LPGsuperchargedBrumby
Everything posted by LPGsuperchargedBrumby
anyone know how many degrees advanced you are when you run out of advance adjustment on a ea81 distributor? cos thats where my'n is, being on lpg i decided to to push my luck and see how far foward i could advance my ignition timing without it pinging......its now advanced till there ain't no more, and has been for the last 3000km. i don't think it could be advanced any more because it sometimes stops dead when being cranked to start, but it runs like champ.
Head bolts
LPGsuperchargedBrumby replied to [HTi]Johnson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
they're about grade 10, i hardness tested a couple (i was bored) and they're better than grade 8 but not as good as grade 12 -
EA81 gaskets etc in New Zealand?
LPGsuperchargedBrumby replied to cubastreet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
try this guy, ive got stuff off him in the past http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Subaru/Engines-drive-trains/auction-56483503.htm -
Look what I found.....
LPGsuperchargedBrumby replied to waimaks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the flares are custom build jobs, like everything else he's done on that thing -
It is alive....Supercharged EJ22
LPGsuperchargedBrumby replied to Matty B's topic in Subaru Retrofitting
any HP & TQ numbers yet? any improvment in fuel usage yet? -
not that high 130psi on a warm day, gets right down on a cold day 30-40psi at around 0 deg C -
hmmm if i was going to do it again i'd go blowthru. still, the way you got it setup will still give vacuum for the distributor advance which can be an act on a blowthru setup -
Soobie Trailer
LPGsuperchargedBrumby replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you'd have to build some kind of chassis or subframe to spread the load hitch evenly under the body. its one of the downsides of the monocoit bodys -
i want it..... -
that looks kinda familier....... if you wanted to you could get an alcohol able carb and run water instead of fuel ,instant water injection (after a leaning the jets), thats what i ended up doing. i also used switched electric fuel pump so i could turn the water off when air temps got too cold why did you go draw thru rather than blow thru? -
It passed Woohoo!
getting insurance is a pain (& costly ) when your under 25. it helps if you can get someone to lean on them,when i was 18 i wanted to insure my vitara, the best i could get myself was $1900 per year on a $12,000 4wd. Dad said if they didn't do better he'd dump $5M worth of liablity insurance he had with them, result was $1100 per year....much better -
Hydraulic hybrid technology!
LPGsuperchargedBrumby replied to sketron13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i like the idea of this system but some of the things in it or claimed don't make sense to me. it would work well in stop/go driving, but unless you have a huge accumulator, a long hill or even a strong steady headwind on a long drive would drain the reserve pressure in the accumulator faster than the little engine could restore it. the regen' braking i did like, and you should be able to get more than 15% back as im pretty sure the limit on batterys is how fast they can be charged, hydraulic accumulaters don't care how fast fluid gets pumped into them,only the max pressure they can tolerate. im a M&D Engineer trained in (among other things) hydraulic system design and in my professional opinion:confused: the the cost of the pump,hyd' motor, accumulator and valving for a setup like this would suk the big na-na -
A Subaru Isuzu?? Slight 56K Warning
LPGsuperchargedBrumby replied to fangster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
they are one of the standard subaru mirror types, there's one that parks near my work that has them -
Hmmmm that sounds like something that a dealer of the other kind of meth would say......
WJM, this just proves your 'old school cool' at heart
More Vortex-XT Woes
thats what you get for living on the wrong island..... -
Running LESS than stock boost.
LPGsuperchargedBrumby replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
- the spring in the waste gate controller needs weakened so the control arm will move at a lower pressure. Just the opposite of adding a spring for more boost i've seen it done with a spring setup to assist the rod opening the waste gate, it just takes a bit playing with different spring weights -
get the people who are cutting and bending your alloy to anneal it along where it needs to be bent, then you can use 6061 T6 rather than the softer 5052
13b Turbo Rotary into Legacy
LPGsuperchargedBrumby replied to DJtheGOD's topic in Subaru Retrofitting
its been done before...in here in New Zealand there was a subaru leone RX sedan AWD with a 13b turbo. used to run on the national rally circut -
Subaru must have been nuts!!!
LPGsuperchargedBrumby replied to pheonix165's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think its something to do with the piston speed, ea81's are a short stroke motor so 4000rpms is probibly not that high a piston speed -
Question about spark color
LPGsuperchargedBrumby replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my spark is yellow... i put it down to dirty plug electrodes, its never caused me any problems such as misfire etc
