack that already has an outside temp display and I was wondering if I could switch the dash one to not duplicate the displays. Glenn, 82 SubaruHummer---outside temp is always the same as inside temp! 01 Forester---wants dual temp displays!
How do you find cheap Subies?
When looking for a Subie....it's important to....... Never let them know your afraid! I'll be quiet now Glenn 82 SubaruHummer 01 Forester
LSD's: 3.7 or 3.9? replacing 3.9
Find a 3.7 LSD and put your existing 3.9 gears in the LSD and you'll have it. I think there are numerous write-ups on the how to details. Good luck Glenn 82 SubaruHummer---Welded diff 01 Forester---LSD
low ratio
Sweet82 replied to church-heliboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't make us Jealous.....talking about High and Low ratios. :slobber: We can't get them up here! We only have the single range transmissions Glenn 82 SubaruHummer-dual range transmission 01 Forester-single range transmission
over temp but why?
Sweet82 replied to wmagni's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a similar problem, I have traced it to one of my fans. I can get one to come on from heat/air conditioning. The other fan will not come on! I have jumped power to it and it will work but the sensors aparently will not turn it on. I checked my relays by swapping them around and was able to eliminate them as a problem? I ran a thread on this a while ago I think it was "Forester cooling issues"? The board was most helpful. Good luck Glenn 82 SubaruHummer 01 Forester
Officially overwhelmed!
I second the motion! Replace as necessary...
experiment for keeping out mice
It's funny all the sudden there is mouse posts everywhere. It kinda makes sence now you think about it. It's the time of year the cridders are looking to find shelter. Can't really blame them for trying Get a bucket half full of water attach a ruler on a piece of coat hanger wire to form a diving board/teter totter. Make it so the ruler can pivot freely but rests/resets to a horizontal position. Place smear of peanut butter on the end of the ruler in the center of the bucket. You now have a resetting mouse trap with the optional drowning attachment. Don't forget to add stairs to the end of the ruler for easy access and your on your way! Note: In winter use Antifreeze or they just jump back out off the ice. I have used one of these for 15 years and only baited it when I first made it! Mice line up to go swimming! Everytime I check it I have a bucket of Mice Smells great in the summer time.... Disclaimer: If they wouldn't eat the rubber hoses on the Quads or snomobiles or carpet in the Trooper, I wouldn't do this in my garage. But they do!
Forester Weight?
I was fooling around at lunch today and got the Forester Weighed. I was kind of supprised how much it weighed As it stood with no real equipment or people inside it was #3170 pounds! For your Ref. Glenn 82 SubaruHummer #2030 01 Forester #3170
Diff hanger bar reinforcment?
Mudrat, I'll give you a call before I leave "work", it's cheaper that way I'm going to go to the cabin this weekend so I may not be around much, cell only works a little up there? I was talking about reinforcing "Summer". I figure I need to do something to the diff bar before I put the other rear axle in for good! Took it out the other day with 3WD and it was a scream! Build Yours!:-p Glenn 82 SubaruHummer 01 Forester
PKmobile won't start!!!! Fuel Pump fuse/relay?
I'm not sure what it does? I know it controls the fuel pump power and the choke on the carb. It's a black box 1982 (Light blue on later years 1984?) that mounts to the side wall of the car near the hood release. I think it has a six prong wire connector. I tested mine using a volt meter and the wires that run to the fuel pump. No Volts! I think it uses a signal from the coil to know how often to pump but I'm not sure if it's dependent on the ignition system or if it is able to kill the ignition system? Someone here will know... I'm still concerned about the spark thing... Good Luck Glenn 82 SubaruHummer 01 Forester
I need to beef up my diff hanger. Here is what I had in mind.... I was thinking on welding a 1.5" by an eighth flat bar along the bottom, following the contour of the existing diff hanger. A cross section of the bar would look like an upside down "T". I figured this would give me the strength of angle iron times two and the strength of curved steel together? Looking for feedback before I do it. Any thoughts? Ideas? insults? Glenn 82 SubaruHummer---welded diff + beefy tires = weak diff hanger! 01 Forester
I had a similar problem when I was building "Summer". Everything went back together just fine and it fired up great. Shortly thereafter it wouldn't start? I traced the problem to the fuel pump. After replacing the pump, I found it still wouldn't start. I then traced the problem to no power at the pump. This was because the "Black Box" (Fuel Pump Control Unit) went bad...for no apparent reason...It quit sending power to the pump. You might want to check this out on yours? For what it's worth... Glenn 82 SubaruHummer---Summer 01 Forester
I too have a mouse
If it's eating Acorns, I think it's bigger than a mouse! I'd suggest a rat or a squirrel has taken up residence? A big mouse trap would catch the varmit but if it's a Squirrel, I'd hate to hurt it? Can you relocate the car? What about wiping the area clean with gas? That's got to stink and varmits have sensitive noses. Good Luck, Glenn I have the same problem with my Trooper (Mice) I relocated the vehicle and put traps inside where the mice are congregating
Help with forester insurance
Sweet82 replied to Diesel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKelly blue book generally gives you a higher retail price than NADA.com. Good Luck Glenn
Hail!
Sweet82 replied to Diesel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat hurts just to look at! Can you get the money for the totaled vehicle and keep it? Or do they give you the money and keep the car if they total it? It would make an interesting platform to start building with and you wouldn't have to worry about body damage Keep us updated on what your going to do! Glenn 82 SubaruHummer 01 Forester
Had some Fun Offroad a couple weeks ago
Lookin Good! The XT makes an unusual looking platform for off-roading. Looks like it could go anywhere you point it! Glenn 82 SubaruHummer 01 Forester
Accessory Blowout Specials from Subaru! (Long)
Doctor,.....That's one of the longest posts I've ever seen Thinking, Thinking, Thinking (Forester Gauge pack with Gauges?) Humm..... Glenn 82 SubaruHummer 01 Forester
Bumper bummer
Sweet82 replied to rottenhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think this is the perfect excuse to make a "Mad Max" bumper and start your building adventure. After all it's not your fault the bumper got torn off. You just put a nice big off-road one in it's place for safety! Built it! Glenn 82 SubaruHummer 01 Forester
What do you think about these Flares???
I'm an off-roader but I like it. It seems to be the proper flare for the vintage of the vehicle. I think with some paint and some finish work it will look like a slick custom machine! Casting one vote for Keep it! Glenn 82 SubaruHummer 01 Forester
Subaru Jihad!
My vote is now....an 1982 flatbaru. The 82's had the plastic outer bumper and chrome center like this one has. I was looking at a different pic from earlier this morning. :-\
Subaru Jihad!
Are we looking at the same picture? What rims? Something fishy is going on here?
I have been battleing mice in my Trooper. They have been eating the fluff thats under the carpet I now have two mouse traps in the thing. That's going to smell good! (In two weeks when I get back to check it). :-p I found out they were climbing up the trailer hitch wires and crawling along the frame and entering through the shift boot area. I hate mice. I have plans for a great resetting mouse trap if anyone's interested Glenn 88 Trooper mouseless 90 Trooper mousehouse
