174
Everything posted by lmdew
Well if it not broken don't fix it. only thing that can fail that's easier to get to with the manifold off is: - Knock Sensor - Coolant Temp Sensor You really don't need to remove much to change out the Intake gaskets as you an just lift the intake up a bit and slide the old gaskets out. As long as there is no stuck gasket you have to clean off you can slide the new gaskets right in and bolt it back up.
Have you tried going back to the stock Intake? Did this just start or has it always been this way?
If the intake if off, leave it off until you have the flex plate bolted up to the TC. The intake goes on easy enough. If you already have the Intake on but have not bolted up the engine to the frame you can raise the engine and trans and get the bolts started and almost tight from the bottom and then use a 6 point 1/4 socket to finish from the top through the access hole. Better access if you pull the plugs on the TPS and the breather hoses going to the PCV. I use the AC bracket of one of the 14 mm bolts that hold it to hook up the chain. Make sure the TC is seated completely, if you push back and rotate it, it will just hit the starter gear. Lots of information on seating the torque converter.
Back to this project: New Subaru PCV installed. It decreased consumption some but not much. Still using over a qt for every tank 300 miles. Ran MM Oil in the engine trying to free up any possible stuck rings Plugs very black and oily, Cylinder Compression Leakdown 1 135 100/96 = 4% 2 140 100/97 = 3% 3 140 100/97 = 3% 4 135 100/96 = 4% The leakage was heard in the oil fill, so it's going past the rings but I don't think it's excessive. For the Compression reading, remember I'm at 6300 ft here in Colorado so the numbers are lower than what you'd see at sea level. Once my Oil Pan Oring seal gets here I'm going to drop the pan and inspect that seal. If it's not that seal, what else could it be? The engine runs great, Head Gaskets just completed. No external leaks. New Subaru PCV.
At the self serve yards you can pull the complete door in Colorado doors are $50 - $75 complete. It's a wire connector, 4 or 6 bolts and the pin that goes the the rod that keeps the door from opening to far. If you not in a rush, wait for one of the same color and there will be not difference. Waist to get it fixed and painted when you can bolt on a Subaru part from the yard.
Replace the o-ring on the PCV drain back tube at the back of the pan. If that doesn't seal you'll suck oily vapors into the PCV constantly and smoke like a pig and use lots of oil. I hope this is the problem in the 2001 2.5 that I did the HG on. The PO had bent all of the intake valves. It runs great but sucks a quart every 200 miles. Plugs are very dark and sooty.
Thanks, There is a 2001 at the Aurora UPAP that was hit pretty hard in the front. parts of the engine are still there and the trans is there. Someone pulled the half shafts without removing the roll pin so they pulled the stub shafts out as well. Think I'll just watch the COS UPAP and wait for one to come up.
Trans was rebuilt a few years ago by Aamco according to the PO. The front diff went on it, low gear lube i suspect, there are chunks in the diff. According to the yards and www.car-part.com the trans requires a 2002 or 2003. Think it's worth changing out the front Diff? Anyone with a Trans in CO? Thanks Larry
Remember if you are reading voltage with no load on the circuit the meter can lie to you. Check out www.brighterideas.com or LoadPro on Youtube. Dan has some great electrical training. If you located the relay, you can remove it and jump the main contacts, that would provide power to the pump always. Do you have a Subaru or aftermarket Security system? I've removed so many of the aftermarket ones that were bad. Junk.
