29
Everything posted by Turbone
This is probably a stupid question but...
Turbone replied to offroadsubie1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I believe he's talking about the fan belts. And it still has A/C if theres 2 belts. Theres a 6 point stud that sticks out just above the water pump. This will loosen the tenshioner for the A/C belt. The other belt is adjusted by moving the alternator. -
Ok, if you want to get technical. The manual says from 3/16 - 5/32, or 5mm - 6mm.
Anyone interested in my project?
Turbone replied to my69opelgt's topic in Non Soob Cars and Bikes Discussion
You see the pics I posted in your thread? The guy that owns that (might have sold it by now) had several GT's in his yard. I took a pic of a green one he had that was in ok shape. He said he wanted to sell it all. He had tons of cars, old Rovers...you name it - he had it. I'll see if I can find that pic. Maybe some day I'll get a GT -
If I remember right (which isnt often) this took me about 10 cans. There is no clear coat on it, yet.
What size punch are you using? It should be a 3/16th punch. Anything smaller and it will spread the roll pin open and may damage it so it hangs up inside the axle.
help im new and i need little off road tires!
Turbone replied to bicycle_ben's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wat? -
But its a PITA to try and twist it out of there, isnt it? Its alot quicker to jack the engine up a little to make the job easier.
Turbo wagon with a hidden secret-
Turbone replied to 4x4_Welder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No idea, but I bought my PAP replacement for $10.50 -
Yup, looks just like the one on my first SVX. -
Subaru Select Monitor
Turbone replied to mountaingoatgruff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nope, his is different. Sorry :-\ -
Got a pic of it? I might know someone who has one and might be able to help. But I need to know if its the same thing. -
Be a good idea to remove the turbo, it has water and oil lines connected to the head that need removed. That bracket can be a pita, soak the bolts with PB Blaster first.
You missed that part :-p
Just bought an 88 GL Hatch with RX EA82T
Turbone replied to FJason80's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Sedan is normally a 4dr, this car is called a 3dr so it wont get mixed up with the earlier EA81 Hatchback. They did have a 3dr, on demand 4wd with a turbo, so I'm not sure if this is a swap. Dont see to many of them, but they are out there. Theres a idle/air screw on the back of the throttle body, adjustable from the top. It may have a black rubber plug in it, but most times its gone. Might want to check the timing on it also. Theres a green test connector that needs to be plugged in to check timing. It could either be in the engine bay by the drivers side strut tower/windshield wiper or under the steering column next to the ECU. -
Take one of the other nuts off the back of the light, I think theres 5 on each one. Is the rubber gasket the one on the door, or the one that surrounds the door jamb? Should be able to find a good one down here in a wrecking yard.
Well I Sold It.....
Turbone replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did you ever get pug nuts? I posted in the playground saying I had some and never got a reply if you were going to come get them. -
I have a pair of those.
So much for the post I had in this thread :-\ I have one also. Let me know if you dont get ahold of Mark. -
just bought an XT6.....added pics!
Turbone replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can change the wiring at the relay, which I believe is under the dash. I dont recall the exact location tho unfortunately. The wiring diagram will tell you which wire is the one from the light switch. Just need to swap that out with a powered wire, dont forget a fuse in there. -
RX having some issues. help harpua find the gremlin
Turbone replied to harpua's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Run some Seafoam thru the fuel system, the injectors could still be gummed up. -
http://www.ultimatesubaru.org/forum/showthread.php?t=49918
I agree with the Seafoam treatment, etc. But if its running better at boost, you probably have a vac leak somewhere. Get a can of ether and check all the intake hoses and around the base of the intake manifold.
I installed Legacy seats in my last Brat. It was a while ago, so its a little hard to remember it all exactly (CRS). I believe theres a inch difference between the track widths. I cant remember if the seat rail was narrow or wide tho. But I removed the tracks from both seats and installed the EA81 rails onto the Lego seat bottom. To get the rails off the Lego can be a pita, it took some drilling to get some spot welds off. Then I made up a couple of spacers and used them on the outer rail. When installed I noticed that the seats had a recline to it. It can be adjusted with shims, but I left them as is.
