5
Everything posted by Scott in Bellingham
install them straight , and with the help of a few trees the ends get a nice bend haaa hhaaaa:banana: :cool: :brow:
Loyale Front Little Lifting!
Scott in Bellingham replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just send gold bullion :grin: :banana: zzz zzz zzz :cool:- 22 replies
- Suspension
- Front
(and 1 more)
Tagged with:
Ive always used the original that was on the car, just dropped down some
I got a box of 50 on the way your welcome to some Scott
what axles and from who should I order to hook up a dual/range tranny to a legacy
looks like 140mm will work too
try it out , keep us posted
this is what they say Hi , dont stock 12x1.25x130 we do have 12x1.25x140 here @ $2.50/ea We have a $100 minimum order in to the US Thanks , XXXXXXXX Fuller Metric Parts Ltd.
fastenal goes up to 120 mm
need to find a source for M12x1.25-130mm bolts, having a hard time finding these bolts anyone have a source?
Ive been running 1-1/2" stress for 10 months- 22 replies
- Suspension
- Front
(and 1 more)
Tagged with:
Tricks on Pulling a tierod
Scott in Bellingham replied to nathan.chase's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I remove the nut , then smack the arm its bolted to not the ball joint threaded part, what this does is causes the tapered hole in the arm to flex a bit and the ball joint will fall out -
13" Justy wheels ?
Scott in Bellingham replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
never thought of a neon I happen to have a old set of those -
Im in the process of putting legacy running gear under a ea82 turbo , on the front to extend the strut I have unbolted the 2 bottom strut bolts and and extending it in that area will add a extendo peice and 2 more bolts , all steel , this will give plenty of room with the 31" tires ,will share pics as it comes along
drilled rim question, this is a hard one literaly!
Scott in Bellingham replied to El Toro's topic in Off Road
on the rims we did we didnt bevel the 2 extra holes just turned those 2 lug nuts over and used them like a normal nut -
Shop/Club night Bellingham Offroaders
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
K we will be casting EA81 parts -
I have been running my white car EA82 all year since January with a 3-1/2" lift at the strut and 2" lift at the engine which gives the axles and the lower control arm a increased angle by 1-1/2" ,it has the same axles in it that where in the car when I got it stock , I have had no issues with axle or tire wear and I have had this car extremly hard offroad without a axle failure . SJR- 22 replies
- Suspension
- Front
(and 1 more)
Tagged with:
looks like I might get it back Rollie picked up a blue one and it looks like hes going to strip all the goodies off this one and I will get it back if thats the case I have a EJ22 in the shop that needs a home and I would like to develope a Nissan transfercase lift kit and this just may be the ginnie pig, I really like the white wheels on this paint skeem , this was taken the day I got my swampers and I was stoked
what kind of driving are you going to be doing? will this be a sandrail with subbie power? if its mainly a dune runner go with the legacy ej type parts if its a woods trail rig go with a trans that has the dual range ( Low Range) I think it would be cool to make a 4x4 rail out of a legacy , nice and light lots of power if your a metal fabficator anything goes
you could remove both rear axles and drive in 4x which would be front wheel drive
your thinkin to hard zzz zzz
Offroad Videos Walker Valley Soobies plus Toys
hopefully a new T-case kit -
SJR Ultimate offroader project
well I decided against the Nissan Pickup stuff am going with Legacy axles and suspension , I have a wagon we will be pulling apart , been getting more excited about the build done more work on it in the last few weeks then I did all year, My final crawl ratio will be 154 CR :cool: -
running the shorter lift as this was the first car to have it installed on and it ended up being my DD . the 6" lift has better geometry then the 3-1/2" as the 3 .5 has higher CV angles , with both lifts we have not had a failed CV yet , my next car Im building will have 8" lift with a T-case but will not be my DD SJR
