Everything posted by lmdew
1991 Legacy Wagon Hard to Start - need advice trouble shooting.
lmdew replied to None77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow old is the gas in the tank? If you do not drive this Subaru very often, you may just have old gas with more moisture collected in it. You can do diagnostics on the car, you have to read up on it. Plug the green connector together under the dash and meet the drive requirements. The IAC controls the idle The TPS sends the shift down signal to the trans. I'd get at least a full tank or two on 91 Octane gas through it with some Sea Foam treatment before you start changing parts. Subaru or NGK Plug wires Copper core NGK Plugs would be the recommended parts.
1997 EJ25D to EJ22E first timer swap
lmdew replied to pginter96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThrottle Cables, loosen the 2 12mm nuts, run the back one completely off until you can slide it out of the bracket. You can now bring the cable around to line it up with the slot in the throttle cam and remove them. There is a metal tab on the bottom of the cam that you have to slide the cable past. Yes, you can swap the lines, it's pretty time consuming as you need the valves associated with the system as well as the electrical harness. It can all be swapped, just make sure you route the harness the same as there is not much room between the engine and the harness when you bolt the intake back up.
05 Outback, PLEASE help!
lmdew replied to Gberg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have the CEL Codes? That will help. I'd check all the grounds to make sure they are good and battery connections are good. Subaru Alt? If not you may want a OEM part. Does it start fine after your drive or is the battery dead?
01 Forester auto trans, doing weird things.
lmdew replied to bratman18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd try adjusting the Inhibit SW/shift cable. I have an Outback that has a Forester trans installed that is doing the drop into N when you get on the gas hard. Drive easy and it works fine. Shift manually and it works fine.
lmdew replied to bratman18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd check the linkage adjustment. Does it do it if you manually shift it, say 1st, 2nd, 3rd. Try leaving it in 3rd.
Hey Colorado, can someone help me out?
lmdew replied to Speedwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd just hit one of the UPAP yards and pull one. If it's not it you can take it back for credit.
USMB Merry Christmas
It's a Great Form we have in the USMB. Merry Christmas to you All Larry
towed an AWD on a dolly
lmdew replied to Steve55958's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe said: It was towed about seven miles at 40mph
Legacy 2 litre ignition fault
lmdew replied to yewman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost Subaru coil packs fire 2 plugs, 1&3 or 2&4. Did you try swapping plug wires? Did you use Subaru or NGK Wires? Copper Core Plugs? NGK
Upper radiator hose blowout
lmdew replied to upnorthguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes folks over tighten the hose clamp and crack the plastic.
1997 Outback wagon heater blower motor replacement
lmdew replied to CalDouglass1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX3 screws hold it in. Electrical connector. You will have more access if you drop the glove box, 2 Screws Remove the Electrical Connector Remove the 3 screws Pull it down. If you have a used fan, you can plug in the connector before removing the old one to make sure it's not an electrical issue.
Those Darn Rabbits
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSwapped the coil. problem solved.
Those Darn Rabbits
I have my Subaru parked at work in Colorado Springs and the Rabbits have crawled up on top of the engine and eaten the wires. Missing on 2&4. Plug wires have been changed, so I'm going to look closer at the coil wires. Lots of grass and bushes around, I don't know why they like to get up on the top of the engine. Crazy!
USMB Donations and Orders?
Who processes the USMB Donations and Orders? I made a donation and ordered a Sweatshirt and Tee Shirt. I got a receipt email, but never a shipment email or Tracking #. Have not received the order? Thanks, Larry
97 impreza outback sport - no power to fuel pump
lmdew replied to wsjones's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCrank and Cam Sensors go to the ECU to control the engine.
transaxle bearing 02 forester....does the engine need to be pulled
lmdew replied to Bowser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFind a new Subaru Mechanic. The engine flex plate is bolted to the crank. The Torque Converter is bolted to the flex plate and splined to the transmission. All bearings are deep in the transmission or the front diff.
lmdew replied to wsjones's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have to hook up an O-scope to read the input to the ECU. Just hit the Junk yard and grab a couple.
deer 1 01 outback 0
lmdew replied to 01 Outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the rear lower A-arm mount bolts do not cross thread when you install them. You'll have it back on the road in no time.
lmdew replied to Bowser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst, I'd ask what bearing he is talking about? Auto or Manual Trans? What symptoms are you experiencing?
1997 Impreza Outback Transfer Solenoid
lmdew replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGreat!
lmdew replied to wsjones's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you provide a good ground does it work? www.brighterideas.com You meter can lie to you. Larry
Tire help needed ASAP!
lmdew replied to tbolt1003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo FWD fuse on a 5sp trans. Not worth the possible problems, get a flatbed truck or take new tires to her.
4 EAT removal from legacy gtb
lmdew replied to barrcus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes or from the bottom. Use a 6 point socket! Make sure you read on seating the TC and you should inspect and or change the TC seal on the trans.
poor headlights
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 3m headlight cleaner is good. Also make sure your bulb connectors are clean and tight. The cover is glued to the housing, it won't come off.
Rust in Door Well
lmdew replied to K9Leader's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProblem is that area is 3 or 4 layers of skin. When you try to weld it, it's going to give you problems.
