Everything posted by lmdew
Totaled, now what?
lmdew replied to KRB64's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you don't have need of the parts, it's most likely a better idea just to scrap it. Engine - $150-200 if it runs good Trans - $50 with TB Seats $20 Most yards will give you $75-200 for the car Scrap value about $140
Master cylinder going bad?
lmdew replied to trivalence's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you bleed the brakes, you should not let the brake go down further than it normally does. Putting a 2x4 on the floor usually keeps it in a safe zone. If you take it all the way to the floor, the piston is working in an area of the cylinder that may have built up crud and it can take out the seal. I'd try bleeding it again. If you pump the brakes do you get a better feel? Then air in the system.
2.5 to 2.2 Swap
lmdew replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can tap the trany for an heli coil. The hole is the correct size for the 14mm stud. I've done several this way. You can do it after the engine is in. I've worked from the bottom.
2.5 to 2.2 Swap
lmdew replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 99 canister is in the back of the car. Just loop the 95 lines hooking them together. It works well if you put the larger line over the smaller one and just make them u-turn at the hard lines. You only need about 2" of vac line to do it.
Got a code out of the trans, Duty C. Next step?
lmdew replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe wire to the C-Duty is very short, and had to be unplugged as you pull off the tail shaft.
Dead Eyes head gasket project
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe pulley should always move, if it sticks when you tighten it it's not assembled correctly.
1999 OBW No Crank No Start
lmdew replied to Husky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSmall wire on the back of the starter! If it's not connected, the starter main contact's will not close and not battery voltage to the starter motor.
1999 2.5 DOHC > 1995 2.2 SOHC
lmdew replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they will bolt up, sometimes the brackets need to be moved as well.
97 impreza 2.2l timing.
lmdew replied to xjeeper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you still have the covers off the TBelt take a picture of the timing marks.
lmdew replied to xjeeper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure you are using the tick mark in the back of the crank gear and not the arrow on the front. Do you have compression when turning it over by hand? Do you have Spark? Have you tried adding a cap full of gas to the intake?
I need mechanical advice for my 1995 Subaru Impreza L 2.2Litre
lmdew replied to XxGHOSTxVIIxX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, it sounds like a water pump leak. The water pump is driven by the timing belt, so depending on the milage you may be do for a timing belt and seals. Search here or check you tube, there is lots of good information available. Overheating a Subaru engine is bad! Hopefully you have not done major damage. Find a good Subaru Mechanic or USMB member close by to help you out.
No start unless throttle held open.
lmdew replied to subiphoenix89's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you smell fuel in the exhaust? Could be you have a leaking injector and it's flooded.
Symptoms of faulty cam angle sensor
lmdew replied to Peter w's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsually they are either good or failed. Might check the wiring and plug. When it does not start are you getting fuel and no spark?
Speedometer, odometer and tach are not working after engine swap.
lmdew replied to No Use's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you know if they were working when the eng&trans were in the RS? Speedo, I'd swap the sender from the old trans on to the RS Trans.
Regular Car Reviews - 19997 Impreza
lmdew replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLove my 98 OBS, 326K 5sp and I get 28-29 mpg all the time.
No rear sound gen v legacy gt
lmdew replied to hayden87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFADE all the way to the front?
Main fan not working
lmdew replied to dssenne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the temp gauge getting above the 1/2 way mark? The fans are independent and 2 speed on one or both. If the engine is hot a single fans comes on, if you have the AC on, both fans should come on. Is your AC Charge low?
97 Impreza OBS 280K, Manual trans, no 4th gear
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, used is the way I'll go.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRepair this trans or replace it with a used one? UPAP trans are only $125 and not to hard to find, so I'm thinking replace the trans and then when I have more time I could split this one and see how bad things are inside.
I just picked up a 97 OBS project - 281K - Clutch was totally out, the center had broken out of the disk. A cheap clutch for sure - I put a good clutch in, the trans shifts fine, up and down but will not go into 4th. I have not checked the linkage yet. - The Trans input shaft did have a little play, but not bad for 281K I'm thinking a used trans,but thought I'd ask. Thanks, Larry
engine to tranny bolts nuts.
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can raise the engine with the mount nuts off or drive out the half shaft pin and slide it out a bit. I do a 6 point socket on a 3/8 universal and 6" extension. It usually works fine.
99 legacy outback wagon oil leak
lmdew replied to Husky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have any other engine maintenance to do, it's easier to pull the engine that drop the trans to do the clutch. Don't mess with the rear main, most of the time people that change it cause leaks.
It misses then it doesn't - 92 legacy 2.2
lmdew replied to pa_trick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the CEL on when it's running rough? I'd put it in the diagnostic mode and run it to see what comes up.
Exhaust studs
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDealer or junk yard. I often pull good ones in rust free CO. In OH they are most likely all like yours.
Brakes
lmdew replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe half shaft slips into the Knuckle. Brake caliper, Brake Hose, Backing Plate, Hub and E-brake cable will do the trick.
