Everything posted by nipper
Break in new rotors?
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWOHOO i feel better :0 http://endwrench.com/images/pdfs/FrictionFeb06EW.pdf page 10 :-p nipper
need tranny
A better explination without me doing a lot of typing http://auto.howstuffworks.com/automatic-transmission6.htm Your welcome (i love teaching, hate typing) nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi still think its alot of bunk, otherwise anyone who lives in a high density area could go after a shop for not properly breaking in a set of pads. For instance, where i live you have travel a good 5-9 miles to get to anywhere where you can do 60 mph (and i dont mean legally), let alone do hard stops without getting rear ended. What are most people supposed to do? Also I have yet to see an SAE paper on this (please feel free to show me is someone has one). Just make sure you have a good brake pedal, be cautious on the first stop to make sure things work, then go ahead and drive. http://www.se-r.net/brakes/breakin.html http://www.cartalk.com/content/columns/Archive/2003/June/05.html Tire rack recomendations for specific brands http://www.tirerack.com/brakes/tech/techpage.jsp?techid=85 though i do love the part about avoiding heavy braking for 400-500 miles. Unless you live in north dakota i think thats impossible. http://www.pagidusa.com/bedding_in_procedure.htm So many variations on the procedures, professionally i think a lot of it is a myth. nipper
Puzzling CEL
nipper replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy front one went at 187,000 miles. My rear went out last month 210,000 miles becuase it was physically broken. I was shocked as to how easy it came out. nipper
what can i do with this damned suspension!!!!
http://www.ultimatesubaru.org/forum/showthread.php?t=36824&highlight=mustach+bar Look at the picture showing the rear end of the car. The bar that looks like a mustach. Someplace on here somone made a custom one that lifted the back of the car. It kept everything in alighnment (no eating axles) and allowed for large tires. nipper
bizarre 4EAT trans issue
IAC job is to bump up the idle speed when the car gets a load at idle, like the AC or putting the car in gear. I may be wrong but thats the first place i would look. Maybe its dirty and sticking when cold. nipper
Puzzling CEL
nipper replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou are about the right time for the o2 sensor to go out (anything over 100,000 miles). (front one needs to be OE) Have the codes read by somone who does it for free, but usually an intermitene CEL is an o2 sensor. A flashing o2 light is a misfire. nipper
need tranny
And its something thats not uncommon to go bad on a auto tranny. nipper
UN-official Alcyone Dragon Meet Alternate Thread.
Ok im blond. The first time i read this i was thinking, what does the UN have to do with subarus, and i dont remember a country called Alcyone. hehehe nipper
I dont think its the lockup TC, unless the TCU is confused, or there is some failure of an internal valve. The TC never locks up in reverse, and its normal state is unlocked. The car only does this cold? If you let the car warm up it doesnt do it? What happens if you skip to N (hang out there for a second) then go into R or D. Scan the puter while its doing this, see what the scanner comes up with. I'm wondering if your IAC is flaky, as this is part of its job. nipper
You said to use small words :-p Have you thought of a mustach bar on the rear differential then longer springs ? It does allow for bigger tires and hence mmore ground clearance. nipper
EA 82's fat smokescreen???
This is one of two things (and its not unusual). Its either the pcv valve or the valve stem seals. It takes very little oil to make a hell of a lot of smoke. Mine did the same thing, but only on one ramp specifically. nipper
91 loyale torq bind, is it the end of the world ?
If you dont have an assistant just jack up one wheel of the car off the ground. This will unload the 4wd. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just always drove the car nipper
Puzzling CEL
nipper replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat what mileage is on the car. Auto or stick. (if I had to take a blind guess i would guess O2) nipper
EA 82 engine temperature variation
Im going for a radiator on this one. You are on the threshold of having a bigger problem i think. Of course check your altenator output and make sure your cooling fans work first. When its cool outside, the cooling fans dont need to come on as often, so the car cant get rid of all its heat. If you have two cooling fans (electric or otherwise) the 2nd one only comes on with the ac. When its hotter outside, the fans run more often, or are on all the time with the ac. There is a lot more air moving through the radiator. First thing i would do is physically remove the radiator and inspect the cooling fins. See if they are still there or are clogged. As long as you have it out, put the cap back on it and fill up the upper hose with water. the same amount of water should go out as goes in. If the Upper hose starts to overflow and the bottom has a poor flow, the radiator is clogged. you should also be able to feel the radiator being evenly cold (temp of the hose water). Just my guess. nipper
VW Syncros Offroad
There are a couple of them on the yahoo list. They say people are amazed when they get passed by EJ powered vans, as they are usually the slowest things on 4 wheels on the planet. nipper
Frt Brakes
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell my brakes are done. It took me 3.5 hours yesterday. Keep in mind this id the first "real" work i've done on the car since my back surgeries. It should have taken me an hour . At least its done. New front rotors and ceramic pads from autzone (the better ones). I researched thme on the net and there was nothing bad about them. The pads would have failed inspection. One rotor practically fell off the car, the other put up a fight. I forgot how much liquid wrench is my freind. The caliper bolts were a PITA untill i soaked them in wrench and they came right off. I am impressed with the feel of the brakes now. I will never go back from ceramic pads. nipper
If its not headgaskets what could it be?
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPersonally I would replace it with something new. You can try all mentioned, but the problem is that it clogs with hard mineral deposits. You cant disolve them nor get them out if they are clogging the narrow passageways. If it was just gunk from oil/antifreeze then you can clean it out. nipper
Help me understand my AWD
nipper replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.autozine.org/technical_school/traction/tech_traction_4wd_2.htm AWD 101 nipper
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts most likely clogged then internally nipper
need tranny
older transmissions operate like an hydraulic computer. They are constantly balancing out throttle pressure (modulator) vs govenor pressure. Without either one of these the car wont shift properly. Check your govenor, it may be bad or stuck. nipper
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo small a radiator? Remembr you did go to a bigger engine nipper
Does a subarau produce Sludge in the motor
nipper replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can sit you know. We are very informal here :-p nipper
I wish the drivetrain would last like the engines
nipper replied to LegAC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO nipper
