25
Everything posted by nipper
Then where do you put the beer?
OBDII has nothing at all to do with the transmission codes. nada zip zilch zero There si another method for getting those codes, involving a chicken, a alter, pointing to indiana, and chanting several times. That and grounding out a pin in the harness. If you dont have a tranny light flashing at startup, then your solenoid is fine. nipper
So this is a drive by wire? Is it possible to get the gas pedal assembly? Usually the transducer for "accellerator" is on the pedal assembly. Sorry i'm a bit foggy right now, but it may just be easier to do that then everything else you wish to do. nipper
When I did Blu I got a case of transmission fluid. I also had a smart system. Drain the tranny fluid into a plastic drain thingy. They actually have measured marks on the side of them so you know how much came out. Put back in the 3-4 qts ish, and put the old fluid back into those empty 3 qts. Start the car and go around the block, or put the car through all the gears and count to 5, then move onto the next gear. Do this through P-R-N-D-3-2-1-2-3-D-N-R-P. Drain and replace fluid, then repeat. I dont even know what I used to tell you the truth. Its the same thing Ive been using for ages, in the same mom and pop store. I just grab the case, pay for it and go nipper PS my biggest fight was getting the dipstick out.
Manual or automatic?
Well those canadians are a nutty bunch.
Krylon rims, opinions welcomed
nipper replied to Txakura's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i like the red and black. nipper -
Wrong Brooklyn
I've heard nightmares about CA emission inspection. To be that pickey is just insane, stupid, and a few other choice words. nipper
