5
Everything posted by Scott in Bellingham
hows this rig after now, got anymore info for us , anymore axle issues??
the SJR 2" lift is : 2" suspension in front ,and 1" suspension 1" body in back
Ive never tuned any of my entennas , I had a Ham guy set up the wire for me and he told me not to shorten it as it would effect the reception,the longer the antenna the better reception I have found, I have a antenna as you do on one of our cars and its the worst one Ive used, I like the 4-5' stick I have on the other car, SJR
those look awesome
Strut BOTTOM lift? (as opposed to strut TOP lift)
Scott in Bellingham replied to backwoodsboy's topic in Off Road
how much in inches over stock legacy? -
Next week I get a new car its a 92 Legacy Sedan 4 dr with 5 speed , its going to be lifted 4" with the lift at the bottom of the stock strut , now I have a few ?? length wise whats all the strut options for the EJ , say stock legacy , outback and others, ? -
RX convertable
Scott in Bellingham replied to mykingcrab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
whats the weather like most the year?? keep the top -
BW on a EA81 keep the stock angles on those axles, if you raise the front strut 3" over stock, then also drop the engine 3" , on the rear try to keep the axles straight dont go over stock geometry
cheap, free, or trade for weld help. WA
Scott in Bellingham replied to cid fits's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks good , I could help only if cars at my shop in Bellingham zzz zzz zzz -
the spare donut rim is thinner metal, also the inner bead is flat, does not have the bead lock ridge standard rims have,
Looks great Zap maybe I should go with that, McBrat does great work, would recomend him to anyone, get ahold of me Mick I have more work for you,
Full subaru drive train in mid engine rail?
Scott in Bellingham replied to Anomaly_983's topic in Subaru Transplants
sounds good I would go with the 4 x4 D/R trannny to get the lower gears and use EA82 axles -
Attn Scott in Bellingham 30's are on
Scott in Bellingham replied to one eye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Im sure they dont rub, the thing probably turns awesome too :lol: looks Cool thou -
new thought, remove the stock transaxle and in its place back enough to allow the diff up in there hookup a transverse front wheel drive transaxle , weld up the diff spider gears in that transaxle and thats were the reduction would be it would be about a 4 to 1 as apposed to the 1.6 to 1 stock would be light and compact but require some big time machine work to hook it all up, or slip it in behind the stock transaxle for even lower gears, did I loose you??
I hear scrap prices are up
EA-EJ Engine Adapters , new design
Scott in Bellingham replied to Scott in Bellingham's topic in Products for your Subaru
this plate was designed using the stock Subaru housings for a templete, done on my Mill with a digital readout, the dowel alignment holes are built into the plate, 2 large and 2 small you can see them at the sides in the picture, the holes are there its up to the installer if they choose to use them or not, you will need the 4 stock dowels from both EJ and EA housings, SJR -
OK this is my next project, I would like to see a 4" extension on the bottom utilizing the stock strut , anyone done that?? -
Wow let me say that again . .. WOW !! installed the 2nd version of the Adapter and what a difference the first one was easier to install , thats why I did it that way, the design was to restrictive and blunt, the second one which Im now going to offer for sale opens up and has a smooth transision, you can see in this next picture the difference down the throat, also as a added benifit it sits about 1 Inch lower had to take it out and test it and boy do I like this car , took it offroad and its got some lowend grunt what a difference from the stock EA82s Ive been running , now to work out the details and make a list of all the stuff required for this conversion, SJR
that day is out for me , Im ready now how bout this Saturday, ?
Heres mine check out the water line on the hood and side, 24" +
