Everything posted by calebz
So did I.. same guy. New improved board presence.
Best year wagon to look for
calebz replied to subanoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For an all around car with capability to get to some of those hard to reach camp spots, my 87 turbowagon has been great. Its only single range 4wd, but I also have 14 inch wheels with slightly larger than stock tires for a couple of inches extra ground clearance. Its not a hardcore wheeler by any means, but it does everything from grocery shopping to camping and everything in between quite well. BTW .. I really want dual range too -
...And sometimes the bearings go to hell just from starting the motor up..Sorry snotrocket.. couldn't resist.
Here Ya Go There are 2 relays located above the ECU just to the left of the steering colum. One is for the ignition, one if for the fuel pump. They both look like the relay in the above pic.
Dyno Day, serious numbers, real proof, real pictures.
calebz replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have been trying to get a Euro ECU from marnix for over a year.. lucky bastard... But, then again, I couldn't go to Germany to get it. -
NorthGuy.. You obviously don't have a Turbo:lol: Mine doesn't do much past 6500.. runs out of breath.. with the stock air intake, it would run out about 5800. Shifting at 5500-5800 gives me pretty good reponse. How high you can safely rev a stock EA82T really depends a lot on the condition of the motor.. remember.. these things are 15+ years old.. too much, too often will spell disaster.. its only a matter of time.
The fuel pump relay and the ignition relay are directly above the ECU. Loosen the 3 nuts that hold the ECU. Its not necessary to remove them. Then drop the ECU down . Right above the left hand side of the ECU is where they will be located. If you aren't sure what the look like, I will take a pic of one tomorrow and post it.
They are expensive, but he's yankin your chain in regards to availability. Try another dealer, or save yourself $100 and get on from Autozone.
Most people regap to .048-.050 after installing the Accell(stock is .044)
i found one of those at Tacoma PAP last year. Richie has it now.
As has been said.. with first, its like that for a reason. With reverse, grinding or clunking is common on a lot of cars.. even brand new ones.. A habit I picked up from one of my Saab owners manuals was to put it in second then put it in reverse.. works every time with every car I have had since that first saab 10 years ago.
what to check when buying an ea82 wagon
calebz replied to MaroonDuneDoom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rust, oil leaks and overheating.. Service records indicating T-belts and water pump. corrosion of radiator.Make sure the rear window sprayer works.. I'm on my 4th wagon and not one has worked. -
On an SPFI car? More air in .. more air out. Better intake.. better exhaust. For offroading, look in the photos section. More more specific info, do a quick search. theres tons of info here about the questions you are asking.
In dj's defense, its an 86.. bypassing the overboost control is easy on 85-86 turbo cars.. its 87 and up that are troublesome.
After the car dies, Does it start right back up?
That must Hurt!!
it would be the driver side, thats the one that turns the disty, just turn the motor over.. if the rotor doesn't turn, the belt is broken To check the passenger side, just pull a couple of the cover bolts out and either peek in or stick a couple of fingers in there and feel for slack
I have 4 extra smaller grounds coming off the bat to various places on the engine and body.. it stops the digidash from weirding out when the car is under electrical load(lights, heater and stuff all at the same time.)
That sounds like a vacuum leak. Have you checked for error codes? The surging could be caused by the EGR solenoid.. notorious for going out. Have you checked for old cracked hoses? Pulled your plugs to check for signs of running lean?
Thats about all I ever got out of my 3AT turboWagon.. that combo of turbo and slushbox is terrible for gas mileage. If you want your mileage to go up, drive like an old lady.. don't engage the turbo.. if you want it to go up higher, slap in a 5 speed.. thats what I did.
continuation of my emissions removal
calebz replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm with Jon.. Carbs are bad... -
Is the rotor turning when you crank it? sounds suspiciously like a broken timing belt. Pull the distributor cap and make sure the rotor is turning.. if its not, make sure the little screw hasn't fallen out of it.. if thats still there.. and it isn't turning, you broke the drivers side timing belt. not the end of the world.. you live in subaru land. lots of people in your area that would probably help you learn how to replace a timing belt.
