Everything posted by nipper
I wish the drivetrain would last like the engines
nipper replied to LegAC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXheheh for future refernce, porked is usually how you describe a gauge thats been over pressurized , hence broken. 10 pts on the bannanas nipper
nipper replied to LegAC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um wow bananas Yes, though it may be easier and cheaper in your case to get a used tranny nipper
nipper replied to LegAC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX. sounds like the previous owner porked the AWD unit. Its a sealed unit in this car. DO measure the tire. You may get lucky and that can be the source of the problem. Maybe its caught early. nipper
ECU says I need a camshaft sensor
nipper replied to salewit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbut that was before the bad o2 sensor nipper
HELP--93 Legacy Problem
Yes sometimes the plunger pops out of the solenoid. im sure somone else will chime in with a better explination, its happesn a few times a year here. Look on the outback board too. nipper
ok here you go. Its a simple system. You either have a bad relay or solenoid in the system. YOu should hear a click when you have the car on, foot on the brake, and press the gear shift button. If you dont there lies the problem. http://www.ultimatesubaru.org/forum/showthread.php?t=46496&highlight=Key+Stuck maybe that will help http://www.subaruoutback.org/forums/showthread.php?s=&threadid=7763&highlight=interlock nipper
Intermittent clunking sound from rear
Check the universal joints in the driveshaft. nipper
nipper replied to LegAC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have to measure the odd tire. Tires can vary in size from brand and mfg within the same size. Measure the circumfrance. The drivetrains last, if you take care of them. Parts do wear out, thats normal. Nothing lasts for ever, otherwise they wouldnt make replacemnt parts. nipper
nipper replied to salewit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXo2 sensors dont last for ever, they wear out in time. That would have been the first thing i changed, along with a tune up. But thats just me :-p Another possability is leaking fuel injectors or worn fuel injectors. Also dump a can of that fuel additive that guarentees passing. I dont like them, but after three tries its time. nipper
nipper replied to salewit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChanged it after the third test or before it? nipper
Question about engine getting hot while sitting in traffic
nipper replied to Rice Burner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJump the thermoswitch, its should start the fans. If it doesnt then you need to look at the fan or the relay. nipper
nipper replied to Rice Burner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen a bad left fan motor, thermoswitch or relay. nipper
nipper replied to salewit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat were your counts exactly? nipper
Brake bleeding
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe brakes are in the mail? Thats a new on one the check is in the mail :-p nipper
Liking the New Gen Car Already
nipper replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPoked a hole in the tank .... silly nipper
Weird AT stuff
nipper replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVSS the car goes into FWD and shuts down the AWD system. nipper
Halp!!!
And change the oil after a car overheats. Just good insurance. niper
Reverse drags....Torque converter?????
nipper replied to sparkster58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTime to decode that, but it will say Duty C electromechanical failure. nipper
squeaky belts?
yes. SLipping belts. nipper
Turbones Trip to the East Coast Update
Oo someone in SD besides my nephew .. may ill skip ND all together. nipper
squeaky belts?
How old are they nipper
Weird AT stuff
nipper replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYOu can drive with thew FWD fuse in. It will save you a major repair in the awd units. you wont hurt anything. nipper
Weird AT stuff
nipper replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you done the basics? Do the tires all match, equally worn with 1/4 inch cirumfrence and properly inflated? Put the FWD fuse in the holder and see if it goes away. Have you ever fully flusged the tranny? nipper
nipper replied to sparkster58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought that was on loyales. He has a legacy. I get so confused on these years and who is who :-p nipper
What are these unused connectors?
nipper replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGreen connectors are always diagnostic on soobies. I cant tell where the other one is, as it may be some sort of diagnostic connector. It sure looks like a scanner connection (ABS Airbags etc). nipper
