25
Everything posted by nipper
Get yourself a haynes manual to start off with, it will make life easier for everyone as we try to explain things. This will also tell you how to pull the codes off this car. Since the o2 sensor is at the heart of the emissions system, i would put that on the list of things to replace, as that has a huge effect on your gas mileage. There are a few things that this can be, it can be the Idle Air control motor is sticking (what happnes when you turn on the a/c), it can be a bad knock sensor, it can be the tps. Which temp sensor did you replace, hopefully the one for the computer. nipper
SIgh ... How many miles are on this car. Ok here we go. First do all the tires match. Secondly how long has the car been doing this. Next when was ther last time the tranny fluid has been changed. A bad/stuck duty C solenoid will throw a code. Put the fuse in the FWD fuse holder and tell us what happens. Also since this is pre 1997 1/2 it is very possible that the AWD unit is wiped out and needs to be replaced. Everyone seems to forget that the AWD unit is more then just the solenoid. Its also a spool valve and seals. Pre 1997 1/2 the seals go bad, the aluminum internal housing can wear away causing TB. Also if he has been driving like this for a while odds are the damage is done. nipper
Your prefered cooling system cleaner??
nipper replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To clean radiators you use dawn and warm water. It should get the scum, especially if its from oil, but old antifreeze that becomes gum not much you can do, and there is nothing you can do about mineral deposits (hence why you dont use tap water in a cooling system. The are rock hard, and the only way to get them out is to recore/rod or replace the radiator. nipper -
An o2 sensor can do weird things. That is usally the first thing you replace on a failed emissions, especially if it is over 60,000 miles for ealry subarus, 100,00 0 for newer. nipper
This is subjective, but in all honesty its rare for a sooby impeller to fail, unless there are many many miles on it. You need to watch the flow in the engine, and a worn impeller would cause over heating but not the puking. ANother possability is a clogged raditaor, but again no puking. Puking is from the exhaust gasses pushing the fluid out of the raditor cap through the overflow. nipper
Water vapor is normal on a cold engine, but not usually out of the crankase. you have blowby when cold (maybe warm too but hard to tell unless your burning something), the next question is how much and why. A compression test would help, if the numbers are even and high, its just a high mileage normal engine thing. Its nothing that is going to be disastarous today tomorrow or next month, but it would be nice to dig around a bit. Also do change your pcv valve. nipper
Well it would be helpful if you told us the mileage on th car. Secondly what are your oil change intervals. it can be a sympton of blow-by, can mean too many short trips, can mean absoloutly nothing. If your not loosing coolant i wouldnt worry about it. Remeber oil in these engines does vaporize a bit, mix that with humidity in the air, a little blowby and you will see that. Clean the cap and keep track of it, but i wouldnt panick. Now the oil levle, chexk the bottom of the engine to see if it is wet. Rule out oil leaks (subrua can leak and not leave any drips). If you burned it you would have seen smoke at that low a consumption. Have somone drive behind you and watch for smoke. nipper
er um... no 2 4 6 8 10 12 14 16 are easily balanced ( one up one down) 3 is not and usually use a counterbalance shaft or some sort of weight to make them smooth. Only GM made the colassal mistake of converting gas engines to deisel. Everyone else on the planet had the good sense to start from scratch. The only thing that MAY be common is the block casting. As far as fitting anything else under the hood, it isnt going to work easily. The subaru engines overall height is far lower then any V or inline engine. Also goiuing to a non oppsed engine witll generally drastically change the handling, as the car would be nose heavy. nipper
Rack Leaking
nipper replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Common thing is for the hoses O rings to go bad and leak, check that first. Subaru racks dont leak when they go bad, they just get very stiff. nipper
