Everything posted by nipper
'04 Legacy spewing oil from passenger valve cover vent nipple. Should I get a reman'd long block?
nipper replied to rogo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat compression is pitiful, on a healthy engine it should be 180. Valve timing is off on that one side of the engine.
does ATF cooler increase or decrease engine cooling efficiency?
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is neither as the heat load vs the air flow is very small. An AC coil can add much more heat if the radiator is on it's way out. Depending where you live, you have to look at it more as a heat exchanger then a cooler. The radiator assits on heating the fluid in winter, so I always mount them before the radiator. I run a temp gauge so in winter the difference is notable.
Carlisle Import Meet 2013
Next year the Justy can go all hysterical, i mean historical
Subaru No-back
http://jalopnik.com/the-subaru-brat-is-practical-for-the-proletariat-508307924
Yes the VW numbers were down this year.
Odd we were all there by noon. Last (or first) row in the Asian section (last row before the hill). The Asian Passport stamp table was right there next to us. The Datsun convertables were right across from us.
I was there for Sat and Sunday. It was the year of the SVX's. There were four of them, some imps, a 97 Lego that was all sort of tastefuly modified, a couple of toyoroos, and the Justy. There was an 80'6 Turbo Hatch with 86K on it, but needed TLC. There were two riced out Imps, but they were antisocial and hung out with the (gasp) Toyotas. There was only one SVX there on Friday so it won an award for the most rare car. *mumble* next year i will have to get the Justy there on a friday, show up that SVX I will. Justy got a lot of attention. Friday I heard the place was crowded. Saturday not so much, and sunday was empty. The weather was overcast on Sat and sunday was cold and wet on and off. There were not as many vendors as last year. The prettiest grouping was the Opels. SAABs were there in numbers to qualify as an army. Quite a few Citrons. There were so many TVR's that i expected them to be killing people just to keep their reputations intact.
the dreaded torque bind? ..no not meeeeee
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fuse holder only completes a circuit that carrys a 12v signal to the TCU. It is not really doing the work of holding the solenoid open. Any spare fuse in the car will do (in the fusebox)
Oil light comes on at stop light
Yay i like simple happy endings.
Frankenmotor dyno results
Ops i meant no offense taken. Anyone here who knows me knows i never "parrot" things on the net, just that term is sort of insulting. i am honest and give the sources, provide when asked, or (shock) am honest enough to say I don't know or admit i learned something. I was also sort of surprised the numbers were so low at the rear wheels, I thought they would be a little higher.
BTW it is great to see all these dyno curves. I will have to bookmark this for when people ask me if i know where any are. Good seeing them all compared, granted different machines, but close enough for comparison sake.
Sources for the sensors(subaru specific) - My automotive engineering degree 30 plus years in the business Haynes manual (if you want I can even specify the pages, but hey, what do I know) Subaru Factory manual This obscure thing called google, i know people never heard of it before. And offense taken. Generally speaking, depending upon the mfg, they may use either sensor for timing and injection, or both with split duties. They can also be used to check against each other for a timing belt starting to stretch, but usually by then it is too late.
Sources for the sensors(subaru specific) - My automotive engineering degree Haynes manual (if you want I can even specify the pages, but hey, what do I know) Subaru Factory manual This obscure thing called google, i know people never heard of it before. Generally speaking, depending upon the mfg, they may use either sensor for timing and injection, or both with split duties. They can also be used to check against each other for a timing belt starting to stretch, but usually by then it is too late.
East Coast Subie people need Colorado parts?
Just a little education for getting here. NYC doesnt have freeways, but highways and parkways, they are not the same. Parkways are no trucks due to lane width and low bridges. Also depending upon what Uhaul beast you are bringing here, be fully aware of the height of the truck. If it is not marked measure it and read the bridge height signs. And welcome to the land of alt side of the street parking http://www.nyc.gov/html/dot/html/motorist/alternate-side-parking.shtml Get yourself a cheap bicycle and multiple locks, easiest way to get around locally at times. Drop me a line when your settled, maybe we can make a sooby welcoming party for you.
Oddly i am the same but going east bound
Crank sensor is for ignition timing (piston position) and the cam sensor is for injection timing. The car can't run with a bad crank sensor (no spark) but I can't swear the same for the cam sensor.
subaru outback 2002 engine problems
nipper replied to kamnk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles/kilometers on the car. When was the last time the timing belt was changed?
- Stuck in 3rd Gear ! help - its finals week!
Low mpg and slightly low power... Starting place?
nipper replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the engine temp gauge get up to the 1/2 point when the car is warmed up? Car could be due for a full tuneup, proper plugs, wires, air filter fuel filter, pcv valve. How does the car run otherwise Also another thing to look at is a stuck brake
Year and mileage? What is your idle RPM? Check your alt output (humor me) Get a gauge, they are cheap enough for test purposes. If you want to mount the gauge get a name brand. Get one where you can actually read the low end of scale. When it stalls does it sputter or just cut out.
What makes the sub-fan come on?
nipper replied to Speedwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's when it is supposed to come on.
Justy digital clock, Justy fender liners (front), Justy air intake snorkle (by the battery) And You being in brooklyn, your just the next county over.
trouble code light on the front of ECM/ECU stays on? 1984 ea81t wagon
Coil failures are rare in coils as a group. They are not rare in 20 plus years old can type coils that have never been replaced.
I will be having the Justy on the grounds someplace
I honestly would just swap another coil in and see what happens. It is hard to bench test a weak coil as not only do you need the heat, but you also need the 60kv to test the insulation.
