Everything posted by TheSubaruJunkie
Removing Struts EA82 (How)
Wow, nevermind my previous post man. You just created like... a weeks worth of work there. You are already past the point of no return, the information I posted above is useless to you now. For future refference maybe...
You are way overthinking this whole process dude. Lift the car into the air, undo the strut bolts. Support the vehicle with stands, place jack under the engine crossmember. Remove the bolts holding the crossmember to the frame, lower the engine crossmember 2 or 3" That should give you plenty of room to install your strut blocks. -OR- Remove the bolts holding the strut to the lower control arm (before ever unbolting the strut tops). With the strut top still bolted to the body, and the lower bolts undone from the steering knuckle/lower control arm.... use a prybar (or some bodywieght) and force the lower control arm down, this will remove the bottom of the strut from the steering knuckle.. Now unbolt the strut top and let the strut fall out. However, if you are installing a lift, you will still need to unbolt the engine crossmember to make room for the reinstallation. Unless you want to spend an entire weekend fighting with it
My latest subaru engine improvement
All I do is pull the manifold, then walk away. Come back in 30min and all the coolant had drained to the propper level, and evaporated. Either that, or just pull the radiator. Sooner or later, all the coolant will be gone Better hope that hose doesnt get too close to your exhaust. I imagine if you sprung a leak in any of those hoses, it wouldnt take but a half a mile for every last bit of your coolant to drain out.
gst???
Thats probably the first time anyone on this side of the Atlantic has seen that thing.
Front Diff locked rear diff Open whose done it? whats the results?
Spinning is bad. Crawling is the name of the game
UPDATE 7/12: Brat Rebuild Progress: Halo Stripes
Are you painting your chrome bed trim along with the topper & body?
In the wheeling world, its best to have your front locked and your rear open if you had to pick only one. This is for technical, low speed crawling or obsticles. Pros: The tires with the most weight over them, has the most traction & pull you over obsticles. Cons: Steering is going to be a ***************.
Nevada Camping Trip
Let me know what kind of help you need, you know im willin to help. Just sucks sometimes makin that drive to reno and back. Expecially when tow trucks have to bring me home.
Nevada Camping Trip
Not sure, maybe with enough straps.
Nevada Camping Trip
Well okay.. guess last weekend didnt work out as planned. JB. I need to make my way up there anyhow. its been too long and the 4Runner is bugging me about the Moonrocks. I have some things I need to deliver to Greenley as well.
On board air?
PSI is one thing. CFM is another. (cubic foot per/min) CFM is what we are after. Sure you can get that $35 pump to build up to 120 psi (mine will do it too). It just takes forever to do so. Its because the volume of air it is able to pump diminishes the higher the compression gets. I paid $90 for my pump (has a nifty bag too) and i believe it pumps at 1.1 CFM at 0psi. But once it reaches near 30psi it is only pumping at .7 CFM, and if it were to ever reach 100psi, it would be close to .3cfm I think when I was doing some research on the Yorks they can pump something like 3.3 CFM at 50psi and that is depending on the RPM given to the pump.
Craftsman storage cabinet
Looks nice. Is it rated to carry combustibles and aerosols?
On board air?
I have been slowly building all the pieces I need. I have $0.00 invested so far, and I have a 5gal tank (two 2.5gal tanks side-by-side). All the hose & fittings I should ever need. Including a 1 - 100 psi guage for mounting pretty much anywhere. Also a few switches that are pressure controlled to do some cool things with Just gotta find me a good york on the cheap, and make the brackets.
Rx Rotors and pads
Glad to hear its still alive and keeping people happy. You should do some reading and learn how turbo's operate, what keep turbo engines happy. Subaru's make great first cars, however, the EA82T has gotten a bad wrap by even the most experienced Subaru techs on here. There is also a ton of subaru specific documentation around here that will help you. Hint: Search for HTKYSA.pdf (How to keep your Subaru Alive).
Rx Rotors and pads
Yeah I think i saw this thing on Craigslist last year with the blown motor. He was asking about as much as I sold it to him for, running perfectly tho when he bought it. Still regret selling it, but knew someday it would find its way around to the USMB. It has a ton of potential, the intercooler should not hamper its smogability.... it didn't here in sacramento. Anyhow. The motor he blew up wasnt stock, if you replaced it with a stock motor it should last a while with propper maintenance. However, with this heat... DEFINATLY GET AN INTERCOOLER! and a bypass valve because they do not come with one stock.
Rx Rotors and pads
Does it still have a huge TOOL sticker in the rear window, or did dude remove that after he bought it? If this is the same car I am thinking of, it used to belong to me. And used to have an intercooler installed. And would have looked alittle something like this:
On board air?
Good luck running an air compressor for long off a power inverter. Unless you buy a real expensive inverter. A/C pumps are the easiest way to make alot of air quickly. And cheap. You should look for a York air compressor. they have a piston pump with an enclosed crankcase that has the oil. The air traveling through the pump does not need to be lubricated, but it does need to be filtered. You can find these pumps on ebay fairly cheap. Might have enough room to mount em somewhere on a EA81. Right now, I use a portable pump that plugs into my cig. lighter. Im about to convert it over so it clips to the battery itself instead, and wire up a second battery. This is all for my 4Runner however, which I air down quite frequently. And airing a single 35" swamper from 8psi to 35psi can take quite a long time! This is why I cannot wait to rig up a better onboard solution!
Rx Rotors and pads
Dude... are you in Yuba city CA?? Does that RX you have, have a boost gauge mounted to the left of the steering wheel? Where the rear defrost switch would usually be mounted?
My fleet of JNC's
Damn I was alittle jealous you got that '73, but now I know it is in better hands!! I say you put the Subaru in front of the other projects, and keep us all posted on its progress!!
Rattle can, rims = question....
Yeah, just replace whatever layers you would have added in clearcoat, with additional layers of paint. Ive only used clearcoat once on rims, and that is cause I masked them after a few coats, and when i lifted the tape it ruined the finish of the paint. So i added a couple coats of clear to bring the gloss back.
Some interior, stereo, CB Radio work on the 4Runner
You know the saying, you get what you pay for. I will continue to search and report back here.
YEah as soon as I installed it, i heard some fizzling and then saw smoke comming from inside the unit. It was an extremely cheap piece. There were no RCA pre-amp outputs. No RMS rating and entire stereo felt cheap and ready to break. I sent it back for a full refund, and now my truck is without a stereo
Rear Disc
Tell the parts guy you have a 1987 RX Turbo. 110% of every RX ever made came from the factory with rear disc brakes. Anything listed in their computer will work for your setup.
Nevada Camping Trip
I say somewhere off Highway 50, that way its kinda a equal drive for everybody. where was the place you took your Scout? Is that subaru safe?
been a Lot of posts for questions recently
More stickies wont fix the problem.
