nipper
Everything posted by nipper
  1. Blu2, which has no personality yet except for a grumpy starter drive, will soon start becoming "my"car. For the 2005 - 2009, I would like to keep from reinventing the wheel. Has anyone made a cutoff switch for the ABS, If so, where did you tap to put a switch. The 2005 does not have a FWD fuse. It actually usses the wheel speed sensors to make sure all the tires match, etc, to keep from damaging things. Has anyone installed a AWD loc switch. I am not sure If i need one yet or not (will find out soon) but I know the AWD has a different curve then Ol Blu did. i just want to keep my options open.
  2. Huge clue is the FWD fuse in. AFter the car is warm go to a paced parking lot and make a tight figure 8 with no throttle or very little. Does the car lurch or fight you at all? Do all the tires match? What condition is the tranny fluid in?
  3. What is your budget? A din wont fit as DIN didnt exist then. http://www.vintagecarradio.com/store/index.php?cPath=20_68&osCsid=3b014d528d72e8eafca53abac2db6ef3 may not fit. They have great fitting system. I know others have put real radios in these cars, Can we have a pic of the dash please?
  4. Change the T-stat, use one from subaru, as even the most expensive aftermarket one wont be as good as subaru's. http://opposedforces.com/parts/legacy/us_b11/type_7/climate/heater_system/ Thats the heater system. The heater core box http://opposedforces.com/parts/legacy/us_b11/type_7/climate/heater_unit/illustration_1/ When you switch between fresh air and recirculate do you see a flap moving anywhere? Since I can see leaves and such, drop your blower motos and vacume it out and as much as you can inside the heater box. That may help. And yes your running a little cool, and a little cool on a 4 cyl can make all the difference in the amount of heat available inside the car.
  5. If you need it ASAP order it online someplace. If you found what you think is a OE replacement, just compare it to the one you have. if it is an original it will look alike. If it is better it should have a wider openining then aftermarket. If your really pressed for wheel just take out the T-stat till a suitable replacement arrives. Your heat will suffer and so will MPG, but for a few days it wont hurt.
  6. I sense autocorrect at work here If your dripping fumes bedside, something is seriously wrong someplace. You can try JB weld. However you shouldnt be dripping liquid out of the chrarcoal canisiter cracked or not. Somehow liquid fuel is getting sucked into the canister where it is just supposed to be fumes.
  7. I have something like this, its called a CVT. The transmission does almost all the work, engine RPM rarely raises over 3800 RPM on WOT.
  8. Keep in mind that is all in a test lab with no wind drag on an engine Dyno. There is some truth to this. If you open the throttle wide and climb in the gears as quickly as possible yes you will get the best MPG. However screaming around in 2nd gear because the speed limit is 30 mph will hurt your mpg and engine life. Lab tests are great, but the real world has 100's of vairiables and everything on a car is compromise to work within these variables.
  9. Pretty Pretty car. Try not to molest it too much, as it looks sweet.
  10. It is a limited so it is on timer. The car had a Auto Dimm mirror as an option and the connector is there under the headliner. I am just not sure where it is located and there is no obvious way the dome lights come down, though they probably just snap in. Thank you though.
  11. I am installing a aftermarket autodim mirror in Blu2. Looking at the wiring diagram all the connections are there in the roof, but I am not sure how to go about getting access to the plug. My gut tells me it is behind the roof light - sunroof switch. I havent looked at the FSM yet as I was just wondering if anyone has gone there before me.
  12. This doesnt look good. I was hoping for an oil leak, a large one. YOu can buy an oil pressure gauge for less then 20 bucks, but if an engine is failing from poor oil pressure, that burning smell is what you get. The engine being hot, is that a observation or from the engine temp gauge on the dashbaord? What does the coolant in the radiator look like? What noises are the engine making?
  13. I tripped over this, don't know if it will help anyone http://www.alcyone.org.uk/ssm/
  14. http://en.wikipedia.org/wiki/Subaru_Alcyone_SVX There are differences, but I am not seeing any in the engine.
  15. You would be surprised how many people do not think of checking the oil. Did the oil look and smell ok? You can get a cheap mechanical oil pressure gauge for testing purposes, or you can mount it on the dash someplace if you want. Oil pressure right now trumps all other issues. Is there any sign of oil leaking at the front of the engine?
  16. I am going to assume someone has checked for oil in the engine?
  17. There may have been some emissions or lighting or saftey stuff, but they were all built in Japan. I can't see a difference either.
  18. Well you came up with a code so we don't have to back door guess it. Duty C will resolve it and should help with the MPG. You will want to replace the PCV valve as it has never been done, and think about a tune up if it is overdue
  19. Never seen the handshake work in a 98. Are you having any driveability issues. Any CEL on? How does the car do in tight circles? How is the mpg?
  20. http://japanesenostalgiccar.com/wordpress/wp-content/uploads/2012/04/1979-Subaru-BRAT-01.jpg Thats a 1979 and deserves to be saved
  21. It is, that is it's strength and weakness. it is made for performance traction not to get you unstuck These are center diffs http://www.autozine.org/technical_school/traction/tech_traction_4wd_2.htm These are rear diffs, start about page 4 if you know the basics already http://auto.howstuffworks.com/differential.htm
  22. http://www.caradvice.com.au/218590/subaru-brz-convertible-undecided/ Thats concrete for toyota, not sure about subaru yet
  23. http://www.cars101.com/subaru/subaru_history.html They were converted for subaru by a coach builder.
