Everything posted by lmdew
Flashing Check Engine Light
lmdew replied to catsdaddio123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet the CEL Codes first. Then apply the suggestions above as indicated by the code.
Lowering problems
lmdew replied to Jconkey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck nasioc.com. You may find more information there. Most USMB folks are Lifting their Subarus.
97 Legacy 2.5L aftermarket exhaust and fitment questions
lmdew replied to pginter96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow's the reset of the system. I have lots of good Colorado dual port header pipes. $60 shipped to a work/business address.
Foglight update/swap
lmdew replied to FlyBoy83's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've gotten some off Ebay, it was a long time ago. I've also used the old plastic and mounted in a sealed low beam lights. You have to cut out some of the back plastic but they will go in.
97 legacy outback 2.5 liter rough idle
lmdew replied to jgilvin06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNGK copper plugs and plug wires!
check engine code PO420
lmdew replied to the sucker king's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSearch the code, there is lots of good information hear and at the outback form. CarDoc has a very extensive article on it. You did the right thing, start with the easy stuff first: - Fuel Filter - NGK plugs and plug wires if needed - Check for air and vac leaks
clunk during gear shifting.
lmdew replied to AdventureSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrive shaft most likely, Were the U-joints checked, free movement? Did you make sure the front and rear diff were the same ratios?
Timing belt reassurance, please
lmdew replied to Gardenguardian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey will be OK, did you mark the rotation?
lmdew replied to jgilvin06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoils usually do not fail. If you want a spare or two, I have a stack of them from the 2.5 to 2.2 swaps. $20 shipped HG are easy to figure out, Check to make sure the radiator itself is full when cold Check the Over flow bottle for black oily stuff Larry
Frankenmotor, whats the big deal?
lmdew replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting so they actually make a HG just for this application?
1998 Legacy GT Limited Automatic Shifting Issue
lmdew replied to thefish383's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the AT light flashing 16 times after you start the car? If so you have a trans fault. The TCM hardly ever fail more likely an input. Throttle position sensor...
2002 Subaru Outback Impreza won't start
So you put a socket on the front crank pulley with the car in neutral and you can not turn the engine over? If that is the case I'd drain the oil and see if you have part numbers in there. You could also pull the plugs and then try it.
Help with Caliper Pin Bolt
lmdew replied to cascadeclimbn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJunk yard would be the fastest. There are several different configurations on Brakes. The nice thing about Subaru's as they are Lego's for the most part so you can bolt up pretty much any matching brake set. Lot's of folks have went to larger WRX Brakes, which would bolt right to your Impreza. As far as the pin, yes I have seen your configuration and if I was home could pull a dozen out of my 5 gal bolt buckets. That will not help you get back on the road but the junk yard will.
Does the engine turn freely by hand? If so you can inspect the complete flywheel Have you checked the voltage at the Battery and Starter under load? Does it make a difference if you put it in neutral?
My front brake was smoking badly, what to do?
lmdew replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd at least flush the brake system and inspect the pads. How many miles on the car? You may have boiled the brake fluid in that caliper. An inspection will tell you if anything is out of kilter. Larry
Is there a way to weld this captive nut? Cut frame rail and have limited access
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you drill from the bottom? Start small and work up until you can pop the head off the bolt
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a 6 point wrench and put it over the nut and then weld the wrench to the frame. You could JB weld or tack the nut to the wrench so it would stay in place if you ever had to pull it again.
2003 Legacy Outback Auto Trans Very Shifts
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes no flashing AT light. Pan was not dented Good Clean Fluid Shifts fine if I keep the RPM low Shifts fine if I manually shift gears I'm going to try to find a TCU from a trans with the newer inhibitor switch and see if that does not take care of the problem, but that will not be for a few weeks. Darn work is getting in the way of Subaru fun.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBetter but not fixed. The shifting is on as hard and it now shifts well up to 4K. I think I may have found the problem. The Inhibitor that is on the trans I installed has 4 mounting bolts. The Inhibitor that is on the original trans has 3 mounting bolts so there may be some difference. I thought the transmission numbers were the same, but there may be some differences. Trans Experts, any ideas? Can I find the correct ECU and swap it in or do I need to swap the trans?
Starting issue with EJ22
lmdew replied to speders's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs you said it could be lots of things. Poor Mileage - Plugs use NGK copper - Wires, use NGK or Subaru - Coolant Temp Sensor - O2 Sensor Leaking fuel injector could cause the issue as fuel pressure drops. Next time it happens instead of cranking for 20 seconds, if it does not fire right away, stop and then try starting it again.
Changed air filter and PCV valve, engine stalls after start
lmdew replied to bIGbEN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can clean it with MAF cleaner. Yes a used Subaru MAF is usually better than an aftermarket new MAF.
Rear crank seal: to replace, or not...
lmdew replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd leave it. I see that all the time, it's coming from the breather. Cam if you want to.
lmdew replied to bIGbEN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStuff happens. Get the code and go from there. You learn by doing things and as you have seen you have Great Subaru support right on the USMB.
2004 Outback lost Rear Wheel Drive
lmdew replied to chrisfen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your rear diff. My son and my Daughters cars over the years both had a rear half shaft pop out about a 1/2. All the torque was going no where. They were both manual transmissions and it felt just like a slipping clutch. One way to confirm the rear diff is good is to try to turn the input shaft/rear drive shaft with both rear wheels on the ground. It should not rotate.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo I believe it was an 02 Forester. The trans had the same number so it should be a direct plug and play. I believe I have it solved, the Inhibitor switch was slightly off. I rotated it about an 1/8" clockwise and the short test drive was good. Additional road time will confirm the fix. When the shop saw the trans shift to neutral and then come back into gear and with the trans shifting well in the manual mode I saw the light! Thanks for the Help. Larry
