'Nudder A/C post, '93 Leg/Calsonic compressor
Legacy777 replied to deiscient's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's the compressor clutch, I was not successful in removing it. I'd just keep using it until it dies....
Request: How to reset TCU in 1996 Impreza
Legacy777 replied to HX-20S's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is the same as the "Hold" button on the first gen legacies.
Top Dead Center - why?
Legacy777 replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe're venturing down the road of semantics........
EJ22 Lifter Replacement
Legacy777 replied to MailManX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt shouldn't, the main thing I can see happening if left for a long time is inconsistent wear or premature surface wear on the cam.
Legacy777 replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe haynes book is stupid. There's absolutely no reason to do that. Just align the timing marks that are on the pullies to the marks that are on the cam covers. Make note of the mark that's on the crankshaft gear. The mark is on the front of one of the teeth that is read by the crank sensor. It's not the arrow on the front of the gear.
R134a Oil Question
Legacy777 replied to e3mt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou really need to flush the system thoroughly. I had a compressor knocking, replaced it. It worked fine for a while, but did eventually die. I recently yanked the condensor out, and there were small metal flakes at the bottom outlet. I'd really recommend pulling all the components out and flushing them thorughly. They make a flush, however brake cleaner will work just as well.
Won't shift from park
Legacy777 replied to brama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it is that box, I do have one. I yanked it when I did my 5spd conversion. You can have it for the cost of shipping. Here's a pic of the box, and some factory scans which might help in diagnosing the problem http://www.surrealmirage.com/subaru/swap/electrical.html#shiftlock
too high cold idle?
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1500 rpm is normal for cold idle. You're car is fine.
Timing Belt Replacement
Legacy777 replied to NewSuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the timing belt is relatively new...it should like fairly new. It should be semi-clear as to whether or not it's been changed recently. Also, here's factory scans of the timing belt change procedure for the legacy. Should be similar. Also, make sure you torque the main front crank pulley to 110-120 ft-lbs. All the manuals, including the factory one have the wrong torque listed. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg
Weight of '06 wheels?
Legacy777 replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd ask over on nasioc....someone's bound to know....
Legacy777 replied to MailManX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Michael, Honestly, this is a pretty easy job. All that needs to be done is to remove the valve cover, take off the rocker assembly, pull out the old lifter, bleed the new lifter, put the rocker assembly back on and put the valve cover back on. It'll be easier on reassembly if they turn the engine by hand so that the lifters aren't resting on any cam lobes. Personally....I can't see this being any more then 2 hours worth of labor for one side....and that's being very generous for someone that has no clue to what they're doing. I think a good subie mechanic should be able to do the one side in an hour or so. There's some pictures of the heads & rocker assemblies here http://www.main.experiencetherave.com:8080/subaru/images/ej22t/14/default.htm
Chassis numbers, what s the difference?
Legacy777 replied to mustang_89's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru is weird....they will have a different part # for an item that is almost exactly the same except for one small thing. It could be a small little clip or something that's different, but it'll get a different part #. What i'd recommend is putting those part #'s in an online subaru dealer's database and see if anything's been superceded. www.subaruparts.com is a good one to use. Other then that, I'd go out to a subaru dealer and see if you can find any physical differences. If not, it's probably just numbering thing......
Obd Codes
Legacy777 replied to gyuunuuya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst thing I always suggest when troubleshooting ECU codes is to clear the codes, drive the car around, and see what codes come back. Typically if you get more then one code, it's possible the other codes could be caused by a "hiccup" from the real problem. As for your problem, I'd suspect the coolant temp sensor, even though there's no code stored for it. They will sometimes not throw any code, and may even test ok, despite being the problem.
Reusing Head bolts, and what my local dealer thinks
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou don't need to replace them. I contacted a dealer in the Seattle area I trust, and they NEVER replace the head bolts. I also contacted Emily at CCR regarding the head bolts, and she said I don't need replace the bolts either. That was good enough for me. So I reused them.
91 Legacy wagon 2.2L missing when started
Legacy777 replied to rdrx7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore then likely the coolant temp sensor is bad. It's almost a tell-tale sign that the CTS is bad when the car runs bad when cold but ok when warmed up, or vice-versa.
1992 legacy missing at low speeds need help!!!
Legacy777 replied to nickrocks2005's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFix the pulley, and check the key way on the crankshaft to make sure it's not damaged. That bolt needs to be torqued to 110-120 ft-lbs As for your check engine light . Check the engine codes. Instructions can be found on my site www.surrealmirage.com/subaru/engine.html
98 imprezia transmission problem
Legacy777 replied to whittles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny idea when the last time the transmission fluid was changed? I'd start with that. Maybe something got gummed up in the valve body.
Trunk Light
Legacy777 replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave taken a multi-meter to see if there is power at the wiring connector? I'd do that first, and see if you have power.
Ganzflow
Legacy777 replied to NoahDL88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt sounds similar to the cobb filter for the RS's. It's basically an enclosed cone paper gauze/oil filter. They're not bad. I'm not sure if the ganzflow is foam & oil, or paper & oil.
R134a Oil Question
Legacy777 replied to e3mt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need PAG 100 oil. I believe the total system oil amount is like 5.8 oz or something like that. I can check, I've got a book at home. Dumping out the old oil, measuring it, and putting the same amount back in is fine too. You should replace the receiver drier as well since the system is open. Just curious, why are you replacing the compressor? Did it die?
Locking the Engine with the Flywheel access hole
Legacy777 replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2486.JPG http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2487.JPG http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2488.JPG
Online Soob Parts Vendors search
Legacy777 replied to Adam Lee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.subarugenuineparts.com
AC and Overheating problems...
Legacy777 replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour AC problem. Did you have the system evacuated with a vacuum pump for 30-45 minutes before charging it? Did you replace the receiver drier? Your friend.....it sounds like he has an air bubble in the system, or a blockage in the coolant line somewhere.
Auto trans shift concern
Legacy777 replied to FSTOUR's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know when the temp is cold, the trans will hold the 3rd gear.....however I doubt it's cold enough anywhere in the US for that to happen right now.
Legacy777 replied to mustang_89's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year legacy?
