25
Everything posted by nipper
Does it seem to come from the seat of your pants (even though you feel it in the steering wheel). How are the wheel bearings. Does it seem to go faster or slower on turns. You are at the mileage where the universals can be suspect. Is it a heavy or annoying vibration? How are the CV joints (boots don't tell the entire story)
wheel bearings wont come out!!!
nipper replied to subinewby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
H - E - semicolon - semicolon thats a new one You need a press to get them out and in -
NOOOOOOOOOOOOOOOOOOOOOOOOOOOoooooooooooooooooooooooooooooooooooooooooooooooooooo It hasnt even be Thanksgiving yet *covers ears* lalalalalalalalalala
Except he was NOT complaining about the car running poorly, loss of power, noisy valves or from a rough idle. GD you are not the only one who has rebuilt heads due to valves out of adjustment thank you, I have done quite a few of them. When somone comes in with a minor complaint and has his check book raped that is an entirely different story. He went in for what he considered a minor leak. The shop has shown its utter lack of skills by not wanting to do an oil change when changing the oil filter. Hell I even doubt they did a proper diagnostics on the valves except for the ol "while we are there" we can charge you another 400.00 dollars. Sometimes the While we are there is justifed, sometimes it is not, in this case I do not beleive it is. Personally I think they just saw easy pray and at worse they are lazy. Even if I beleived them I would not them do the work. It mat be a leaking oil filter... and it does not take two techs 20 minutes to diagnose a leaking valve cover. The first thing that should have been done if the leak was not obvious, was wash the under car and tell the customer to stop by the next day or so. This was not done. Like I said, get another opinion.
Auto Tranny Grinding 89 DL
nipper replied to workin4weekends's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The nice thing about a diff when ti just starts making a whine (gets louder with speed), it is a very long hose to be hosed with, but never the less it is dying and needs replacement -
Shock from 3 to 4th 1) Control module 2) Throttle position sensor 3) 2-4 brake duty solenoid 4) ATF temperature sensor 5) Line pressure duty solenoid 6) Control valve 7) 2-4 brake timing solenoid 8) 2-4 brake 9) ATF deterioration 10) Engine performance 11) Low clutch timing solenoid 12) Low clutch Shock occurs when accelerator pedal is released at medium speeds. 1) Control module 2) Throttle position sensor 3) ATF temperature sensor 4) Line pressure duty solenoid 5) Control valve 6) Lock-up damper 7) Engine performance 8) 2-4 brake duty solenoid 9) 2-4 brake timing solenoid 10) Low clutch timing solenoid Shift characteristics are erroneous. 1) Inhibitor switch 2) Control module 3) Vehicle speed sensor 1 (Front) 4) Vehicle speed sensor 2 (Rear) 5) Throttle position sensor 6) Control valve 7) Ground earth Now lets start with the cheap stuff. Run a new ground from the transmission to the chasis or battery (hey its cheap) Next disconnect the battery for ten minutes and take it for a drive.
