Everything posted by TheSubaruJunkie
Studs.. or rip them out...
TheSubaruJunkie replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
me and a buddy pulled the studs from his tires. it was a pain in the rump roast. Used needle nose pliers to do it, and took a couple hours to do all 4 tires. -Brian -
Was playing with the video program. Made another video of just me and the toyota.
Reno-Tahoe Wrenchfest...
TheSubaruJunkie replied to NV Zeno's topic in Meet n' Greet. Your USMB Welcome Center
I have erands that i need to run tomorrow too. -
Some AWESOME wheelin this last weekend, 10/13/07
TheSubaruJunkie replied to TheSubaruJunkie's topic in Non-Soob Off Roading
Download Limit??? How do you live? -
No wheelin for me in the Legacy. And I stated above Sundays wont work for me... your guys yards aren't open :-\ -Brian -
I live in between. Im probably as close to 50 as I am 80, however if we traveled up 50, it would take us to carson city, then its another hour to reno. Taking 80 is also alot faster as I can cruise at 85+, whereas 50 is 35+ past Icehouse road, and 2 lanes... twisty and im usually stuck behind a motor home or a 70yr old. -Brian -
Neither. I hate traveling 50, and 88 will be closed shortly. I take 80 into reno. Jibs lives up highway 395 north of Reno (or west, northwest). -Brian -
EJ with a Carb and Disty what do you have?
TheSubaruJunkie replied to Scott in Bellingham's topic in Subaru Retrofitting
Here are the coils. This is the coil for the distributor mounted module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=IC24&Description=Ignition+Coil Here is the connector: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=ICC1&Description=Ignition+Coil+Connector They list a coil for a Fender Mounted Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=IC21&Description=Ignition+Coil However, for this application I believe you would want the distributor mounted module. Correct me if im wrong? Prices like these make it seem better to buy new (reman) than trusting a junkyard part. -Brian -
Bored at work, I used my Napa Prolink account to look up Distributors for the '82 Escort. They list two. One with an attatched module, and one that has a detatched module. Napa Links: Attatched Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NRD&PartNumber=482493&Description=Distributor+(Electronic+w%2fo+Module)+-+Remfd Detatched Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NRD&PartNumber=482492&Description=Distributor+(Electronic+w%2fo+Module)+-+Remfd Module for distributor attached model: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=MPE&PartNumber=TP30SB&Description=Ignition+Control+Module Fender Mounted Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=MPE&PartNumber=TP40SB&Description=Ignition+Control+Module I think i'll look up coils too. -Brian -
Use the tire calculator and punch in your stock tire size. Then find out what 14" tire will give you the same diameter. Then goto TireRack.com and search for tires matching that size and find one you like. Ive run tires as wide as 205 on my old Brat, they were 205/50R15. -Brian
My ECU Scanner reports back intake manifold pressure, so i think there is some sort of boost sensor. -Brian
Going to the junkyard this weekend scott. Im sure I can find a '82 Escort. I'll report back to you if I find something. -Brian -
Pictures needed of past WCSS's
TheSubaruJunkie replied to Qman's topic in Meet n' Greet. Your USMB Welcome Center
Here Ken. These are links to my photo albums from previous WCSS's WCSS3: http://usmb.net/gallery/album116 WCSS6: http://usmb.net/gallery/album273 And here is an album full of various members photos of WCSS7: http://usmb.net/gallery/wcss7 -Brian -
i got my WEBER :)
TheSubaruJunkie replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check ebay for a new filter kit, it will come with the clips you need and its always good to have a spare filter anyway. The adapter can be had for about $40 if i remember correctly. Search the web for weber dealers. -Brian -
1980 gl5 maby 79 1/2 breed???
TheSubaruJunkie replied to subaruguru's topic in Historic Subaru Forum: 50's thru 70's
Yeah, the 1600 was used in DL models and GL5's. Alot of 1600cc single range models existed past 1980. I believe in 1983 they did away with the 1600cc and made everything 1800cc. But single range still existed in DL models. -Brian -
6 lug conversion
TheSubaruJunkie replied to H.K. Phooey's topic in Historic Subaru Forum: 50's thru 70's
Everything you need to know is documented there. There is also tons of conversation about the 6 lug conversion all over this forum, mostly in the off-road section. I took 6 lug rims and drilled 2 more holes in them to match the subaru 4 lug pattern. But the center hole was too small, and I had to grind away at my hubs to get things to fit propperly. I used chevy luv rims. -Brian -
tire question on EA stock wheels.
TheSubaruJunkie replied to s'ko's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I ran the 205's on my RX, with the front end dropped and had no rubbing problems at all. Was lookin for a pic, but I dont think i have one with the tires mounted. They were great tires, and a great price. 205/50R13 i believe is what I ran, maybe it was the 60 series, its been so long. -Brian -
Did the video work for you guys? Ive been having trouble all day, but that maybe cause my work block streaming media. -Brian -
Me and my co-worker hit up a trail we've read alot about. Its called Slickrock Road, but its no road. Its a forest route, and only about 3.5miles one way. We had a great time, did the trail in one direction, camped and came back Sunday. Im real pleased at how the Toyota handled, cant wait to do it again with lower t-case gears. Hope you have 24min to kill, here's the video link http://video.google.com/videoplay?docid=7096230928567802984&hl=en Pictures are as follows: Camp! What we woke up to at 8am: Great day for wheelin!! The trip was great! The drive from Sacramento is alittle long, roughly 2.5hrs each way. However, I think it was well worth it. -Brian
