Everything posted by nipper
Lift Kit new gen
http://www.ausubaru.com/index.php?pageid=liftkits Ok now this really wants me to see diesels here. Imagine this AND a diesel? nipper
Is it my vent valve? Can't fill gas
nipper replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, this is a rinky dinky little check valve in the rubber line by the charcaol canister. Looks like a check vlave of some sort. If you follow the lines from the canister it should be about 12" or less away. nipper
nipper replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your charcoal canister, does it feel heavy? If you have topped off the tank recently and it sucked in some fuel, it can cause this problem. Have you checked the two-way valve (by the charcoal canister).
Low Fuel light - false positives
nipper replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHurt. It would be too strong. Remember that little can mixes with 15 gallons of fuel. I am sure at some point it may even damage the sensor bodies if it is too strong. Use a pencil eraser if your going to yank the senders. nipper
nipper replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow You know you hear these urban myths, of things like this. A neon that had no issues.
Rear (transaxle) Mount
nipper replied to bsaride's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck all the motor mounts, but yes it sounds like yout tranny mount is not happy. nipper
nipper replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts not just subarus, other cars do it also, but realize that we also keep our cars much longer and much more aware of what they do then other drivers are. It also happend regionally. Now with cleaner fuel its less of a problem, but there have been a few incidents of fuel with too much sulphur in them (happened in FL and TX) that ruined alot of fuel senders and the gas supllier had to cough uup money for repairs. Soobys with over 150,000 miles on them is common place, as oppsed to almost any other brand (excluding volvos). I am sure if you had a bunch of nissans or chevys rolling around with that many miles on them in large numbers, they would show the same issues. Usually by that time any other car has so many things falling off them, no one notices the gas gauge as much, if it even works. nipper
nipper replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGauges are for refernce only. Also it may not be that one is bad, but that one has an innacurate spot in it, or they both do. I would never recomend just removing one. Its worse then having an innacurate sauge, because the gauge is predictable. nipper
nipper replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a very obvious access plate on either side of the car. Then under thoe plates are the fuel sensors. Be careful as they are small nuts and easily lost. Be patient pulling out the sender as it will take some manuvering. nipper
nipper replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn an AWD sooby you have two fuel senders and one light sensor. A left float amd a right float. They dont get out of synch, as they are are independent vairable resistor devices. There is alos a "jet pump" (siphon) that shifts fuel from one side of the tank to the other. Either or both sensors can be fouled by sulphur. They are wired in series. nipper
14 mpg!!!!
nipper replied to Sundance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe are attacking one problem at a time. The O2 sensor needs to be OE. Hard starting can be a fuel pressure issue, can be runing too rich becuase of the O2 sensor and fouling the plugs, but generally fix one issue at a time. Also get the codes read, see if any are stored, and then reset them and lets start with a clean slate. Also describe better the hard starting. nipper
Alot of smoke on passenger side of engine bay?
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmmmmmmmmmm hotdogs THATS IT! We need someone to bring a turbo the bext time we play out at NJ Pine Barens so we can have hot dogs nipper
14 mpg!!!!
nipper replied to Sundance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got down to 14 with a bad O2 sensor, Replace the front one with an OE. I had an aftermarket and it only lasted 2 years (for the record I did not install it or buy it). How many miles on the car? When was the last time a timing belt was replaced? nipper
1998 Legacy Timing Belt Change
nipper replied to Urban Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet the belts and seals from subaru, anything else from wherever. What mileage is this change? If this is a 60,000 mile interval then every other change should be water pump cam seals main seal re-seal oil pump idler tensioner A new T-stat wouldnt be a bad idea, and If hes never done it before may want to keep virginal ears away when you try to line up the timing marks. nipper
what engine and transmission?
Welcome. GIve us a better idea of what you want to do with this project car. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles. It may just be time to reseal the engine. If its the valve covers replace them and the spark plug grommits with parts from subaru. the aftermarket parts dont hold up. And if oil is on your wires, change those too. nipper
Looks like Subaru's evil overlord isnt so evil
For future emissions they all will have to go to DI, so that wont be thrown away. nipper
nipper replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um Well................... yes there are. Its called the fuel level sensor for the gauge. But buillions of cars have been like that because its a variable resistor that is in constant contact with the wiper arm of the sendor for no sprak. Also in a sealed gas tank the tank isnt exploive unless you add oxygen. Worry more about getting hit by lightening. nipper
New Jersey Devil Chase
Thats what beer is for
1994 Legacy Torque Bind (I Still Have Questions, Please Help)
nipper replied to mslamb5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat only works for cluutch type LSD's, which even if you had an LSD it wouldnt work. Don't listen to that shop ever again. nipper
Hey
I can never find good deals like that nipper
nipper replied to mslamb5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat may have been my fault. I said to add it, but may have not have been clear as to where. nipper
nipper replied to mslamb5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you add the LSD additive to the ATF fluid? I know it sounds wierd but it does help if the plates are grabbing. nipper
Hey
Welcome (you need to fix your links) Thats a really good mileage nipper
Did I wait too long on my knock sensor replacement?
nipper replied to otis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook under the dash on the drivers side near the gas pedal. You will see two green connectors. if they are connected disconnect them and all will be well. They are to be connected just for diagnostics. Sometimes (we are all human) a mechanic will get distracted and forget to unplug them. nipper
