Everything posted by montana tom
Possible cooling system issue
montana tom replied to 07outback12's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs Bennie asked why was the rad replaced ? Fill the engine from the upper hose , then attach and finish by topping the radiator. Strong chance you may need head gaskets.
Ball joint not removing from knuckle
montana tom replied to Jadu108's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo build the tool to pull ball joints , you need a few pipe fittings ,a piece of all thread some nuts and a lug nut . You do need to drill one hole and weld the lug nut on the all thread. That's it. Its about a half hour job. If you don't have a drill or a welder , pay someone who does. A teenager in high school can build one of these.
Gear positions drifting to the left
montana tom replied to Theophilus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is an Ebay item number for the original equipment complete part. 132901914818 type this in the ebay search.
Rear caliper stuck on top slider stud
montana tom replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr to Rock auto as a core return...
Sudden loss of power
montana tom replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can get it in a dark place , when its acting up . I think you will see the catalytic glowing . Too much raw fuel being dumped.
ABS Module, different models question.
montana tom replied to Septu301's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a long shot for you but worth checking. On two different outback's I had a persistent abs light. Code reading said the main unit was "stuffed". or up the creek. There is a ground wire for that whole unit. I believe it originally was bolted under part of the P.S. tank. I have found this ground moved and loose and not moved but also loose. Both cases caused a main unit failure code but the fix was as simple as cleaning and tightening a ground. Take a look it won't take long.
montana tom replied to Septu301's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat symptoms are your brakes showing ?
05 Subaru Outback Motor R&R ??
montana tom replied to mickytrus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would not attempt changing over. You would need the ecm and the harness. Non turbo 2.5 would be sohc Smoke out the exhaust sounds more like your turbo than head gaskets.
Ej22 headgasket part numbers
montana tom replied to Raynman1989's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe gasket's, are a pair of Subaru # 11044AA114 The other is the ebay item number that you would search for on ebay. # 141665882014 That particular seller is where I buy all my subi head gaskets .
montana tom replied to Raynman1989's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is an ebay item # ( 141665882014 ) for original equipment gasket set $86.00 delivered
montana tom replied to Raynman1989's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Ray ; I show the 90 -98 2.2 using the 11044AA114 gaskets
1992 Legacy Similar to later years?
montana tom replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your one daughter's 96 is an outback it "could" have the 2.5 dohc Pulling the engine on one of those years is very straight forward. 1-2 hrs
Water Leaking into roof and rear hatch - ‘05 Outback
montana tom replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the 2000-2004 outback's ,the front drain tubes are visible with the front sunroof open. The rears can be reached with an extended blow gun from the open rear sunroof. The reason to drop the headliner is as follows. The channels that the water runs in to reach those tubes , can leak at their seams. Resealing the seams with silicon stops that. Also small hose clamps on each drain tube can stop leakage as well. Very common for water to back up and fill the map light housing, then dripping out as you drive. I currently still own a sunroof car (the wife's) Once she decides to let that one go … I'll never own one again. Other than the extra light in the winter , we never open them.
montana tom replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a sunroof car then ? If you go to remove the headliner be aware they used Velcro in places near the sun roof. I recommend trying air pressure in the drain tubes before pulling your headliner. Also headliner's stain very easy from dirty fingers … use gloves.
Antifreeze in Oil
montana tom replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it mixed bad enough, then there is most likely bearing damage. Otherwise, if you think its ok , flush it out , then use #642 Subaru head gaskets . Myself , I would search out a replacement motor.
High RPMs Leaky Oil gaskets, Low RPMs not so leaky?
montana tom replied to suprunner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, its been proven.
montana tom replied to suprunner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttps://www.ebay.com/itm/NEW-Genuine-Subaru-PCV-Valve-Impreza-Forester-Outback-Legacy-WRX-STI-XT-OEM/132817578967? hash=item1eec8b6bd7:g:7w4AAOSw0e9U1oiJ that is the 2002 up and this is the early one https://www.ebay.com/itm/Genuine-OEM-Subaru-PCV-Valve-Impreza-Forester-Outback-Legacy-SVX-Loyale-WRX-NEW/132746993512?hash=item1ee8565f68:g:rDkAAOSwNSxU5Szp
Great to have you back USMB!
montana tom replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChecked several times each day ! Glad its back !
09 Forester Hill Hold feature? Your experience
montana tom replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMilty; Hill holders work great! They had them in the older subi's glad to here they brought them back! The clutch pedal moving is what releases the brake... at least it was on the older ones.
02 outback temp sensor readings
montana tom replied to LEOD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo the fans run if you turn on the A/C ?
Baja troubles
montana tom replied to Imprezafan96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe are talking about a 2003 2.5 sohc. They drip coolant/oil and overheat from a lack of coolant . A 2.5 dohc has a poor seal at the fire ring and boils coolant and that creates air pockets.
Merry Christmas and Happy Holidays to everyone!!!
montana tom replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you 3 Pin! Same to you and yours!
4th gen. driver's side low beam...wtf?
montana tom replied to 5000fingers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the passenger side had the wire clip... so did the drivers side...
Baja Chokes + Radio & Instruments Go Dead
montana tom replied to rp2813's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the pos cable at the starter, check the neg cable same area. Closely inspect the smaller hot wire from the battery to the fuse box.
release my hood
montana tom replied to slickwelder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen one won't pop up I slide a bic lighter under a front corner, pops open every time.
