Everything posted by nipper
Antenna Mast
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXttthhhrrrpppppttttttttt nipper
Congratulations to RichieRich !!!!
:clap: now how long before you stick a subaru sticker on the babby carrige nipper
97 legacy tps issue
nipper replied to river rat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhats the weather like when the light comes on, or doesnt it matter? nipper
1999 Outback-Jarring downshifting---TCU replacement?
nipper replied to sunking247's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis sounds familiar, like ive answered it before .... hrmmm http://endwrench.com/main.php?smPID=PHP::search_articles_action.php& http://endwrench.com/images/pdfs/994EATInfo.pdf nipper
Mouse/Rodent protection ideas welcome -Storage solution
If ti comes with a fan, wind out how much flow the fan is. Then get a 12 volt computer fan, a 12 volt battery, and a small solar panel to keep the battery chanrged. Just a thought. nipper
In theory there is a tupperware container for everything, mabe they have one for a car nipper
clutch throw out bearing sound?
nipper replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should be no noise. Confirm the throut bearing is properly seated on the fork with both clips. If it is still there you need to replace it. nipper
Antenna Mast
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine only goes up ont extension and goes GGGRRRRGGGGRRRGGGRR so surgery once i get over this cold. nipper
Slight Shudder when AC is Turned On
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust for the heck of it, check the motormounts too. Otherwise what you describe is normal. nipper
why is my car shaking????
Where do you feel the shaking the most, the fllor, your seat, the steering column, the console? Does it shake in gear? nipper
Antenna Mast
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bought mine new from https://www.subarugenuineparts.com/oe_parts_cat.html For my car it was 35.00 new. nipper
? for Subaru Dealer Mechanics.
nipper replied to submonkey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the records. Personally I would have suggested doing the timing belts. The car was close enough to 106K that it would have been worth while. All it would cost at that point is the cost of the part, as the labor is free. They make money selling parts, and it should have been suggested. nipper
POLL: 2 Coupled Engines
Tw engines in an SVX? one driving the front wheels, one driving the rear? nipper
Antenna Mast
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk i got a new mast. Is there anything i need to know before i attack this repair? nipper
05 3.0 vdc slight miss, coolant smell (searched)
nipper replied to ampsucker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo back and tell them your taking the tech for a drive, and demand it. If you can make the conditions happen on the road, show them. Then let them drive the car back. Pull into a parking lot and let them smell the antifreeze. It may be a subaru smell. My 1997 did it (till i rebuilt the engine). My freinds 05 Forester does it and 06 outback. I rented a new outback and it did it too. I talked to the svc manager and he said they get that complaint alot but, they can never trace it down. nipper
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShudder? Your loading up the engine, so a rpm drop then recovery is normal. Otherwise i would clean the IAC. nipper
Car won't start, no fuel.
Check the fuel pump relay, I dont remeber where it is on your car, but with no power at the pump thats usually the culprit nipper
is that timing belt idler pulley important?
A n ice thing about bearings, since they tend to live a nice weather sheltered life, they all have mfg names and numbers on them so its really easy to get a replacment. nipper
On the 60,000 mile belts i usually recomend every other timing belt change to change all the idlers. You can MAYBE make it to a third, but after that its just a matter of time. On the 106,000 intervals we have found out you need to do it at every belt change. It avoids getting stranded or even worse if its an interfernce engine. Glad your back on the road nipper
Centre diff lock on AWD auto
nipper replied to Fatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the mismatch between the two axles is too high for two long, the TCU will disconnect the AWD. Also if there is no pulse it assums the 2nd sensor is dead and disables the AWD. nipper
transporting gas
nipper replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is always 2 2.5 gallons on the roof rack. Thats what i'm planning on doing when i take a long driver into upper North Dakota (canada) this summer. nipper
Woof er um ers
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk so the slippery slope starts. I got a pioneer GM-6200F 120watt per channel 4 channel amp. I know the numbers can be fictional, but its bigger then i thought and has some mass to it. Questions.... The wiring diagram shows two 30 amp fuses in parallel feeding a common cable to the power side of the amp. There is no reference to the gauge of the cable. I dont want o ver buy, but it seems the kits are either 8 or 4, when im thinking it should be a 6. Also the kits show huge AGU fuses, when i would rather use the standard automotive type fuses if i can. Also i can see running the 4 gauge wire being a nightmare. Any comments? Also is a capacitor just for sub woofers? nipper
nipper replied to Fatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell the speed sensor is a square wave. No resistor would help there. 50/50 power split is difffernt from full lock. 50/50 on demand would be great. Wht someone needs to do is throw a three channel scope on the two wheel sesnosr and on the duty C solenoid and see how they all interact. From there we could make a pulse generator of some kind and dial in the amount of 4wd we want. nipper
there is supposed to be a code right?
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect. OBDI cars have a differnt emission standard then OBDII. nipper
2.2L knocking sound (sound clip attached)
nipper replied to JPX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou dont want to drown out that noise, that one you want to get fixed. If its a bad u joint get a used shaft or have a driveshaft shoop rebuild it. That one can total the car if it lets go at the wrong time. Its giving you plenty of warnings, this is one that you really need to listen to. Someone on the old gen list ignored it and it bent his floor and put a scary hole in it. nipper
