rocketman
Everything posted by rocketman
  1. And you have a lot of oil build up you need to address,maybe cam or crank seals.
  2. Check pcv system,also with no cats probably running full rich.
  3. Lol,I am not sure but I think my generator does,and some newer vehicles.
  4. So if oil pressure is lost,do they shut down for safety reasons?
  5. Is it possible the engine locked up from a cylinder full of violent?
  6. A loaded manifold would be easier,but you can do that.
  7. I don't think so, it must be from 2.2 engine only, reread entire post.
  8. When you did compression ckeck,did you put oil in cylinder to see if compression was up? You may have bad rings or cam lobe.
  9. I think sticky brake,maybe get out and see how brakes are. I use a temp gun if you don't want to burn your fingers.
  10. I believe that swap is not plug and play,have you done this before?
  11. Also you could open up the doner car to see where the plug is,then take another blew pill.
  12. I had to laugh too,may put some dielectric grease on plug.
  13. Is there anything that will clean the oil ring without taking apart,like marvel mystery oil?
  14. I like the body style,but the big dawgs here are saying bad rod bearings,uncomfortable seats,bad window motors,and switch's,also carry less weight,and ordering parts can be a debaco.
  15. Fairfax has good point as usual so if drop y pipe to see if guides have dropped down is important.
  16. Did lifters sound noisy? Did can lobes look worn? Did cylinder wall look scored?
