8
The only thing that needs greasing is the caliper guide pins. However if the dealer had the caliper off to check this and didn't grease them, that's pretty shotty service. As for the vibration, did you just have new brake pads put on? It's possible the old pad material on the rotor is causing an intermittant deposit of the new pad material and causing the shimmy you feel. You can try taking the rotors off and sanding them to see if that helps. Where do you feel the vibration? In the steering wheel or in the brake pedal? The valve noise is probably from the lifters. If the oil wasn't changed regularly, it's possible crud got into the hydraulic lifters and gummed things up.
So the speedo doesn't work normally? Are you getting any codes? If not, It's probably the motor in the dash that operates the speedo needle. If it were the speed sensor, it would pop up a CEL. It's possible there is a loose connection. If you wanted to take apart the dash and pull out the combination unit to check it out, you might get lucky.
Hmm.....yeah...something sounds weird. To be quite honest, most dealer mechanics are just parts changers. They have very little troubleshooting skills, and unless a blatent computer code is flashing in their face, they're stumped. You never answered my question. So the starter cranks? but the engine doesn't start? There's two things you need for the engine to work, fuel and spark. If the engine is cranking, not starting, and you pull a plug out and it's wet, I'd say you have fuel. Leave a plug out and resting against the block to see if you have spark. The only thing left is to check whether spark & fuel are being delivered at the appropriate times. If the timing belt is good and aligned properly, then it's possible your ECU is on the fritz.
The automatic transmissions have a torque split of 90/10 under normal straight dry driving conditions. So the front wheels are going to be most of the work. WHen slip occurs, the torque split can increase up to 50/50 Manual transmission cars have 50/50 torque split all the time. Manual tranny cars use a viscous limited slip differential to control torque transfer, while the autos use electronics.
pics http://www.main.experiencetherave.com:8080/subaru/images/trannyresistor1.jpg http://www.main.experiencetherave.com:8080/subaru/images/trannyresistor2.jpg http://www.main.experiencetherave.com:8080/subaru/images/trannyresistor3.jpg Don't do what the picture says...leave it plugged in http://www.main.experiencetherave.com:8080/subaru/images/trans_connector.jpg
Andrew, I'm not sure what the gear ratios were like overseas, but the turbo legacies in the states got 3.90 final drive ratio. However.....that really doesn't matter. The differential is staying the same. You're just replacing the gear sets. You can do whatever you want with the gear sets. You can remove the drive pinion shaft from the driven shaft. These scans may help show what I'm talking about http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_AWD_drive_pinion_assy.jpg here's the main shaft http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_main_shaft_assy.jpg
