Everything posted by nipper
Full rebuild or top end?
nipper replied to jimbo1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour a little under my limit for a replacement rebuild. I use 180K on a subaru as after that you will generally start to develop blow-by. http://www.ssisubiespecialists.com/ have a real storefront, so thats a plus. hehe they even passed zoning http://www.blairtownship.org/TB_minutes_feb_14_2012.pdf
98 outback no cruise
nipper replied to ivans imports's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou dont need test switches, just a meter and the ability to adjust them. Usually they just need a tweaking.
Suzuki Sidekick vs Subaru
Never said they didnt exist, just nthat not all of them have it. Head gaskets do weep with time, it is old age. We leak with old age too. Just due to subarus boxer design whatever leaks usually falls on the exhaust system and becomes quite noticable. Funny how I see more people upset over head gaskets then 1999 transmission failures which seem to happen with more regularity then HG for that year. Now Suzuki Sammis ... they dont have HG issues unless they get old enough, but do seem to like to get belly rubs.
It is. For instance if they all have it then both of mine should and never did. I know countless of others that did not. You do not see 100 of 1000's of complaints on the net or in the news about it the way you do about GM or Neons. the best guestimat put out is about 20% of the 1996-2001 suffer from it and even a smaller amount of the newer ones (external weeping leaks). Using your logic all cars have bad head gaskets as if any car lives long enough it should need one. be careful with blanket statements. Thats the last I will respond to this misinformation and will go back to the topic at hand.
There is a lot of lift stuff out there for the Samari. I would actually lean towards the Sammi for very rough trails. There must be a way to get more power out of it. http://www.lowrangeoffroad.com/index.php/suzuki/samurai.html I know I know I didnt say subaru, Just may be more economical if there are a ton of bolt on parts out there instead of heavily modifying a sooby that may be not quite up to the task.
Not all, this is a myth.
Oil filter question
nipper replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the larger filter fits and meets the same criteria go with it. It helps to add some capacity. And yes fram hate is justified as pointed out by many of the studies on fram construction and performance, not including the recent recall of filters made for sunaru by fram.
nipper replied to ivans imports's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is one of the pedal switches, a fairly common failure mode on this generation, otherwise the cruise just works till the doors fall off.
do shift kits for auto lego's exist?
nipper replied to soobie_newbie67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- HighGuysLifts.com---Lifts for all models of Subaru!
Any pics of the lift kits?- knocks while driving in straight line
U joints. if there is knocing coming from there check it NOW. You do not want to drop a driveshaft at any speed. Very ugly. First look for any freeplay by hand. Rotata the shaft and loof ro any delayed movement in the yokes. Next unbolt the drive shaft and check the universal joints to see if they are seized. This can be a potentially dangerous situation which needs to be investigated.- Tell me EVERYTHING you know about Ski Team Wagons
http://www.indysworld.com/vehicles/1980-skiwag/skisoob.html Just as a refernce- Historic Subaru Forum
- Calling all tranny guru's. Has anyone ever......
http://en.wikipedia.org/wiki/List_of_Subaru_transmissions There is a list of gear ratios to get you started. OOOh do i get one free name calling?- Mazbaru?
Isnt sort of hard to drive with all those jumper cables laying about?- Mazbaru?
but it is not all about hp, but also weight. That will make the car very nose heavy.- Replacing worn starter contacts mishap
nipper replied to rendoll911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo much heat/vibartion/ozone there to have any epoxy hold it togehter, and really whay take the chance on being in the middle of no where and have the starter fail.- Blinkers acting funny
nipper replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the bulbs out and check them with a meter. Dual filament bulbs may look like they are ok but can be internally shorted.- How would you fix this?
nipper replied to ibroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoesnt the boot just snap on to the trim?- I think i have owls!
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.autoblog.com/2013/02/12/woman-finds-live-owl-trapped-inside-grille-of-her-ford/ I checked, I dont have this problem, and yes I still have them.- How to tell if your $600 craigslist Subaru has bad struts
nipper replied to SubieTrav's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats actually can happen. WHen I boughtg Blu2 his rear struts were so bad he was almost bouncing that badly. I considered him dangerous.- Fram / Subaru Oil Filter Recall
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI buy Pureone or Mobile One filters for Blu. I buy a standard Ford Truuck Purolator filter for the Justy. Fram, the only thing I get from them are air filters, and only if I have no choice.- non-resistor spark plugs
nipper replied to subarugt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didnt even know they still made non resisitor plugs to be honest.- Fram / Subaru Oil Filter Recall
http://www.fram.com/sites/default/f/uploads/en/recall_notice_02052013_for_distribution.pdf- Windows fogging, antifreeze smell and leak under the car
nipper replied to Rxb6170's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your coolant level. If the leak is coming out of the HVAC drain hose, then your hosed, so to speak. You have a leaking heater core. - HighGuysLifts.com---Lifts for all models of Subaru!
